Ugh, Secondary Air Pump Strikes Again
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Jul 26, 2016.
  1. Jul 26, 2016 at 10:44 AM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Great, got CEL (Check Engine Light) the other day and indicated the other pump went out. And this morning my truck was in limp mode. Just ordered the parts and will be doing this fix this weekend. $400 in parts this time but still coming out ahead compared to the $2000 the dealership wanted.
    If anyone would like a write up let me know. I will be using the Chilton Manual procedures that I have previously posted.
    And if anyone lives in the Houston, TX area and would like to earn a couple of free beers let me know. It goes faster with help.
    Ancient1, driverdog, Law323 and 3 others like this.
  2. Jul 26, 2016 at 10:50 AM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    I would have done the bypass on it.. personally..
  3. Jul 26, 2016 at 11:04 AM
    I would glady help you (to learn) if I lived in your area.
    driverdog and 2cID like this.
  4. Jul 26, 2016 at 11:08 AM
    I agree, but if you did any updates on this system via recall, you're screwed on the bypass working.
  5. Jul 26, 2016 at 11:10 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    We are in development of an intake relocation kit for the secondary pump. We should have something available shortly for you guys!
  6. Jul 26, 2016 at 11:15 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm sure the DIY would he helpful. I heard the job is a pain.
    Do you guys know when they updated the trumpets on new Tundras for sale? I'm wondering if my 14' has the updated parts...
  7. Jul 26, 2016 at 11:34 AM
    :popcorn:
  8. Jul 26, 2016 at 11:37 AM
    Nor7
    Yeah, yours should have the new parts, they started using the new parts in some of the 2012 models. But all of us 2011 guys are hung out to dry, Toyota only is taking care of the '07 to '10 tundras.
  9. Jul 26, 2016 at 11:38 AM
    Nor7
    Considered it but I heard of it causing other issues and throwing ECM codes. With my luck with electronics I wouldn't pass my next emission test.
  10. Jul 26, 2016 at 11:41 AM
    Nor7
    For everyone's benefit, the reason I pursued replacing the parts with new ones instead of the bypass: I figured since the original parts lasted over 100k miles, the new ones should easily last another 200k to 300k miles since I also put in the new air intake hose that has a guard on it to prevent water ingress.
    I'll take some pics and try to do a write up but it won't be much better than the Chilton Manuals. Also, I have the 4.6 engine which makes the job alot easier in comparison to the 4.7 models.
    Chilton Manuals Attached.
    driverdog and Law323 like this.
  11. Jul 26, 2016 at 11:45 AM
    David2013Tundra
    David2013Tundra New Member
    2013 Tundra DC 5.7
    Sub'd.
    Definitely want to see the write up.
  12. Jul 26, 2016 at 1:21 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Thanks for the info. That doesn't make any sense Toyota :facepalm:.
  13. Jul 26, 2016 at 2:55 PM
    Mike Tread lightly.
    south carolina
    Different suppliers..
  14. Aug 12, 2016 at 3:58 PM
    sdhq_offroad
    GILBERT, AZ
