What Add - a - Leaf kit?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Nov 20, 2018.
  1. Nov 20, 2018 at 7:25 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    I use my truck to pleasure and work. With that said, I need to be able to carry a heavier load at times. Not a bunch more, but 500lbs or so more than I should. I can't always use a trailer when I work in the city.
    I have a 2016, TRD, SR5 with a crew max cab.
    Will this work for my truck? Or does anyone else have any ideas on a good kit?
    https://www.amazon.com/dp/B017I8EHWS/ref=psdc_15731761_t2_B00L3OI5BI
  2. Nov 20, 2018 at 7:45 PM
    Aurora CO
  3. Nov 20, 2018 at 7:54 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Don't go cheap on an add a leaf. Itll ride like crap. A progressive 3 leaf would be nice.
    You may wanna look into sumo spring or superbump bump stops or air bags for your use. May fit your needs better than leafs.
    I would only run add a leafs if I wanted a lift if I had a constant load like a cap, bebslides/drawers, heavy rack etc...
  4. Nov 20, 2018 at 7:57 PM
    Vizsla
    Vizsla ☠️☠️☠️
    SC_TRD, Broncobroke and Black Wolf like this.
  5. Nov 20, 2018 at 8:07 PM
    Aurora CO
    That's good to know. I've seen mostly good reviews here about the Icon AAL . Didn't know that Deaver had a AAL. By the way ..I have a AAL on my Tunny with ToyTec shackle and rides just fine with only a few hundred lbs at times. I need to check out that Deaver AAL setup! :thumbsup:
    Rica25 likes this.
  6. Nov 20, 2018 at 8:35 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Hellwig 1909 helper spring kit won't effect the empty ride
    Yosemite_Fam, ldale and Vizsla like this.
  7. Nov 20, 2018 at 8:40 PM
    Erick
    Erick
    Thornton Colorado.
    What do you mean by losing capacity? Will this spring help my truck from sagging too much from a weight over load? I'm looking for someone that will add to my pay load.
    Thanks, let me know.
  8. Nov 21, 2018 at 4:11 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Yes , this kit will work and it will indeed increase the load capacity like you want. It's only 150 bucks brother, I say go for it.
  9. Nov 21, 2018 at 4:15 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I have the Tuff Country AAL. It's stiffer than stock but I wouldn't say it even comes close to "riding like crap". I wanted a little over 1" of rear lift and wanted to get rid of my block. This was a cheap and easy solution.
    But your situation sounds like you'd be better off with Sumosprings or airbags. I also have Sumosprings to handle additional weight and can't say enough good things about them.
  10. Nov 21, 2018 at 4:22 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I added the sumo springs/bump stops...they did the trick.
    Vizsla likes this.
  11. Nov 21, 2018 at 4:32 AM
    timsp8
    NY
    Have you thought about airbags? Should be easier to install.
    Vizsla likes this.
  12. Nov 21, 2018 at 4:59 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Forums.....love/hate. I have the Icon AAL in a cart about to pull the trigger and then I see this thread. I see some hate Icon AAL, some have run it for years with no issues at all. what do I believe? hell if I know, my guess is it'll give me the 1.5" i'm looking for and if in a few years it sacks out, i'll throw more money at it.
  13. Nov 22, 2018 at 10:13 AM
    Erick
    Erick
    Thornton Colorado.
    Okay. I ordered black sumo springs. Let's see how they handle.
  14. Nov 29, 2018 at 6:27 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    How do you like your Sumo Springs? Thanks
  15. Nov 29, 2018 at 6:37 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    If you want something that will add to your payload - get a different truck. Springs are only part of the equation for payload. Axle assemblies and frame strength play a part as well. Your legal payload is whatever your yellow door sticker says it is. Putting new springs on isn't going to change that (actually, adding a leaf technically will reduce the legal amount you can carry since you are adding weight).
  16. Dec 2, 2018 at 3:56 PM
    Erick
    Erick
    Thornton Colorado.
    Went fantastic. I had to wait for a day without snow or ice on the ground. That day finally came. I got it done in 2 hours. I did a 2" spacer and the sumo springs. It's pretty solid. Going to put about 2300lbs on it tomorrow. I'll report back with the results. Front is now @ 40" rear is @42"
    Black Wolf, Rica25 and OBXTundra like this.
  17. Dec 2, 2018 at 9:36 PM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    I have the Icon AAL, I was going to get the Deaver mini pack but the shop owner changed my mind- difference being the Icon AAL let’s you keep the overload leaf so you don’t lose towing capacity ... I have had them for almost 2 months now and I’m loving them
  18. Dec 4, 2018 at 4:07 AM
    Fired
    Fired Flame Extinguishment Specialist - Ret.
    The LowCountry
    '18 Limited Dbl Cab TRDOR
    Swapped 5.7 for V6
  19. Aug 8, 2019 at 8:10 PM
    2chains
    2chains New Member
    Southern Ablerta
    Wondering how you're liking the Icon AAL and how it is holding up? thanks!
    flinky14 likes this.
