Brakes
Discussion in '2nd Gen Tundras (2007-2013)' started by Jgarcia6820, Oct 29, 2018.
  1. Oct 29, 2018 at 7:15 AM
    Jgarcia6820
    Jgarcia6820 [OP] New Member
    Jhonny
    2013 tundra rock warrior
    what is everyone using for brakes?
    Checked powerstops n got mix reviews,
    Oem are warped and want to upgrade new rotors and pads
  2. Jan 19, 2019 at 2:43 AM
    Jgarcia6820
    Jhonny
  3. Jan 19, 2019 at 6:12 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I’ve got the power stop drilled and slotted on mine with the top of the line Wagner pads and I’m very happy with them I tow a 6x12 enclosed trailer for Quad racing and they def. made a difference over OEM stuff
    Jgarcia6820[OP] and Y0TA PR0 like this.
  4. Jan 19, 2019 at 6:23 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Original rotors lasted 97K. So I replaced mine with oem. Good luck. D
    Jgarcia6820[OP] and 15whtrd like this.
  5. Jan 19, 2019 at 6:27 AM
    FXFormat
    FXFormat New Member
    I used Platinum series painted rotors and pads from Advance, no issues here. Brakes well, doesn't make noises and low dust.
    Jgarcia6820[OP], Rica25 and 1UPPER like this.
  6. Jan 19, 2019 at 6:59 AM
    timsp8
    NY
    I used powerstop for years. Worked pretty good but can’t say I remember a big difference over oem. Going from worn out oem to new aftermarket there will always seem to be an improvement.
    One definite comparable though is price. Powerstop is about half the price of oem.
  7. Jan 19, 2019 at 7:08 AM
    I used the Power Stop drilled and slotted rotors with the Extreme pads and I am very happy!IMG_20180225_154833897.jpg IMG_20180225_223156422.jpg
  8. Jan 19, 2019 at 8:06 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    I have roughly 10.5k so it will be awhile for that decision but when the time comes I will revisit this thread.
  9. Jan 19, 2019 at 10:35 AM
    StrayCat4x2
    StrayCat4x2 040 is Super Fastest!!
    Lenny
    Pa.
    2007 Super White Tundra
    Stock for now.
    Prostar I was just looking atnthose on Rock Auto. Front rotors are starting to warp enough I can feel i in the pedal. How long have you had them on?
    Prostar 190 likes this.
  10. Jan 19, 2019 at 10:45 AM
    AZTundra
    Paul
    Phoenix, AZ
    @Prostar 190
  11. Jan 19, 2019 at 10:47 AM
    15whtrd
    15whtrd Mr. Blonde
    Many times they are not warped. It’s pad material that is inconsistent on the rotor surface. I suggest trying the break in process again. Some call it bedding them in. Basically you want pad material coating the surface of the rotors. There is a thread on it around here. Racers have it professionally done. But I do know I have a series of breaking methods. Something like 40 down to 20 mph a few times in a row fairly aggressively. Then 60 down to 40 mph just about standing on the pedal a few times LOL. And bring it home and let it cool off. There is a more scientific detailed way to do it but this works for me. Basically you go get them progressively real hot and then bring it home.
    Jgarcia6820[OP] likes this.
  12. Jan 19, 2019 at 10:51 AM
    TheBeast
    TheBeast The Beach
    I upgraded the brakes over a year ago. So far so good.
    Sport Tech slotted sport rotors
    Posi Quiet ceramic brake pads
    Rica25 likes this.
  13. Jan 19, 2019 at 10:52 AM
    TheBeast
    TheBeast The Beach
    nice clean up in the wheel well
  14. Jan 19, 2019 at 10:56 AM
    About a year and I pull a boat every Saturday and Sunday all spring thru early fall.
    Y0TA PR0 likes this.
  15. Jan 19, 2019 at 10:58 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    What’s up Bryan! What kind of paint did you use? Does look awesome!
  16. Jan 19, 2019 at 11:02 AM
    StrayCat4x2
    Lenny
    Pa.
    Stock for now.
    Thank you for the info, think I'll install a set. Are you using ceramic pads of just semi-metalics?
  17. Jan 19, 2019 at 11:15 AM
    Thanks VHT caliper paint.
    Y0TA PR0[QUOTED] likes this.
  18. Jan 19, 2019 at 11:17 AM
    The Power Stop Extreme pads Z36 ceramic.
  19. Jan 19, 2019 at 11:23 AM
    StrayCat4x2
    Lenny
    Pa.
    Stock for now.
    Cool thanks
  20. Jan 20, 2019 at 12:16 PM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    Without hijacking the thread too much, how is the caliper paint holding up? Are you finding it getting dirty and looking bad between washes? How are you getting in to clean them when they do get dirty. I love the look, but don't want them to look dirty all the time.
  21. Jan 20, 2019 at 12:29 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I just installed a set of Hart brand drilled and slotted rotors and Wagner ceramic brake pads on my friends 2014 double cab tundra.His rotors we're warped pretty bad . I did them Saturday so I don't know yet how they are going to hold up.the drilled holes were beveled so they shouldn't crack. They looked really good behind the wheels,
  22. Jan 20, 2019 at 2:45 PM
    Everytime I wash my truck I spray a little simple green on them they clean right up.
  23. Jan 20, 2019 at 2:59 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    When I think of pads, one brand comes to mind. Kotex.
  24. Jan 20, 2019 at 3:16 PM
    You can see by this picture in the fall they still looking good.IMG_20180709_175648662.jpg
    WrigglingWilly likes this.
  25. Jan 20, 2019 at 5:31 PM
    11SilverPlatinum
    Dave
    Nice, one more thing to add to the list :thumbsup: Thanks for the quick response.
  26. Jan 20, 2019 at 7:43 PM
    Jgarcia6820
    Jhonny
    Towing occasionally, not to heavy but many down hills
