Check engine light and exhaust issues
Discussion in '1st Gen Tundras (2000-2006)' started by Chief 01, Nov 15, 2018.
  1. Nov 15, 2018 at 3:07 AM
    Chief 01
    Chief 01 [OP] New Member
    PA
    2020Tundra Pro Army green
    Replaced all 02 sensors and maf sensor, rough idle on and off, now being told that ECM or something to do with ECM is making check engine light come on,when code is cleared stays off for a while then comes back on,also looking to replace complete exhaust system with upgrade, any recommendations.
  2. Nov 15, 2018 at 8:01 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I don't know much and may not be a ton of help but, it would be helpful to know what code is showing up.
  3. Nov 15, 2018 at 8:16 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    I agree @Baller not much in the noggin but Google can help out where I am lacking. I know some people too......:hattip:
    because_wumbo-truck likes this.
  4. Nov 18, 2018 at 9:23 AM
    Chief 01
    PA
    Code is P0100 MAF/VAC, circuit fault
  5. Nov 18, 2018 at 11:25 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Sounds like it could be a vacuum line or PCV valve
  6. Nov 18, 2018 at 11:30 AM
    Chief 01
    PA
    Thanks for the reply, I will check it out tomorrow when I'm installing a new hood protector, will let u know what happens thanks again
  7. Nov 18, 2018 at 1:34 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Be careful pulling the PCV Valve as that rubber grommet may be brittle if its old. Mine was very brittle and was changed out when I did the Valve Cover Gaskets. Mine was also clogged badly. I think this is an overlooked area on most vehicles and may be a problem that leads to overheated engines on our models.
    Also, look to see if any rubber lines have detached under the hood. Its happen to me. One other thing, last year my engine was throwing a code and about some fuel canister in the gas tank. I replaced the gas cap and fixed it! Hahaha.
  8. Nov 18, 2018 at 1:43 PM
    Chief 01
    PA
    Thanks for the heads up on the pcv valve, took a quick look at the hoses for anything off or cracked didn't see anything but will check again with some starting fluid.
