Radio Issue
Discussion in 'Audio & Video' started by Dimbulb, Jan 2, 2019.
  1. Jan 2, 2019 at 5:12 PM
    Dimbulb
    Dimbulb [OP] New Member
    Hello,
    I have a 2016 Tundra 1794 Edition. I recently started up my truck and was met with the attached warning. 'New software is not compatible with this system'. I did NOTHING to this radio. There have been no modifications whatsoever. Upon some initial troubleshooting, I noticed that the error no longer shows up when the SD card is removed. The system clock is no longer visible on the radio screen at all.
    I took this to my dealer and they stated that I need to buy a brand new radio/head unit to the tune of $1200 to fix this. They claimed that there is a communication problem between the unit and the engine control unit. I am baffled. This appears to be a software issue, not a hardware issue.
    Currently, I am able to use the unit with the SD card out - I use Waze and dont use the navigation so Its not a terrible loss, however, the missing clock is a bit of an issue. Sure, I can look at my phone for the time, but it was super convenient having it on the head unit.
    Has anyone else run into this before? I am at a loss.
    Thanks in advance for any advice.
    ryanwgregg likes this.
  2. Jan 2, 2019 at 5:25 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    By chance did you change phones or anything? I'm curious here..
    Sounds like SD card or SD card reader might be a issue..
  3. Jan 2, 2019 at 5:28 PM
    Mike Tread lightly.
    south carolina
    Let me add this in a new one try this disconnect the battery for 15 minutes touch postive and negative together to dead out the caps in the truck and reconnect see if that helps.
  4. Jan 2, 2019 at 5:34 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    $1200?!!!
    Fishman57 likes this.
  5. Jan 2, 2019 at 5:36 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are you talking about the map card? I have the non-JBL, so I'm not knowledgeable on whether the JBL unit has an actual external SD card reader, separate from the map card reader. Have you went into the settings and manually set the time? If the map card is bad, it could bork the GPS time capabilities.
  6. Jan 2, 2019 at 5:57 PM
    18TRDSport
    18TRDSport New Member
    Western Mass
    2018 TRD Sport Sequoia in White
    Window tint, terrainContact AT tires, skid plate, less restrictive muffler and TRD air cleaner
    Also, Entune sucks
  7. Jan 2, 2019 at 7:06 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    ^^^^^^^^^^^^^. Agreed!
    I’m guessing you’re out of warranty. I’d never pay to fix it. You can get a new HU much better HU for less than that.
    bobbywesley12 likes this.
  8. Jan 2, 2019 at 7:39 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    If you're leaning toward a replacement OEM head unit I would shop around on here or eBay for a used OEM unit. Lots of people upgrade the JBL Entune HU and they come up for sale pretty regularly.
  9. Jan 2, 2019 at 8:53 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I believe it. When I was buying my truck they wanted me to buy the extended technology warranty and told me a new radio costs around 2-3k :rofl::rofl:
    JoshuaA[QUOTED] likes this.
