Do these rotors look okay?
Discussion in 'General Tundra Discussion' started by Thattundradude, Oct 11, 2018.
  1. Oct 11, 2018 at 2:57 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    I have no previous experience with brakes nor do I know when the last time the rotors were changed. 2014 tundra 88k miles
    First 2 are the front left other 2 are front right.
  2. Oct 11, 2018 at 3:10 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Visually yea for the most part but a run out gauge will expose the truth
  3. Oct 13, 2018 at 5:45 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    You'd have to pull out a dial caliper to really see how much life the rotors and pads have left.
  4. Oct 13, 2018 at 6:46 AM
    Thattundradude
    Platinum Tundra
    Lifted
  5. Oct 13, 2018 at 7:55 AM
    15whtrd
    15whtrd Mr. Blonde
    If you can’t see the pads through your wheels you should pull the wheel and see how much life you got left. Inside and out. Check the rears as well. Some brake pads will have a little metal tab that rubs the rotor when they are low to indicate it’s time to change them.
  6. Oct 13, 2018 at 8:10 AM
    Thattundradude
    Platinum Tundra
    Lifted
    The issue is that the noise started after changing the left lower control arm
  7. Oct 13, 2018 at 8:14 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe the dust shield got bent and it’s in harmonics when the brakes are applied. Try tweaking it a little bit.
  8. Oct 13, 2018 at 8:34 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I'm gonna take it back to the shop I can hear it while driving too around 40 mph
    15whtrd[QUOTED] likes this.
  9. Oct 13, 2018 at 8:34 AM
    Thattundradude
    Platinum Tundra
    Lifted
    My steering wheel also shakes like crazy at 65 so maybe my wheel bearing is shot
  10. Oct 13, 2018 at 8:36 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s possible they didn’t clean the surface behind the rotor and hub or between the rim and rotor. Did you get an alignment as well?
  11. Oct 13, 2018 at 8:38 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Yeah but the crossmember has damage to one side and we weren't able to adjust the caster
  12. Oct 13, 2018 at 8:41 AM
    That could be your problem.
    15whtrd likes this.
  13. Oct 13, 2018 at 8:43 AM
    Thattundradude
    Platinum Tundra
    Lifted
    This damm thing won't adjust
  14. Oct 13, 2018 at 8:46 AM
    15whtrd
    15whtrd Mr. Blonde
    Hmm so you changed the lower a arm and they got the eccentrics out? I’m surprised it won’t adjust. From the picture it doesn’t look beat up. Sometimes those bolts get seized. But I don’t think taht would cause those noises unless it’s really tweaked I guess. Is anything rubbing the axles? In the video it sounds like your brakes.
  15. Oct 13, 2018 at 8:48 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I'm not sure the axle boots look fine they dont look ripped or damaged. The noise wasn't there before the change that's what I dont understand yet
