Tonneau Cover Recommendation?
Discussion in 'Tonneau Covers, Caps and Shells' started by Nmdna, Nov 12, 2018.
  1. Nov 12, 2018 at 1:49 PM
    Nmdna
    Nmdna [OP] New Member
    2018 Silver DC TRD Limited 4x4
    I'm in the market for a Tonneau Cover for my 2018 DoubleCab Standard Bed Tundra. The cover on my 2011 Tundra was an Extang Trifecta. I liked a lot of things about it, but I didn't like that I had to remove it completely to pick up loads of mulch or compost. It also would not have worked if I wanted to use a rack on the bed rails to carry bikes or kayaks.
    So, is there a cover that meets all of the following criteria:
    1) Does not need to be removed to pick up loads of mulch/dirt or compost.
    2) Does not interfere with installing a rack on the bed rails.
    3) Compatible with the factory deck rail system.
    4) Not too heavy (I tow horses and want to make sure I keep plenty of payload available for water/hay and what have you).
    Thanks!
  2. Nov 12, 2018 at 2:02 PM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I just posted this earlier today and checks all the boxes for you.
    flyfisher and Lake.Life24 like this.
  3. Nov 13, 2018 at 12:15 PM
    Nmdna
    Thanks. It definitly looks promising.
  4. Nov 13, 2018 at 1:03 PM
    BuilderBee
    BuilderBee New Member
    Southern California
    2017 Tundra Double Cab TRD SR5
    BakFlip MX4 Tonneau Cover Stubby Antenna Husky Floor Liners
    I have a BakFlip MX4 and it works great for me, fits with or without bedrails, spray on bed liner no issues, can load up to 300 lbs evenly spread on top of it.
  5. Nov 13, 2018 at 1:44 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    X2 Revolver... Thing of beauty.PicsArt_01-15-11.31.03.png PicsArt_01-15-11.29.19.png IMG_20180610_090801.jpg
  6. Nov 13, 2018 at 2:29 PM
    doggiecareman
    Eric
    North Central CT
    Who makes that bedrail rack setup?
    Toyotoholic[QUOTED] likes this.
  7. Nov 13, 2018 at 3:10 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    I had the Revolver, held up really good for 3 years, then it got caught in a windstorm and yanked up and out of the rails smashing some side clips. Partially my fault as I think it was slightly out of alignment after a couple months of neglect and not checking the screw tightness. I have since been talking about it behind its back and now have my eyes set on a Diamondback.
    equin likes this.
  8. Nov 13, 2018 at 3:39 PM
    Blueknights75
    Ron
    Clayton, NC
    Love my Rugged Cover 2 tri fold! Water tight and can be removed in 2 minutes with no tools.
    Stroke250 and T500 like this.
  9. Nov 13, 2018 at 9:52 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    It is a Trac Rack SR, I had it powder coated black because the silver was ugly on my truck... Can't have a rack that looks like asstoast.
    doggiecareman[QUOTED] likes this.
  10. Nov 14, 2018 at 2:21 AM
    Sunnier
    Sunny
    San Diego, CA
    @KB Voodoo makes cool brackets that allow you to mount a bedrack over several different tonneau covers....
    KB Voodoo and dcsleeper408 like this.
  11. Nov 14, 2018 at 4:30 AM
    Freezy
    Freezy New Member
    Does that cover do a good job of keeping everything dry? Did you have the factory rail system back there?
  12. Nov 14, 2018 at 7:02 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    It relocates the oem deck railing 2" lower and keeps things 95% dry... A little drip at the tail gate corners.
    I am 100% happy with it. So easy to use. Works with bikes too.IMG_20180225_163350~2.jpg
  13. Nov 14, 2018 at 7:55 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I have a truxedo low pro cover.
    It works well and is pretty low cost.
    https://www.autoanything.com/tonneau-covers/truxedo-lo-pro-soft-roll-up-tonneau-cover
    Not as secure as the bak revolver due to being fabric, but it has been my experience that items out of sight is 90% of the security.
    It is also lighter and takes up less space when folded up.
    I am not sure how it would work with a rack tho as I have no personal experience there.
  14. Nov 14, 2018 at 8:23 AM
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    Gotta ask...What size tires? How much lift?
    Your truck looks awesome!
  15. Nov 14, 2018 at 9:51 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Thanks!
    275/65/20 Mickey Thompson atz
    3/2 lift (TRD Pro suspension with CB +1 front and CB +3 shackles)
    Lambeau[QUOTED] likes this.
  16. Nov 14, 2018 at 9:08 PM
    twistedcricket
    twistedcricket New Member
    Paul
    Omahell, NE
    2014 SR5
    TRD rear sway bar, power fold tow mirrors, Firestone airbags, LED OEM fogs
    Had mine installed "professionally" and it never fit right. A gust of wind and it came up, out and bent a few places. Installer claims I set something heavy on it, reported it to Bak and I can't get it replaced.
    It also doesn't seal at the tailgate. It doesn't flood the box, but it's annoying enough and I don't trust it.
    Not going with another one of those for those reasons.
    B737 likes this.
  17. Nov 15, 2018 at 3:55 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    x2- I’ve had the Rugged Cover for few weeks and really like it. I don’t believe it’s the “2”, as I don’t have the attached LED lights in the back. Have taken it off a few times now, very easy and almost 20lbs lighter than the OEM Cover my Tacoma had.
  18. Nov 15, 2018 at 6:50 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I have the Backflip MX4. I love it. It comes with plates to lower the bed rails a few inches so they still work. If you fold it up all the way, it leans against the back of the cab. Pads come with it so cab doesn’t get scratched. And prop rods hold it open. Once folded all the way up, almost the whole bed is open. I’ll post pictures later.
    TOYOTRD8 likes this.
  19. Nov 15, 2018 at 9:22 AM
    JoshO
    JoshO New Member
    2018 Magentic Gray Tundra
  20. Nov 15, 2018 at 9:39 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I have the soft roll up from American Tonneau. I really love it. It fits the bed nicely, has kept the bed dry through several Florida rain storms, and has some hidden metal cross bars that allows some weight to be placed on it if need be. As an added bonus, they threw in an American flag and pole that mounts to your house. I really wanted a hard tonneau, but couldn't afford one. But, now that I have the American Tonneau, I don't think I'll switch it until the vinyl on this one is shot to s$^%.
    https://www.realtruck.com/american-soft-rolling-tonneau-cover/R184843P2018Y610MA.html
  21. Nov 16, 2018 at 10:05 AM
    Dilsky
    Shawn
    Edmonton, Alberta
    Yea mine dripped at the 4 corners, which wasn't too bad until I left my shoes there a couple times. Not sure if any cover is 100% waterproof. But in Canada I like it for the snow protection the most. I also liked the extra protection of it not being just fabric and still being able to roll all the way out of the way. Definitely hoping for a back friday sale on Diamondbacks though.
    Stroke250 likes this.
  22. Nov 16, 2018 at 10:29 AM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Looks more like a Gatling gun than a revolver!
    Bad Cow and Toyotoholic[QUOTED] like this.
  23. Nov 16, 2018 at 2:22 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Lol!
  24. Jan 7, 2019 at 9:10 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Looks good. Is there a problem with the deck rail system? I need to use the deck rail a lot for my dirt bikes and the likes. Your pictures make it look like the deck rail tie down points are unusable.
  25. Jan 7, 2019 at 10:06 AM
    Nmdna
    I ended up going with the Truxedo Lo Pro- very similar to the recommended Truxedo Pro X15, but a little cheaper and not as low profile. I would guess that they install in the same way. The deck rail tie down points are still usable, but because the mounting brackets for the cover are installed into the deck rail, the tie down points can only be moved in between the deck rail brackets where they are located and not along the entire length of the deck rail. So, it depends on which locations you need the deck rail tie down points to be in. There are 3 tonneau cover brackets on each rail, one goes 8 inches in from the rear of the bed, another goes 8 inches in from the front of the bed, the third goes in the center- I put each tie down point between an end bracket and the center bracket.
  26. Jan 7, 2019 at 1:49 PM
    doggiecareman
    Eric
    North Central CT
    Pretty much what he says below. Still liking it and believe it's a great way to go for a sturdy soft cover. You could have a full length deck rail mounted as long as they are designed to use the stake holes as their securing point and don't extend to0 far inward. There are systems out there that have that capability though they are fewer than the other systems out there.
  27. Jan 8, 2019 at 6:33 AM
    r1-superstar
    DB
    UTAH
    Can you post pictures please?
  28. Jan 8, 2019 at 6:38 AM
    r1-superstar
    DB
    UTAH
    How is it to take off with the Factory installed bedliner you have?
  29. Jan 8, 2019 at 6:57 AM
    Frog
    Frog New Member
    2016 FJ40 hauler
    If you have a drop-in bed liner, will the bed covers sill work the same or is there a better recommendation for this?
  30. Jan 8, 2019 at 8:19 AM
    doggiecareman
    Eric
    North Central CT
    I have the factory sprayed in bedliner. So no removal issues. So many drop in bedliner designs I can't speak to that but any of them would be trimmable/modifiable I would imagine.
