Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Dec 17, 2018 at 4:40 AM
    #331
    briarpatch
    briarpatch New Member
    I've only used a Torq once.....belonged to a friend. Seems like a decent machine, but depending on the model, it doesn't match up well with the Griots 6" DA. The base Torq tops out at 4800 OPM, while the Griots tops out at 6800 OPM, and the Griots motor is 25% more powerful. When you combine this with the fact that the Griots comes with a lifetime warrranty and top-shelf customer service, I think the choice is clear. If you have a Pep Boys nearby, they're offering the Griots machine for 127.99, which Autogeek will price match. If that scratch removal kit you mentioned has the Chemical Guys 'V' line of polishes, I think you'll be disappointed in those products. I'm no CG hater, but their polishes leave a lot to be desired
  2. Dec 17, 2018 at 4:42 AM
    #332
    War Machine
    War Machine SSEM # 5 3MW
    Do you have a link to the specific Griots model you use?
  3. Dec 17, 2018 at 7:29 AM
    #333
    briarpatch
  4. Dec 17, 2018 at 8:15 AM
    #334
    War Machine
    Pudge likes this.
  5. Dec 17, 2018 at 8:20 AM
    #335
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Thanks for that info!
    That looks like a solid machine for sure. I'm not a CG fanboy, but do like some of their washing products. When I saw the 25% off deal on their site I went straight to the polishers, but wasn't sure. I'd rather buy something decent (for about the same price!) and get that much better results.
  6. Dec 17, 2018 at 9:22 AM
    #336
    I have the Porter Cable 7424XP and the Torq and think they are both good. I have used the Porter Cable alot more because I have had it for years.
    driverdog and War Machine like this.
  7. Dec 17, 2018 at 10:23 AM
    #337
    War Machine
    By the Griots and trade me.
  8. Dec 17, 2018 at 11:16 AM
    #338
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
  9. Dec 17, 2018 at 11:35 AM
    #339
    briarpatch
    Buy the 5" conversion kit and you can still use all of your 5" pads. I've switched to the Griots BOSS line of pads from the CG HexLogic quantums. I'll be trying some Lake Country pads next
  10. Dec 17, 2018 at 11:36 AM
    #340
    briarpatch
    CG has some kick-ass wash soaps.....Honeydew snow Foam for one. I use their P40 quick detailer, too
    War Machine likes this.
  11. Dec 17, 2018 at 11:57 AM
    #341
    War Machine
  12. Dec 18, 2018 at 1:23 PM
    #342
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Definitely swap to a 5" backing plate. It'll be better than buying all new pads and from pretty much all of my research, the 5" I'd the way to go. I have a harbor freight 6" but plan to upgrade soon, even if its just to a good 5" backing plate.
    I havent done much polishing but from what I have done, I really like the lake country pads, especially their HDO line. They really work well.
  13. Jan 2, 2019 at 9:45 AM
    #343
    FirstGenVol Brake Czar
    2002 AC
    So the early first gen Tundras are notorious for having "chalky" paint, especially the non metallic colors like white. Mine is having this issue. Initially I thought I could buff out the cloudy areas but I'm now realizing that's not a good idea. I guess the clear coat is gone in those areas.
    My question is, other than keeping it waxed is there anything else I can do to keep it from getting worse?
    Is the info in this thread good advice?
    https://www.autogeekonline.net/foru...le-stage-paint-toyota-tundra-chalky-much.html
  14. Jan 3, 2019 at 7:44 AM
    #344
    briarpatch
    Yes...look at post #5 and it's link to a post by Mike Phillips....Mike outline a process for bringing back single stage paints, which I'm guessing you may have on that 1st gen tundra
  15. Jan 8, 2019 at 11:59 AM
    #345
    2002 AC
    Follow up question on this. I tested Meguiar's #7 on a few panels this weekend. It gave the paint a richer/deeper look but didn't remove all the oxidation. I'm not familiar with Iron-X. It seems several companies offer some version of this. Is this the one to get?
    It sounds like I need to start over with Iron X followed by Meguiar's #7. After that, should I try wax and then polish or just stop at wax? The post by Mike Phillips was catered towards classic cars.
  16. Jan 8, 2019 at 12:34 PM
    #346
    War Machine
    I’m not an expert on getting rid of oxidation, but I’m not sure Iron-X is going to affect it. It’s for removing metal contamination in the paint. I’m guessing that it’s mentioned as part of the overall process of paint correction. (I may be completely wrong though.)
    That said, the one you linked is correct. I’ve tried a couple of different brands, but it’s by far the best.
  17. Jan 8, 2019 at 1:42 PM
    #347
    T-Rex266 [OP] Elon approved Staff Member
    Buddy wants to clean up his chrome on his Dodge. I had him start with an all purpose. Anything else?
  18. Jan 8, 2019 at 9:03 PM
    #348
    2000Strong
    2000Strong Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    Any tips for faded/peeling/chipping clear coat.
  19. Jan 9, 2019 at 9:20 AM
    #349
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    So I want to get a good, shiny finish on my Tundra, but I don't have the $$ to do ceramic coating.
    What are the next best process to do and products to use? And what is best to maintain it?
    SouthBoundSteve and War Machine like this.
  20. Jan 9, 2019 at 10:50 AM
    #350
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    I can only tell you what I do. I would obviously wash it. The next step is to clay bar. Then Polish by hand or I use a Griots DA Polisher with 5.5 pads. My personal favorite clay bar is Griots. I currently polish with M205 from Meguiars, but I am going to try Menzerna this year. I shine and wax twice a year. Hope that helps.
    bulldog93 and Fishman57[QUOTED] like this.
  21. Jan 9, 2019 at 10:57 AM
    #351
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    I think keeping it waxed and polished is the key. Twice a year is good start, Depending on sun/weather exposure maybe more. When I see less beading action I know its getting time.
  22. Jan 9, 2019 at 10:58 AM
    #352
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    wash it. clay it. compound with dual action buffer. polish with dual action buffer. toss on some Bead Maker and you'll be a happy Fishman
    Fishman57 likes this.
  23. Jan 9, 2019 at 10:59 AM
    #353
    Faht Nocker
    Woody
    Milky Way
    totally agree. I wax many times per year, at least once per month or so. The difference for me is that I only shine (polish) twice a year because of the colder (rainy) climate I am located.
  24. Jan 9, 2019 at 11:48 AM
    #354
    GravityGear
    Aurora, CO
  25. Jan 9, 2019 at 11:53 AM
    #355
    Faht Nocker
    Woody
    Milky Way
  26. Jan 9, 2019 at 12:32 PM
    #356
    GravityGear
    Aurora, CO
    I was looking at that one. The price point is a bit higher than what I would like to spend, but this kit is fairly reasonably priced. I do need some fat microfiber towels as I only have general purpose thin ones.
    https://www.amazon.com/Griots-Garag...qid=1547063419&sr=8-3&keywords=griots+da&th=1
  27. Jan 9, 2019 at 1:08 PM
    #357
    Faht Nocker
    Woody
    Milky Way
  28. Jan 9, 2019 at 1:10 PM
    #358
    GravityGear
    Aurora, CO
    Yeah, that's what I'm saying. Alone, it's a bit higher than my budget, but with the towels and sealant it's a bit more palatable, because I would still need to buy that stuff. I would still need pads and cutting compound and polish as well.
  29. Jan 9, 2019 at 1:13 PM
    #359
    Faht Nocker
    Woody
    Milky Way
    I see. I totally agree it is a lot to get setup. Once you do you are golden. I would call Griot's to make sure it is the same DA. I think that it is, but I don't know for sure. If it is go for it. I love that DA polisher for the price.
    these are great pads, but I use the 5 inch backing plate with 5.5 foam pads.
    https://www.amazon.com/Lake-Country...8&qid=1547068553&sr=8-6&keywords=lake+country
    https://www.amazon.com/Gray-Finishi...&qid=1547068553&sr=8-10&keywords=lake+country
  30. Jan 9, 2019 at 1:28 PM
    #360
    GravityGear
    Aurora, CO
    I was looking at the lake country or these. The Americana Global seems to be getting some good reviews from some detail heads. More heat dissipation I guess. They are also exact fit.
    http://americanaglobal.com/pads/6-inch-pads/
