1st Gen General Questions
Discussion in '1st Gen Tundras (2000-2006)' started by FlightSimGuy, Nov 21, 2018.
  1. Dec 13, 2018 at 9:10 AM
    Casper421
    In the woods
    06 DC
    Sounds like a bad relay.
  2. Dec 13, 2018 at 10:27 AM
    FlightSimGuy
    FlightSimGuy [OP] New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    Kinda what I'm thinking.
  3. Dec 13, 2018 at 2:10 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Went out and checked the 02’ after us talking about the DTR RELAY (thats how its labeled in my fuse box). Wasn’t able to pull it out. Looks like a special puller tool needed? To depress those white tabs (2 on each side)?
    My year 02’ is made to run DTR with no ability to control. No problems, but just curious.
    Went ahead and pushed down all those big box fuses as some were wiggly.
    Anyhow, that lead me to checking all my other fuses (see What Have You Done section).
    FlightSimGuy[OP] likes this.
  4. Dec 14, 2018 at 9:14 AM
    My drls run all the time too. It's normal.
  5. Dec 14, 2018 at 11:00 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I had to look into this for myself. I've got an '05 and here's what I get.
    With this,
    I get this,
    With this,
    I get this,
    With this,
    I get this,
    Sunnier and FlightSimGuy[OP] like this.
  6. Dec 14, 2018 at 1:37 PM
    Looks about right.
  7. Dec 14, 2018 at 1:40 PM
    Casper421
    In the woods
    06 DC
    I don’t see a difference in the last two pics.
  8. Dec 14, 2018 at 1:42 PM
    There's a leaf on the sidewalk in the last one.
    ColumbiaGorge, seth419 and Sunnier like this.
  9. Dec 14, 2018 at 1:50 PM
    FlightSimGuy
    Definitely a time lapse happening. :D
    Look at the switch position, yet the lights don't change. Same thing my truck does.
  10. Dec 14, 2018 at 1:53 PM
    Casper421
    In the woods
    06 DC
    I don’t believe the “off” position should have any lights on.
  11. Dec 14, 2018 at 1:54 PM
    FlightSimGuy
    Same. That's why I'm going to check my relays. When I get time...
  12. Dec 14, 2018 at 2:14 PM
    Fred
    Hand Protectors
    Hahahaha!!!
  13. Dec 14, 2018 at 2:24 PM
    Fred
    Hand Protectors
    I like the DTR’s for safety. They are a normal function on my 02’. They are the high beams burning at half power and turn on and off with the ignition key.
    Was researching this a bit last night for you newer gen 1st gen’rs. Shoulda took a screen grab of the instructions, but this commenter guy said you can take out the relay fuse(s) and snip some connection(s) inside relay and that will alter your light controls.
    Sounded interesting. It was on fixya.com
    Do your research and see where it takes you.
    BTW, how are these relay fuses removed? I pulled and wiggled and felt like they were going to break. Seems like a special tool is needed to depress all those 4 clips at one time so the fuse will ‘unlock’.
    Also, I find it strange that no info is available anywhere on removal of these. Stealership ploy?
  14. Dec 14, 2018 at 3:21 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    It doesn't look like the picture relays reality perfectly but, with the switch in the lights "on" position, the lights are a bit brighter. Now that I go back and forth, quickly, between the pictures, you can appreciate the lights are a bit brighter in the last picture.
  15. Dec 14, 2018 at 3:24 PM
    Fred
    Hand Protectors
    Those lights are DTR in OFF position (half power). Lights in ON are full strength. He has DTR.
  16. Dec 15, 2018 at 8:16 AM
    Fred
    Hand Protectors
  17. Dec 15, 2018 at 12:47 PM
    FlightSimGuy
  18. Dec 15, 2018 at 1:23 PM
    Fred
    Hand Protectors
    Just went through this a few months ago when tire store lost my key years ago and I was there getting new tires and they couldn’t find the key. Prior guys forgot toput key back. Good thing I never had a flat!
    New key is hard to find. Best to buy the combo set ($50 at stealer). Tirestore paid for mine.
    Trick to this is getting the old cup off. I used a plumbers under sink adjustable wrench with some arm yoga to reach around tire and SLOWLY was able to spin it off. You can remove key cup, but then you are vulnerale to theft.
    Can you find original key?
  19. Dec 15, 2018 at 1:26 PM
    Fred
    Hand Protectors
  20. Dec 15, 2018 at 1:29 PM
    #50
    Fred
    Hand Protectors
    This is the fun part. Hope you have long arms.
    NUDRAT and FlightSimGuy[OP] like this.
  21. Dec 15, 2018 at 1:32 PM
    #51
    FlightSimGuy
    Thanks! You da man! :cheers: Good illustrations too. :D So I need to turn that whole assembly off. I'll try a pipe wrench and maybe a large pair of pliers. Looks fun. o_O
    Sunnier likes this.
  22. Dec 15, 2018 at 1:37 PM
    #52
    Fred
    Hand Protectors
    You need the ‘Under Sink Adjustable Wrench’. The kind for tight places. It has spring clamping action on the business end. Can be reversed so it tightens or loosens. Handle has adjustment as well.
    Angle of attack is to sit up on ground looking at bumper hole at the key. Reach in with wrench and ‘feel’ the bite on the backside of that cup. Turn to loosen and once you get it halfway down, abandon the wrench and use your hands.
    You look for key under the back seat in the tire changing pouch? Glove box?
  23. Dec 15, 2018 at 1:39 PM
    #53
    FlightSimGuy
    OK, I'll see if I can find one. I've looked all over and I'm guessing it wasn't with the truck when I bought it.
  24. Dec 15, 2018 at 1:41 PM
    #54
    Fred
    Hand Protectors
    If its not in the truck, forget about ‘finding one’ online. You’ll have to buy a kit withthe cup key combo. Tire store couldn’t figure any of this problem out that they created. Took them 3 tries and couldn’t connect the dots. I had to take over otherwise it wouldn’t get done.
  25. Dec 15, 2018 at 4:03 PM
    #55
    Sunnier
    Sunny
    San Diego, CA
    @Professional Hand Model this is one of the coolest how-to sequences I've seen on this forum! It rivals the full how-to threads posted up, yet you did it to answer one guy's question. You're a good guy!
    :fistbump:
  26. Dec 15, 2018 at 4:09 PM
    #56
    Fred
    Hand Protectors
    Thanks. This forum has helped me very much and I’m just trying to give back. I’ve saved tons of money and time on DIY from advice here. Getting back to my roots by helping others as much as possible. Thanks for the recognition.
  27. Dec 15, 2018 at 4:51 PM
    #57
    FlightSimGuy
  28. Dec 15, 2018 at 5:01 PM
    #58
    Fred
    Hand Protectors
  29. Dec 16, 2018 at 6:56 AM
    #59
    FlightSimGuy
    Well, I got the tire down. For anyone with this issue I was able to do it with a pair of "plumbing" pliers. I could actually sit under the tire and reach around it.
    How do I get the cup/device off? Spare tire theft isn't exactly rampant here.
  30. Dec 16, 2018 at 9:06 AM
    #60
    Fred
    Hand Protectors
    Twist and pull. Might be corroded locked so give it a few taps and pull it straight out/off.
