Tundra Serious Off-roading Thread
Discussion in 'General Tundra Discussion' started by ColoradoTJ, Aug 23, 2016.
  1. Feb 16, 2017 at 6:41 AM
    #151
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    You won't need AC. Its 5400-7000 feet in elevation and mostly tree covered.
    And you can make it as hard as you want to. Lot of optional lines. IMO it should be a bucket list trail for any wheeler.
  2. Feb 16, 2017 at 6:53 AM
    #152
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    I agree with this wholeheartedly. Even if it's not extreme, the scenery and awesomeness of that trail make it great. Also, I hear the water levels are now insane due to all the water they got.
    Sunnier and ColoradoTJ[OP] like this.
  3. Feb 16, 2017 at 8:10 AM
    #153
    ColoradoTJ [OP] Certified tow LEO Staff Member
    LML 3500HD
    I was talking about the AC due to running down to Johnson Valley in August. That gets a little warm...LOL.
    I'll look into it. If we decide to stop off in Phoenix area and hit some of that hard core stuff, I would consider it.
    My TJ is a two seater right now with not a lot of storage space, as most jeeps don't. So a rack would have to be fabricated, rear seat added (not tough and have seat), buy and change out rear springs, buy new set of tires since mine are not DOT legal, I would risk the Beadlocks if I had to do any amount of pavement since there are so many fake beadlock wheels out there now. I would have to see if there are any laws against full hydraulic steering. CO and some of the other states I go to do not have anything on the books.
    So pretty much, my TJ is a trailer queen. I would have to do the rubicon forward and then backwards to get back to my truck and trailer, and spend 3000.00+ before I even left.
  4. Nov 29, 2017 at 1:15 PM
    #154
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    Has anyone had their frames notched and how effective and difficult is it? I found I've had my bed hit the cab, I'm guessing from the frame twisting? 20171127_162105.jpg 20171129_124658.jpg 20171127_162120.jpg
    Stormtrooper81 and dcsleeper408 like this.
  5. Nov 29, 2017 at 1:20 PM
    #155
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    :eek: ouch.
    trayday[QUOTED] likes this.
  6. Nov 29, 2017 at 1:29 PM
    #156
    jberry813
    Lake Tahoe
    Notched?
    The problem you are experiencing I refer to as the "Tundra Twerk."
    2 ply shit c-channel frame that flexes like crazy and allows for crumple zones.
  7. Nov 29, 2017 at 1:45 PM
    #157
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sexy...
  8. Nov 29, 2017 at 1:55 PM
    #158
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    How am I just seein this thread :thumbsup:
    Sunnier likes this.
  9. Nov 29, 2017 at 2:36 PM
    #159
    geno0506
    geno0506 New Member
    Michael
    LMAO
    Darkness and Marty McFly like this.
  10. Nov 29, 2017 at 3:12 PM
    #160
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Adding additional steel to the frame to make it thicker.
  11. Nov 29, 2017 at 3:14 PM
    #161
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    notched
  12. Nov 29, 2017 at 5:51 PM
    #162
    jberry813
    Lake Tahoe
    Uhh. That's notched because the truck was lowered via SUA. You don't need to notch the frame.
    You can however box the frame. Which is welding in a plate to the open section of the c-channel frame. And you may also plate the outsides of the frame.
    I did both on my old racetruck.
  13. Nov 29, 2017 at 6:00 PM
    #163
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Pics of racetruck?
  14. Nov 29, 2017 at 6:24 PM
    #164
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Mormon Wells Road, NV
    Cleaned the lights after staying by the fire til 1 am. Hit the car wash a day or two later. Truck is actually white under there. Haha
  15. Nov 29, 2017 at 6:53 PM
    #165
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Flint Trail switchbacks out to the Maze Overlook from Hans Flat. Completely stock except for tires. Nothing too crazy. Used 4Lo in a handful of places, but probably could have gotten by with 4Hi. Put a nice dent in my skid plate. I'm guessing I'd be fine now with a 3 in lift up front. There are a couple hairpin turns on the switchbacks with rock walls on both sides that make things interesting. My first time out there by myself, I panicked a bit on the way up trying to navigate one of these turns. Left some paint behind from the lower panel below the doors and would have tore up my steps if I didn't take them off beforehand. Made it through without a scratch on my second trip. Having a spotter makes things easier when navigating one particularly tight switchback. But yea, wouldn't recommend anyone waste their time heading down there. The scenery is horrible and it smells weird. Man, those plastic gas cans suck ass!
    13130832_10106241423848390_5755939313105_6e4a989a345183a483ceeed25011a5617b7c46bf.jpg
  16. Nov 29, 2017 at 8:42 PM
    #166
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I may need to have this done to prevrnt from happening again, could have been worse. What sections do you recommend having the extra plating?
  17. Nov 29, 2017 at 9:00 PM
    #167
    T-Rex266 Moderator Staff Member
    here you go.
    Baja Mike[QUOTED] and jberry813 like this.
  18. Nov 30, 2017 at 8:20 AM
    #168
    jberry813
    Lake Tahoe
  19. Jan 4, 2019 at 4:00 PM
    #169
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Wow over a year since the last post. Bump! Here's a little twist ditch I found on my way to go fishing.2018-09-03 16.50.46.jpg 20180820_155639.jpg
  20. Jan 4, 2019 at 7:13 PM
    #170
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Just keeping it alive and moving forward.
    MVIMG_20181020_145719.jpg 18671740_10155512505917122_1486507969345187482_o.jpg 44387833_175786093328152_1014360864590921728_n.jpg IMG_20180502_164248.jpg IMG_20180909_143800.jpg
  21. Jan 4, 2019 at 8:34 PM
    #171
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
  22. Jan 7, 2019 at 2:21 PM
    #172
    Wintersun
    Wintersun New Member
    With off-road use I care about the wheelbase, ground clearance, and overall height with respect to the center of gravity. Long beds and crew cabs are off the list. Lifted vehicles are plain dumb and I figure the higher the truck the lower the IQ of the owner. The rest depends on the skill of the driver.
    I photographed an event for the Hummer dealers in my area and there were dozens of owners running the trails and obstacle courses at a local off road park. Each section increased in difficulty and by #10 most drivers were spent. After watching all the Hummers with their locking differentials try 10 and getting to the bottom of the hill, I saw a family in a stock Suzuki Brute go down that same section with aplomb.
    Sunnier likes this.
  23. Jan 7, 2019 at 4:46 PM
    #173
    LML 3500HD
    Hell of a first post homie. In one single post, you insulted most on this forum with little practical experience. I would love to see you outwheel a mid travel build on 35’s with your stock truck.
    Not sure if you know this, but hummers can’t wheel for shit. I’ve wheeled with them, not impressed. Great troop transports, all around military use vehicle. Other than that...POS.
    In light of your awesome first post, enjoy a week of reply ban and think about if you want to be a contributing member on this site.
    15whtrd, Sunnier, jewsNbrews and 17 others like this.
  24. Jan 7, 2019 at 4:52 PM
    #174
    Lol. I guarantee there are Tundra owners here (actually I know multiple) who’s truck is lifted, and will make your IQ seem lower than Lil’ Wayne’s pants.
  25. Jan 7, 2019 at 5:41 PM
    #175
    lionix
    Gotta love great mods!
  26. Jan 7, 2019 at 6:52 PM
    #176
    Krezz
    Kevin
    LOLS!!!!
    Great way to wind down the night lol.
  27. Jan 7, 2019 at 7:33 PM
    #177
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I came for off-roading and saw a newb get owned haha. Works for me!
  28. Jan 8, 2019 at 6:04 AM
    #178
    jberry813
    Lake Tahoe
    I can’t wait to compare dicks and IQs with you!
  29. Jan 8, 2019 at 6:13 AM
    #179
    LML 3500HD
    Coffee time?
    Lol. Inside joke.....
  30. Jan 8, 2019 at 6:35 AM
    #180
    Notachickmagnet
    Notachickmagnet New Member
    :bowdown::bowdown::bowdown::bowdown::bowdown:
