800 miles and already broken.
Discussion in 'General Tundra Discussion' started by Morninwood, Jan 16, 2019.
  1. Jan 16, 2019 at 7:29 AM
    Morninwood
    Morninwood [OP] New Member
    Jerry
    2019 TSS Crewmax 5.7 Tundra
    Anybody know anything about this? To say I’m disappointed is taking it quite
    Mildly. I bought a Toyota because I was tired of taking my Chevy’s in!
    Stormtrooper81 likes this.
  2. Jan 16, 2019 at 7:32 AM
    FXFormat
    FXFormat New Member
    Take it in for warranty
    zcarpenter92 likes this.
  3. Jan 16, 2019 at 7:35 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Are you driving in wintery conditions? The TSS will not work if there is snow on the Emblem & windshield.
    If so, try cleaning the emblem and ensuring the camera in the windshield is not blocked.
    The pre-collision system uses radar (in emblem) and camera (on windshields) to operate. If either are blocked, it cannot properly function
  4. Jan 16, 2019 at 7:41 AM
    Morninwood
    Jerry
    Why didn’t I think of that?
  5. Jan 16, 2019 at 7:46 AM
    Morninwood
    Jerry
    Nope, and you can eat off of the truck. I did not realize the camera was in the windshield. It is clear. Thank you, though
  6. Jan 16, 2019 at 7:48 AM
    Morninwood
    Jerry
    I AM running a radar detector. Could this be a problem? Edit- just drove without it... same problem
  7. Jan 16, 2019 at 8:18 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    If it is blocking the view of the camera around the rearview mirror, yes.
  8. Jan 16, 2019 at 8:19 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    Have you consulted your Owner's Manual?
  9. Jan 16, 2019 at 8:43 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Before messing around at the dealership, I would just disconnect the battery for a few minutes and reconnect it. That seems to fix any strange "electronic alarms" I get on my truck.
  10. Jan 16, 2019 at 8:57 AM
    PMG
    PMG New Member
    Well that sucks... it's like it's unplugged
  11. Jan 16, 2019 at 9:08 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    This happens to me almost every morning when the truck is parked outside. Snow and ice covers the cameras, lights go on and automagically come back on when the defroster finishes it's job.
  12. Jan 16, 2019 at 9:12 AM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I got the same message yesterday. The next message was clean sensor. It was during a very heavy rain shower and cleared on its own.
  13. Jan 16, 2019 at 9:14 AM
    twintundra2016
    twintundra2016 New Member
    Chad D
    New Brunswick, Canada
    2013 Tundra SR5 5.7L
    depending on conditions driven in sometimes will affect TSS operation, do you have any sort of lift kit or anything like that??
  14. Jan 16, 2019 at 9:18 AM
    koditten
    Kirk
    Midland of the Mitten
    If you don't know what it is, how do you know it's broken?
    Y0TA PR0 likes this.
  15. Jan 16, 2019 at 9:20 AM
    twintundra2016
    Chad D
    unavailable doesn't mean broken, I would try radar cruise possibly?? :fingerscrossed:
  16. Jan 16, 2019 at 10:04 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Although its unnerving, the issue your having isn't unique to the Tundra. Toyota is low tech and "stuck' in the past because they perfect a a design model. That design becomes immensely reliable. This system is new and often has to be initially tweaked.
    So in closing, if the hard reboot through power loss didnt solve the issue, the dealer level scan tool will.
    Congratulations on your new and reliable Tundra
  17. Jan 16, 2019 at 10:24 AM
    Thunder68
    Thunder68 New Member
    Aaron
    2018 Tundra SR5 TRD4x4
    3.5 inch rough country lift, 295/70R18 cooper SST Pros, fuel wheels, Toyota predator steps, under cover tonneau cover.
    I own a 2018 tundra and same warning and icon came on when the truck had about 200 miles on it. I brought it to the shop and scanned it for codes, no codes present. Another tundra came into the shop for the same concern. That Tundra was scanned and no codes present. The tech started what's called a tas case and spoke with Toyota about the concern. Toyota said its normal and the pre collision system runs self diagnostic test randomly and when doing so causes the pre collision to illuminate and not operate until self test is complete. Snow, ice, rain, bugs, mud or anything else on the grill can block the sensor reading and also cause the pre collision to illuminate. I hope this information helps. By the way I've worked for a Toyota dealer for the past 18 years.
  18. Jan 16, 2019 at 10:38 AM
    Joe24
    Joe24 New Member
    Jose
    SJ, Puerto Rico
    2019 WHITE TRD SPORT
    My 2019 Tundra has 1,200 miles on it and the same message has been displayed once o a very rainy day.. The next morning good as new..
  19. Jan 16, 2019 at 10:46 AM
    WrongwayUp
    WrongwayUp New Member
    Andrei
    working on them.
    when i did my initial should i buy a tundra a few months ago, i spoke to a toyota mechanic about what stands out with new trucks coming in for repairs.... here in the DFW area... he said the main grill sensor (and not 100% sure I'm recalling the correct sensor here) in toyota safety sense... it was not like a whole bunch , its what stood out ... for whats that worth.
  20. Jan 16, 2019 at 10:51 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    and @ 46 degrees I doubt snow or ice would be a problem
  21. Jan 16, 2019 at 11:14 AM
    Cmckinney80
    Cmckinney80 New Member
    2018 MGM sport
    None
    The radar sensor for that is actually behind the emblem on the grill. The most common cause of that is dirt mud rain snow or bugs collecting on the emblem in the front of the truck.
    Morninwood[OP] likes this.
  22. Jan 16, 2019 at 11:54 AM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    What you're citing is, unfortunately, a fairly common refrain on this forum. I've gotten to the point where I just shut the PCS off before every trip. Not saying that that is the right approach; principled stance would be to make the dealership fix it, but I have zero faith that they dealers actually know what to do. There are a bunch of threads where the dealers just keep replacing sensors, IMHO hoping that the sensor replacement will fix the problem <-- it sounds to me like guessing as opposed to actual troubleshooting. Issue is in the design of the TSS, again IMHO.
  23. Jan 16, 2019 at 11:56 AM
    Rockanock
    Rockanock 21 Chevy 2500
    :boink:Should of bought a 2017
    TaquitoBandito and Y0TA PR0 like this.
  24. Jan 16, 2019 at 12:11 PM
    Morninwood
    Jerry
    Did that. same issue. Called Toyota and he said he's replaced several sensors.
  25. Jan 16, 2019 at 12:13 PM
    Morninwood
    Jerry
    No lift. Bone stock truck so far!
  26. Jan 16, 2019 at 12:17 PM
    Morninwood
    Jerry
    The day I bought it I got the warning, but it was sleeting. I understand that. Once everything melted it was fine. Its been doing this for three days now. Toyota dealer wants me to bring it in. *sigh*
  27. Jan 16, 2019 at 12:20 PM
    Morninwood
    Jerry
    Yup, that's what the tech told me, that there were several that had a "bad batch" sensor. What annoys me is that they can't order a new one until it is diagnosed first. 150 mile round trip x 2 to fix my brand new truck.
  28. Jan 16, 2019 at 12:25 PM
    Morninwood
    Jerry
    This guy seems to know whats really going on. He told me which sensor he had to replace and that it would take two hours to recalibrate it once it was replaced. I'll make an appointment and hope for the best!
  29. Jan 16, 2019 at 12:26 PM
    Steve89gt
    2018 Limited CM
    Please keep us posted. If you find a dealership that can actually implement some effective results, I'm sure that the other members of this forum that are nearby would appreciate the knowledge.
  30. Jan 16, 2019 at 12:36 PM
    AdyTexas
    AdyTexas New Member
    I had the same issue with mine at 400 miles. Took it in and they replaced the camera. It's been working great after that.
