ESP Plastic storage Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by Norfolk757, Jun 9, 2018.
  1. Dec 19, 2018 at 10:09 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
  2. Dec 19, 2018 at 10:14 PM
    SiberianTundra
    Greg
    War Machine
    You place the carpet you cut out at bottom of the bins and it keeps the noise down. I will take a picture and post it tomorrow.
    AlmightyCrash likes this.
  3. Dec 19, 2018 at 10:37 PM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    I tell people to use the carpet they cut out, and line the bottom of the boxes with it. It is made from ABS plastic, so if there is something hard sitting in the compartment, it could rattle. Not any way around it without lining it.
    nk1794 likes this.
  4. Dec 20, 2018 at 5:13 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have the cut-out carpet in there as a liner, and I keep some microfiber rags in there also so the hard tools that I have in there are nestled in the cloth so they do not rattle. If you through a hand full of wrenches in there without the carpet liner I am sure it will rattle.
    nk1794 and AlmightyCrash[QUOTED] like this.
  5. Dec 20, 2018 at 7:27 AM
    Norfolk757
    Norfolk757 [OP] עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Like @Boerseun mentioned, the cut out of the carpet will prevent things from rattling around. I have not had any issue with noise or space.
  6. Dec 20, 2018 at 9:53 AM
    ejd049
    ejd049 New Member
    2018 Tundra Crew Max TRD Off Road 4X4
    Thanks, going back and fourth on this one or the long box.
  7. Dec 20, 2018 at 10:02 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
  8. Dec 20, 2018 at 10:22 AM
    War Machine
    War Machine SSEM # 5 3MW
    whodini12 and Norfolk757[OP] like this.
  9. Dec 20, 2018 at 2:33 PM
    Norfolk757
    Tom
    Norfolk, VA
    I had to remove mine and just bought the Husky ones for the back that did not go all the way under the seats. I did not want to cut in to it so I sold it online and got the new Mats.
  10. Dec 20, 2018 at 9:44 PM
    havasubud
    Earl
    Corona, California
    If you need locking storage or feel you will have the need in the future, I would go ahead and get it now. It will save you time and money since you won't be buying two different parts and having to redo the install. Easier to cut it once than have to do it later and take more out.
  11. Dec 23, 2018 at 4:51 AM
    Ubnpast
    Ubnpast New Member
    I put a towel in mine for some ratchet straps and trailer lug wrench, no noise here.
    AlmightyCrash[QUOTED] likes this.
  12. Dec 26, 2018 at 3:13 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I just did this mod- very pleased. It took one hour after reading the install threads here. I thought the template was effective. I trimmed my carpet scraps and fitted them in the bottoms. I don’t hear anything.
    Merry Christmas to me! Again- great solution if you don’t need a long space. Note I have a small combination vault in mine, so you can still use this to achieve some security. 4190CFF5-3C67-477E-ABC3-A9B26F4C560F.jpg
    TUNDRA375 and Boerseun like this.
  13. Dec 26, 2018 at 4:45 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Really like your mod looks great
  14. Dec 30, 2018 at 12:33 AM
    Elk34
    Elk34 New Member
    Paul
    2019 Tundra TRD Pro
    Tell me about the combination vault. Is it attached to the box or just loose?
    I installed my esp storage today. It went pretty well. I didn't realize that the box wasn't symetrical. I thought each side would be equal but it's not so make sure you have the template right side up. I almost made a mistake. I also cut out the template areas around the middle two seat bracket bolts because that makes the template sit better. Also when cutting through the foam, it isn't all one thickness as there are thicker reinforced lines on the underneath of the foam and those areas are harder to cut through and the linoleum knife doesn't really make it all the way through. I put the foam backing that you separate from the carpet in the hole and then cut the carpet to fit in the boxes. And I used some pieces of duct tape to hold the template in place. The boxes are dog eared so you need to cut the carpet pieces with dog eared corners to fit cleanly in the container.
  15. Dec 30, 2018 at 7:26 PM
    MJ_19Tundra
    MJ_19Tundra Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Has anyone made their own boxes and installed? Thinking about making a large wood box for half the side if the truck then installing sub on other side. Or sub in the middle and two boxes on each side....
    Thoughts?
    Norfolk757[OP] likes this.
  16. Dec 31, 2018 at 6:28 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    After looking at how easy you made it look I decided to order one. It should be in this weekend. Hopefully I can get it installed this weekend.
  17. Dec 31, 2018 at 6:35 PM
    SilverandScout
    SilverandScout New Member
    I installed my plastic ESP on Saturday. I used my oscillating tool and it worked great. Very little dust and easy to vacuum up. I trimmed the carpet pieces and lined the tubs. No rattles and no noise. Easy and useful mod.
  18. Jan 1, 2019 at 12:58 PM
    panicman
    Eric
    The vault is attached to the back seat frame with a coated steel cable. Of course, someone could just cut the cable with bolt cutters... so I wouldn’t recommend it as a permanent storage solution for anything precious.
    You could figure out a few ways to make it more secure, like drilling through the box, storage bin, and floor of the truck and use short carriage bolts, large washers, and nuts to secure it.
    I just use it for temp storage.
  19. Jan 29, 2019 at 5:42 PM
    TUNDRA375
    GA
    I installed it this weekend. It was super easy took about 30mins great addition.
    Boerseun likes this.
  20. Dec 3, 2019 at 12:55 AM
    #50
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Mine is on its way. Thanks for posting the tips and install
  21. Dec 3, 2019 at 5:47 AM
    #51
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Where are you guys purchasing this from, ESP direct?
  22. Dec 3, 2019 at 7:51 AM
    #52
    d4ivg3i2j
    d4ivg3i2j New Member
    J
    Does anyone know if you can cut one large, long compartment or are there hidden supports/bumps that would prevent this?
  23. Dec 3, 2019 at 8:43 AM
    #53
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
  24. Dec 3, 2019 at 8:44 AM
    #54
    d4ivg3i2j
    J
  25. Dec 3, 2019 at 10:56 AM
    #55
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Joss1799 likes this.
  26. Dec 3, 2019 at 2:04 PM
    #56
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    I understand the smart key system on 2020's utilizes some of the space under the carpet in some or all of this area. Has anyone braved trying to install these in a 2020 yet? Curious to see if there is a reasonable work around to install these since the Tundra has less storage space than my Tacoma did.
  27. Dec 3, 2019 at 2:24 PM
    #57
    AdventureAddict
    AdventureAddict New Member
    Josh
    19 Cement Limited TRD off road
    I have the standard under seat storage on my double cab and always thought it didnt make sense it wasnt on the crewmax. Good to hear theres a solution!
  28. Dec 7, 2019 at 2:30 PM
    #58
    Boerseun
    Ferdie
    Sarasota Florida
    Yes, you can have one long compartment. ESP actually makes one like that also. The front edge will be straight through, but the back may be interrupted by the seat bases, depending on how deep to the back you want to cut them.
  29. Dec 7, 2019 at 2:38 PM
    #59
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    The ESP kit provides new braces because the stock ones run all the way out to the front, IIRC. In the plastic 3 bin model the seat braces are in between each bin. You cannot just cut one large hole without changing the seat brackets.
    Boerseun[QUOTED] likes this.
  30. Dec 7, 2019 at 3:55 PM
    #60
    Boerseun
    Ferdie
    Sarasota Florida
    Correct. It is possible but will be more than just cutting the carpet and styrofoam.
    GODZILLA[QUOTED] likes this.
