Ran out of Gas
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Apr 16, 2018.
  1. Apr 16, 2018 at 8:03 AM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Well I ran out of gas in the Tundra...
    Funny thing is the gas gauge was just slightly below the "1/4 mark".
    The miles to empty was at 17.
    I tried to start after sitting for a few minutes but it just sputtered.
    Luckily, I was in a residential area, when I ran out.
    I wont let it get below 1/4 again, normally I don't anyway.
  2. Apr 16, 2018 at 8:10 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Wow. Right below the 1/4 mark. Never would have guessed that.
    BuckWallace and NewImprovedRon like this.
  3. Apr 16, 2018 at 8:12 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Now you know.........
    Does seem a bit off.
  4. Apr 16, 2018 at 8:15 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Maybe ur the float in the sending unit is going out and isnt reading properly
  5. Apr 16, 2018 at 8:33 AM
    I would think the same thing.
    Not the first time I’ve seen a fuel gauge tank level sending unit fail on a Tundra.
    I used to go off miles on my Tundra over the gauge due to that very thing.
    TheBeast and kenomouth64[OP] like this.
  6. Apr 16, 2018 at 8:37 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    So much for the fuel light:notsure:. What's the reserve mileage in our Tundras, 25 miles. I have been living on the edge.:eek:
  7. Apr 16, 2018 at 8:38 AM
    n2deep
    n2deep Pavement Princess
    Fuel Sending unit is bad. Had the same thing and Toyota replaced under warranty.
    Ran out of gas with a little under 1/4 tank and the light hadn't come on yet.
  8. Apr 16, 2018 at 10:41 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I went about 8 miles yesterday on 0 miles remaining & just above the line of E. It took 22 gallons.
  9. Apr 16, 2018 at 10:45 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That blows.. I’ve ran my tundra to 0miles and back to work and home .. usually after you have 0 miles left, it still has at least 4 gallons.. better start carrying a gas can :annoyed:
    DalTee and kenomouth64[OP] like this.
  10. Apr 16, 2018 at 10:45 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have run mine twice down to zero miles left and have never put more than 31.5 gallons in the tank. Gauge was even with the e line both times.
    Jsena likes this.
  11. Apr 16, 2018 at 10:46 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Better have them check out the gauge.. cause it shouldn’t run out like that
  12. Apr 16, 2018 at 12:06 PM
    kenomouth64
    Tetrus
    I agree, I am guessing that it is the fuel sending unit. I filled the truck and it took, 27.5 gallons, it was above the full mark. I then drove around 10 city miles and it was already saying I was down to 3/4 of a tank left. I checked under the truck to make sure i did not have a hole in the tank, lol. It is odd, just this morning it was showing just slightly below full, while yesterday it was at the 3/4 mark.
    I guess I am going to buy a jerry can and mount it in the back somewhere for now.
  13. Apr 19, 2018 at 2:39 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    That’s gangster!!!
    Bump you fuel gauge - I’ll do as I please
    :transformer:
    I’m not the one to be stuck on the side of I-91 uh uhhh!
    Jsena[QUOTED] likes this.
  14. Oct 9, 2018 at 4:17 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I once (stupidly perhaps) tested mine on the way home from a job site 40 miles away, shortly after buying my truck. My 2010 doesn’t have a “miles to empty” display so I just used the gauge. It started on the line below E and went about 1/8” lower after a few miles and stayed there the rest of the way home. I think I put like 23 gallons in it when I next filled it. Since then I just record the odometer at fill-ups because I don’t trust that gauge.
  15. Oct 9, 2018 at 5:11 AM
    trdprobped17
    trdprobped17 New Member
    I think that there is something wrong with your fuel gauge, if you ran out of gas with the indicator showing just below 1/4 tank. I have driven 20 miles on “E” all the time and never ran out of gas. The amber light (empty) always come on in truck before my fill-ups. Check your fuses and replace them all, and if that doesn’t work, take it to the dealership.
  16. Oct 9, 2018 at 5:46 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    The level instrumentation on a typical gas tank isn't going to be the most accurate anyway. Precision detectors (like a linear level differential transformer) or the use of multiple level detectors to compensate for pitch and roll are expensive and are unnecessary in such an application.
    trdprobped17 likes this.
  17. Oct 9, 2018 at 5:57 AM
    trdprobped17
    A what and a who?? Yup, what he just said....I’m with him :)
    NewImprovedRon likes this.
  18. Dec 26, 2018 at 5:30 PM
    avt007
    avt007 New Member
    Rob
    2010 Silver Tundra Double Cab
    My 2010 had the low level light come on just above zero, showing 20 miles to empty. I drove until it ran dry, 72 miles later. When the gauge was at zero, and o miles to empty, I still went 55 miles, so at least on mine, there's plenty of gas left at "empty". Total distance on the tank was 352 miles. And BTW, when it runs out, it dies then and there. No stumbling to the nearest gas station, it pretty much just shut off.
  19. Dec 26, 2018 at 6:39 PM
    FXFormat
    FXFormat New Member
    Yeah that float in your fuel pump is probably stuck at the 1/4 mark. I usually fill up around 200 miles mark, that's nearing the end of the tank anyways. This truck is a camel, thristy AF.
    15whtrd likes this.
  20. Dec 27, 2018 at 4:41 AM
    BlackSheep
    Scott
    Kansas City, MO
    Update on mine: about a month ago I ran out of gas when I thought there was no way I was near empty. I only got like 25 miles once the low fuel light turned on. So apparently if my tank float gets stuck it doesn't happen in the same place each time. I was hoping I was getting really good mileage all of a sudden but that was a mistake. Should have trusted a year's worth of mpg data. Now I really don't trust my gauge.
