USB port
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14limited, Jul 1, 2016.
  1. Jul 1, 2016 at 12:52 PM
    14limited
    14limited [OP] Diehard Florida State fan
    Matthew
    14 limited 4wd
    3" OME magnum front bumper and steps spyder headlights MB TKO wheels
    Anyone have a problem with theirs stop working all of a sudden
  2. Jul 1, 2016 at 2:12 PM
    Fuse? I've had one go bad in my Tacoma before...needed a whole new one.
    Edit: new one = USB unit.
  3. Jul 1, 2016 at 3:02 PM
    14limited
    Matthew
    14 limited 4wd
    Ok thanks I'll look
  4. Jul 13, 2016 at 9:54 AM
    TundraWes
    TundraWes New Member
    Wes
    Key West, Florida
    2016 Tundra SR
    Its just a cable from your head unit to the mount in the center console. Have you taken out head unit lately? Maybe it cam loose. Is it an older truck that you been installing and removing the cable for years? You may have broken loose the circuit board side of the plug.
  5. Jul 13, 2016 at 9:58 AM
    TundraWes
    Wes
    Key West, Florida
    2016 Tundra SR
    I couldn't find the USB repair one. But here is the AUX IN repair. The USB should be close to the same.
    http://imgur.com/a/3Kxdf
  6. Jul 13, 2016 at 10:02 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    mine didn't work with my cheapy cable. used oe apple one. works fine now.
  7. Jul 13, 2016 at 10:43 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Yeah, I've had the same problem with the off brand cables. They're cheaply made and stop working after a while. Meanwhile the apple cables can be run over, burnt in a fire and exploded and they'll still juice up your phone.
    dcsleeper408 likes this.
  8. Jul 13, 2016 at 1:14 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  9. Jul 14, 2016 at 4:44 AM
    14limited
    Matthew
    14 limited 4wd
    It wasn't the cable but the use port started working again the next day
