06 Double cab rear brakes
Discussion in '1st Gen Tundras (2000-2006)' started by spiderrey, Dec 22, 2018.
  1. Dec 22, 2018 at 9:09 AM
    spiderrey
    spiderrey [OP] New Member
    rey
    06 Double cab
    Bilstien 3 n 1 inch lift with a bed cap
    My truck has 204,000 miles. Rear brakes have never been done. I am about to do them this weekend. I will search a you tube video on it. Is there anything specific that I should know from people that have done this before?
  2. Dec 22, 2018 at 9:33 AM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Drums or rotors? Either way might as well replace everything if they’ve never been done. Also I’m sure it’s time for a fluid exchange/flush.
  3. Dec 22, 2018 at 9:34 AM
    Casper421
    Casper421 Adventure in a 1st gen
    In the woods
    06 DC
    Buy lots of brake cleaner and a mask. Wear gloves. Don’t breathe in the brake dust that’s in the drums. Did you buy new hardware or just shoes and drum? Might want to buy a wheel cylinder or two just in case.
    15whtrd likes this.
  4. Dec 22, 2018 at 10:47 AM
    spiderrey
    rey
    06 Double cab
    Planning on buying all NEW parts. I know about the bad dust. Done lots of brakes before, but haven't done drums in ages. Just watched a video. Going out for the parts now. Appreciate all advice. Hopefully Ill get to timing belt next week.
    Casper421 likes this.
  5. Dec 23, 2018 at 1:12 PM
    FirstGenVol
    FirstGenVol New Member
    Erik
    TN
    2002 SR5 4x4 AC
    ICON, SPC UCA's, SCS Ray 10's
    Does someone make a parts kit for the drums or is everything purchased individually?
  6. Dec 23, 2018 at 1:46 PM
    Casper421
    In the woods
    06 DC
    15whtrd likes this.
  7. Dec 23, 2018 at 2:49 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I used this one on mine
    https://www.amazon.com/ACDelco-18K544-Professional-Adjuster-Return/dp/B000C9G7JM
    You may want to have new bell cranks on hand in case you need them too.
    https://www.amazon.com/dp/B00C0UAABW/ref=cm_sw_r_cp_apa_i_UcbiCb0W5N3VE
  8. Dec 23, 2018 at 4:36 PM
    spiderrey
    rey
    06 Double cab
    I went to O Rielly's bought Brake Best shoes, drums n hardware kit. haven't started yet due to xmas shopping.
  9. Dec 23, 2018 at 4:51 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    take a picture of the rear brakes so you know how it goes back together
    mtntop likes this.
  10. Dec 23, 2018 at 4:55 PM
    spiderrey
    rey
    06 Double cab
    Thank you for the advice. I Have a video that shows step by step uninstall and install. I pause and rewind when necessary.
  11. Dec 23, 2018 at 5:01 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    now would be a good time to do a rear disk brake conversion if you got the money. a big improvment. go to sos performance .com, or tundra racing.com
  12. Dec 23, 2018 at 6:08 PM
    spiderrey
    rey
    06 Double cab
    how much does that run?
  13. Dec 23, 2018 at 6:11 PM
    spiderrey
    rey
    06 Double cab
    38D3828A-63B8-4107-998F-D5F2B23F6C2C.jpg 8698A42A-7202-4D34-A9B4-B6CEFFA54B72.jpg Just pulled off drivers side. Real easy useing two 8 x 1.25 bolts. No lining left in the middle at all.
    Rheywood456 likes this.
  14. Dec 23, 2018 at 9:57 PM
    bmf4069
    bmf4069 New Member
    TX
    02 AC sr5 4wd v8
    Yeah, that looks bad. When I finally get to mine I'll put pics up. I'm sure it's full of diff juice.
  15. Dec 24, 2018 at 6:12 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    i cant remember how much. go to the website and check it all out. i purchased the caliper brakets/hardware only, without the parking brake provision. i purchased power stop upgraded calipers,disk pads and drilled/slotted rotors.from summit racing.you can call s.o.s performance and talk to them about your options
  16. Dec 24, 2018 at 5:09 PM
    spiderrey
    rey
    06 Double cab
    All done. Should have taken a pic before I closed them. The brake best hardware kit was a waste. Most parts didn’t fit. Just need to adjust them tommrow.image.jpg
  17. Dec 25, 2018 at 6:43 AM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Did you end up reusing the existing hardware? How is your parking brake operation?
  18. Dec 25, 2018 at 9:38 AM
    spiderrey
    rey
    06 Double cab
    The only new hardware that I was able to use were the long springs and the locking clips. other parts didn't match. I still need to adjust the shoes this morning and toss the wheels back on. Everything that was reused was cleaned and checked. I will let you know about the parking brake when I test it.
  19. Dec 25, 2018 at 2:27 PM
    spiderrey
    rey
    06 Double cab
    So I adjusted the shoes. parking brake doesn't work, it never really worked before. It looks like I need to adjust the parking brake cable still.
  20. Dec 25, 2018 at 2:29 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Are the bell cranks moving freely and are the secondary cables inside the drums in good shape?
  21. Dec 27, 2018 at 5:26 PM
    spiderrey
    rey
    06 Double cab
    Brakes weren't adjusted properly. I adjusted them again. Parking brake works fine now.
