I need help with compatibility!
Discussion in 'Suspension' started by 510Krish, Nov 9, 2018.
  1. Nov 9, 2018 at 8:00 PM
    510Krish
    510Krish [OP] New Member
    2018 Toyota Tundra Platinum 4x4
    Hey guys, so I have a 18 cm 4wd and I’m getting s 6in lift put on it. I’m going with procomp for my lift. I also have a pair of 6in lifted “struts” or “coilovers” from rough country. Does anyone know if I can install these shocks, struts or what every y’all call them in the front? Or will it work or fit? Here is the link to them:
    6" Lifted Premium N3 Struts for 07-18 Toyota Tundra 4WD/2WD - Rough Country https://www.amazon.com/dp/B01L2VVE6Y/ref=cm_sw_r_cp_api_oEL5BbMW22A2E
  2. Nov 9, 2018 at 8:14 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Yes, it will work in conjunction with the Procomp 6 inch lift.
  3. Nov 9, 2018 at 8:42 PM
    510Krish
    Thank you! I wish they said it somewhere instead of writing a whole essay filled with bs!
  4. Nov 9, 2018 at 8:45 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Unless I'm missing something, It uses the oem coil so there should not be any fitment issues.
  5. Nov 9, 2018 at 9:23 PM
    510Krish
    Correct, the oem spring/coil
  6. Nov 9, 2018 at 10:41 PM
    @Les7311 has these on, also ther is a lift RCD that has Bilsteins extended struts for a 6" lift
    Black Wolf, Les7311 and jeremyd like this.
  7. Nov 10, 2018 at 5:11 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    They will fit as I did replaces the brick to shock. The only thing....
    Call a buddy, get muzik, puff something if you a smoker, and pack some patience.
    You may have to drop the lower control arm if you cannot slide them into position (which I didn’t do to avoid the PITA install that took 3 hours.
    Otherwise, mark everything you remove
    Keep us posted
    Black Wolf likes this.
  8. Nov 10, 2018 at 5:20 AM
  9. Nov 10, 2018 at 5:27 AM
    Aurora CO
    Heh.heh...
  10. Nov 10, 2018 at 9:20 AM
    510Krish
    I will keep y’all posted! Nov. 24 is when I’m getting it installed
    Les7311 likes this.
  11. Nov 28, 2018 at 10:44 PM
    510Krish
    Here it is guys! Full 6in lift kit by procomp and a awesome exhaust!
    parker44 and TXRailRoadBandit73 like this.
  12. Nov 28, 2018 at 10:45 PM
    Noice!
  13. Dec 2, 2018 at 12:34 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Sooooooooooo nice. But you gotta paint those flares!!!
  14. Dec 3, 2018 at 4:23 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    How does it ride with those rough country struts? I was thinking about picking up a set of the 3" ones when I replace my stock shocks.
