Help! There is a creature living in my truck!
Discussion in 'General Tundra Discussion' started by j2007, Oct 14, 2018.
  1. Oct 14, 2018 at 7:22 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Good job! Glad you got them.
    j2007[OP] likes this.
  2. Oct 14, 2018 at 7:31 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Wow good thing you were on top of it before things really got torn up! What brand of glue trap is that? Never seen a neon green one like that.
  3. Oct 14, 2018 at 7:54 PM
    j2007
    j2007 [OP] New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    Yeah I’m really glad they were nice enough to make their presence obvious by making a huge mess out of the Kleenex box two days in a row.
    The glue trap was from Home Depot. The 4 lb mini sledge that finished off what the glue trap started was in my tool box.
    Watt maker, Adam, 15whtrd and 2 others like this.
  4. Oct 14, 2018 at 7:55 PM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Nah. Though I have sweat my balls off in that suit more times than I care to remember, it was not me this time.
    4x4_Angel likes this.
  5. Oct 14, 2018 at 8:14 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Man that sucks. I'm glad you got them!
  6. Oct 14, 2018 at 8:46 PM
    j2007
    VA
    I’m up to 3 now! Just went and checked the traps again before going to bed and found another! I wish I knew where in the truck they were hiding so I could clean it out of mouse crap and whatever else they dragged in there. I took everything out of the truck today and vacuumed the heck out of it and cleaned everything I could. But obviously these three were somewhere hiding.
    Based on the debris in the fresh air intake, blower motor, and under the front passenger seat, I’d guess they were in the rear seat vent under the passenger seat or between there and the blower motor. I ran the heat for 15 min earlier in the day trying to force anything out but didn’t see anything. I guess they could also have been under the carpet or under the center storage box. Maybe I’ll take apart the center console next time I have time.
  7. Oct 14, 2018 at 9:31 PM
    Jaxdad
    Jaxdad New Member
  8. Oct 14, 2018 at 9:35 PM
    Jaxdad
    Jaxdad New Member
    Just pick the truck up and shake it upside down till it falls out
    Adam and 4x4_Angel like this.
  9. Oct 14, 2018 at 9:54 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Yuck...at least you found their nesting site
    Damn mice
  10. Oct 14, 2018 at 11:15 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    Do they have some sort of bug bomb for critters?
  11. Oct 15, 2018 at 4:07 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    This is why I hate glue traps but man you got a problem! 3 of them already, I'd keep baiting till you come up empty.
  12. Oct 15, 2018 at 4:25 AM
    j2007
    VA
    Sonofa! Glue trap failure - 3 down but there is at least one more that got away. He left a present on the trap and ate the plastic. Guess I need another couple 4-packs of traps. This is nuts!
    Watt maker, Ostrich and 4x4_Angel like this.
  13. Oct 15, 2018 at 4:36 AM
    Very nice, you will get him. :thumbsup:
  14. Oct 15, 2018 at 4:44 AM
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    Big ones get in there also. This one was huge. Got killed when I turned the AC on.
  15. Oct 15, 2018 at 4:54 AM
    j2007
    VA
    Whoa! That is a lot bigger than the ones I’ve killed so far. I didn’t realize how common this is.
  16. Oct 15, 2018 at 5:53 AM
    Moon Puppy
    Bob
    2020 Tundra Limited
    So when you have Recirculate on and you turn off the truck, does the vent stay shut?
  17. Oct 15, 2018 at 5:59 AM
    j2007
    VA
    At least for awhile yes. I tested it while I had the blower motor and air filter out and could see the recirculate damper (or whatever it’s called) move when I hit the button. I turned the truck off and it stayed closed. I’m not sure if the electronics in the truck do anything to manage it while it’s parked and off for a long period. It would be nice if it automatically closed when parked regardless of the setting just to avoid this problem.
    Watt maker and 4x4_Angel like this.
  18. Oct 15, 2018 at 6:49 AM
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    I always have mine on recirculation. I'm in Tampa FL. We only have like 5 days of cold weather. But that's when me and a few other guys at work had issues. Check the AC filter regularly. That's the first barrier they chew through. All the tundras at work had been chewed up. Mine went through.
    My rat was too big to fit through a vent, but I assume that's how the little ones went inside your truck.
    j2007[OP] and 4x4_Angel like this.
  19. Oct 15, 2018 at 1:13 PM
    Tacogrande
    Jeremy
    Lol. I hope you were a face mask when you Gallaghered him! They redesigned those traps.. I have some old ones not the same.
  20. Oct 15, 2018 at 2:07 PM
    #50
    Woodguy65
    Woodguy65 New Member
    Imagine my surprise when I checked in the garage.
    Watt maker, Metro14536, ldale and 3 others like this.
  21. Oct 15, 2018 at 2:22 PM
    #51
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    :eek2: I think I need to go put some traps out in the garage and truck just for good measure.
    I think the truck is okay. I always leave it on recirculation and I have never seen any evidence of intruders, but my garage is another story - I have had mice before and I killed a snake 2 weeks ago just outside the door.
  22. Oct 15, 2018 at 2:46 PM
    #52
    j2007
    VA
    Yikes! Makes me appreciate my mice!
    Boerseun and 4x4_Angel like this.
  23. Oct 15, 2018 at 2:47 PM
    #53
    j2007
    VA
    Like @Jra8 said, check your cabin air filter in the back of your glove box. If you see any chew marks or holes that would be a good indicator to check further or put traps. Coming in the fresh air intake, after disassembling the whole system, I don’t see any way they can get in the cabin without going through the filter.
    Jra8 and Boerseun[QUOTED] like this.
  24. Oct 15, 2018 at 7:13 PM
    #54
    j2007
    VA
    In case anyone wonders what a mouse chewed air filter looks like, this is mine. (Yes, super dirty. I have 19,000 miles and expected it to last longer and hadn’t checked it before.)
    It is more chewed since yesterday so the one that escaped the trap must have tried to get out. He would have been blocked by the recirculate damper. I wish I knew where he was now. Worried he worked himself to exhaustion getting off the glue trap last night and is dead somewhere in a vent now.
    Watt maker and Black Wolf like this.
  25. Oct 15, 2018 at 7:27 PM
    #55
    Big J
    Big J New Member
    2020 4x4 crewmax
    Little asshole mice! I had one get under my hood and chewed the shit out of my wiper hoses. Pooped all over the engine cover too. Replaced the hoses and washed that shit off (literally). Sprayed everything with a water and vinegar mix. Hoping it helps kill their scent so they won’t come back.
    j2007[OP] and Black Wolf like this.
  26. Oct 15, 2018 at 7:28 PM
    #56
    Totally sucks
    j2007[QUOTED][OP] likes this.
  27. Oct 16, 2018 at 2:37 AM
    #57
    Adam New Member
    That sucks the last one got away. I bet they were using the HVAC system like those colored tubes my hamster had when I was a kid
    d.[​IMG]
    j2007[OP] and Sas like this.
  28. Oct 16, 2018 at 6:37 AM
    #58
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I have found ,at least where i live in the sticks. we leave the hood up on all our cars. And a few cheap Glue traps layin around.
    But we do live in a place where we never need to lock our cars or house.
    My Girls car has had the speed sensor wire eaten- Baby mice in the wheel well be the little mud flap-and her window washer water hose eaten.
    One time a litte mouse ran across the seat over her leg.
    Now that my Aunt down the driveway from me got rid of her chickens we have less
  29. Oct 16, 2018 at 9:41 AM
    #59
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    Damage could have been costly.
  30. Oct 16, 2018 at 2:01 PM
    #60
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Here's a thought though, check to make sure that the truck actually stays in recirculate mode once it's shut off. On mine, I can leave it in recirculate mode, the light stays on, shut the truck off, stay in the truck and listen carefully. After about a minute the truck will take itself out of recirc and revert back to fresh air. Turn the key back on and it puts itself back into rec and the light is on. This is why I installed the screen coverings
