Get snap back in seatbelts?
Discussion in '1st Gen Tundras (2000-2006)' started by HappyTrails, Jan 15, 2019.
  1. Jan 15, 2019 at 12:02 PM
    HappyTrails
    HappyTrails [OP] New Member
    2000 Tundra SR5
    None
    Any tricks for getting the seatbelt to quickly retract into its home again?
    Mountun Goat likes this.
  2. Jan 15, 2019 at 12:04 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Mine does it so fast that I have chips in my window tint from it smacking against the window.
    FirstGenVol likes this.
  3. Jan 15, 2019 at 12:11 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    OMG my wife’s nails/rings are innocent!
  4. Jan 15, 2019 at 12:23 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Spray this on your belt where it contacts the shoulder guide. Fully saturate the belt and operate it through its normal patterns so the product gets on the plastic guide as well. This product reaches its full slip AFTER it dries so do not expect miracles right away. You’ll have to wait till it dries. The Teflon action really spiced my belts back up. I did 3 separate individual soakings of the belt just to make sure.
    You can also remove the lower cover where the belt retracts and spray that area. One other thing, if all else fails, trim some plastic off the belt guide as it is very narrow and catches the belt hairs. You shouldn’t have to do it, but its an option.
  5. Jan 15, 2019 at 2:02 PM
    HappyTrails
    2000 Tundra SR5
    None
    I never thought about the belt and its friction as the culprit. Always thought it was the take up mechanism. Thank you!!
  6. Jun 15, 2019 at 5:41 PM
    TundraGarden
    TundraGarden New Member
    That doesn't rub off on your shoulder? I'm having the same issue. I saw a non Tundra you tube video of a guy totally removing the belt, washing it, and winding the mechanism a few more times to get it tighter, then reinstalling everything. I think my issue is the winding mech. I pulled out a bunch of belt to bypass the upper belt guide and it still retracts slowly. Driver and passenger.
  7. Jun 15, 2019 at 6:00 PM
    Fred
    Hand Protectors
    Do as I stated above. The PB Silicone with Teflon costs about $8. My belts work 95% better. Not like new, but very close. Whats to lose? If all else fails, then go the $uper expen$ive route with new winders.
    No it doesn’t rub off.
    pm07, marbleville and Mountun Goat like this.
  8. Jun 15, 2019 at 7:28 PM
    HappyTrails
    2000 Tundra SR5
    None
    Don't spray it right before you strap in. Coat it down at night or something and let it soak in. Depending on how bad it is you'll need to spray it a few times. Let it dry completely and the respray if needed, over the course of a few days. The belt will eventually get enough silicone in it that it snaps right back.
  9. Jun 15, 2019 at 8:48 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I was wondering this question yesterday! :popcorn:
  10. Jun 15, 2019 at 9:23 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    I use the same brand lube, but I would try - "dry lube with Teflon". I use it for a lot of stuff... Probably worth a try on this. Also epic for the inside of a safari land holster/holsters with mole skin type lining.
    Just buy a can. I was definitely not disappointed.
