06 Double cab rear brakes
Discussion in '1st Gen Tundras (2000-2006)' started by spiderrey, Dec 22, 2018.
  1. Dec 22, 2018 at 9:09 AM
    spiderrey
    spiderrey [OP] New Member
    rey
    06 Double cab
    Bilstien 3 n 1 inch lift with a bed cap
    My truck has 204,000 miles. Rear brakes have never been done. I am about to do them this weekend. I will search a you tube video on it. Is there anything specific that I should know from people that have done this before?
  2. Dec 22, 2018 at 9:33 AM
    15whtrd
    15whtrd Mr. Blonde
    Drums or rotors? Either way might as well replace everything if they’ve never been done. Also I’m sure it’s time for a fluid exchange/flush.
  3. Dec 22, 2018 at 9:34 AM
    Casper421
    In the woods
    06 DC
    Buy lots of brake cleaner and a mask. Wear gloves. Don’t breathe in the brake dust that’s in the drums. Did you buy new hardware or just shoes and drum? Might want to buy a wheel cylinder or two just in case.
    15whtrd likes this.
  4. Dec 22, 2018 at 10:47 AM
    spiderrey
    rey
    06 Double cab
    Planning on buying all NEW parts. I know about the bad dust. Done lots of brakes before, but haven't done drums in ages. Just watched a video. Going out for the parts now. Appreciate all advice. Hopefully Ill get to timing belt next week.
    Casper421 likes this.
  5. Dec 23, 2018 at 1:12 PM
    Does someone make a parts kit for the drums or is everything purchased individually?
  6. Dec 23, 2018 at 1:46 PM
    Casper421
    In the woods
    06 DC
    15whtrd likes this.
  7. Dec 23, 2018 at 2:49 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I used this one on mine
    https://www.amazon.com/ACDelco-18K544-Professional-Adjuster-Return/dp/B000C9G7JM
    You may want to have new bell cranks on hand in case you need them too.
    https://www.amazon.com/dp/B00C0UAABW/ref=cm_sw_r_cp_apa_i_UcbiCb0W5N3VE
  8. Dec 23, 2018 at 4:36 PM
    spiderrey
    rey
    06 Double cab
    I went to O Rielly's bought Brake Best shoes, drums n hardware kit. haven't started yet due to xmas shopping.
  9. Dec 23, 2018 at 4:51 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    take a picture of the rear brakes so you know how it goes back together
    mtntop likes this.
  10. Dec 23, 2018 at 4:55 PM
    spiderrey
    rey
    06 Double cab
    Thank you for the advice. I Have a video that shows step by step uninstall and install. I pause and rewind when necessary.
  11. Dec 23, 2018 at 5:01 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    now would be a good time to do a rear disk brake conversion if you got the money. a big improvment. go to sos performance .com, or tundra racing.com
  12. Dec 23, 2018 at 6:08 PM
    spiderrey
    rey
    06 Double cab
    how much does that run?
  13. Dec 23, 2018 at 6:11 PM
    spiderrey
    rey
    06 Double cab
    38D3828A-63B8-4107-998F-D5F2B23F6C2C.jpg 8698A42A-7202-4D34-A9B4-B6CEFFA54B72.jpg Just pulled off drivers side. Real easy useing two 8 x 1.25 bolts. No lining left in the middle at all.
    Rheywood456 likes this.
  14. Dec 23, 2018 at 9:57 PM
    Yeah, that looks bad. When I finally get to mine I'll put pics up. I'm sure it's full of diff juice.
  15. Dec 24, 2018 at 6:12 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    i cant remember how much. go to the website and check it all out. i purchased the caliper brakets/hardware only, without the parking brake provision. i purchased power stop upgraded calipers,disk pads and drilled/slotted rotors.from summit racing.you can call s.o.s performance and talk to them about your options
  16. Dec 24, 2018 at 5:09 PM
    spiderrey
    rey
    06 Double cab
    All done. Should have taken a pic before I closed them. The brake best hardware kit was a waste. Most parts didn’t fit. Just need to adjust them tommrow.image.jpg
  17. Dec 25, 2018 at 6:43 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Did you end up reusing the existing hardware? How is your parking brake operation?
  18. Dec 25, 2018 at 9:38 AM
    spiderrey
    rey
    06 Double cab
    The only new hardware that I was able to use were the long springs and the locking clips. other parts didn't match. I still need to adjust the shoes this morning and toss the wheels back on. Everything that was reused was cleaned and checked. I will let you know about the parking brake when I test it.
  19. Dec 25, 2018 at 2:27 PM
    spiderrey
    rey
    06 Double cab
    So I adjusted the shoes. parking brake doesn't work, it never really worked before. It looks like I need to adjust the parking brake cable still.
  20. Dec 25, 2018 at 2:29 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Are the bell cranks moving freely and are the secondary cables inside the drums in good shape?
  21. Dec 27, 2018 at 5:26 PM
    spiderrey
    rey
    06 Double cab
    Brakes weren't adjusted properly. I adjusted them again. Parking brake works fine now.
