Fuse help needed ASAP
Discussion in '2.5 Gen Tundras (2014-2021)' started by jordanpop1, Oct 11, 2018.
  1. Oct 11, 2018 at 3:51 PM
    jordanpop1
    jordanpop1 [OP] New Member
    Blew the brake fuse trying to change tail lights on 2019 tundra. Someone help me out with which fuse it is?
  2. Oct 11, 2018 at 3:59 PM
  3. Oct 11, 2018 at 4:11 PM
    jordanpop1
    Right. Do we know which one it might be? Checked the related and they all look good
  4. Oct 11, 2018 at 4:33 PM
    You check your owners manual? Is it in the power distribution center or in the kick panel?
    Did you pull the fuse and inspect? Sometimes it burns where you can’t see it from the top.
  5. Oct 11, 2018 at 4:42 PM
    Kick panel, fuse 20, 15amp
    Hope this solves your problem. This can be so frustrating and cause someone to drink at least seven one packs.
    T-Rex266 likes this.
  6. Oct 11, 2018 at 5:31 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Yep, the one that says “TAIL” 15A above the 7.5A among the fuses in the instrument panel beside your left foot inside. The schematic is on the lid.
    MotoTundra likes this.
  7. Oct 11, 2018 at 7:47 PM
    jordanpop1
    So actually it was the STOP fuse. I had to pull them all out and look for the bad fuse.
    So freaking frustrating over stupid aftermarket taillights. Not too mention the audio shop had to leave the fuse cover off the drivers side. So the link helped to locate the fuse but damn!!!
    Thanks for the help.
    JoshuaA and ColoradoTJ like this.
  8. Oct 11, 2018 at 7:47 PM
    jordanpop1
    Here’s a few pics
    jeremyd, Areith762, NavyFlip and 4 others like this.
  9. Oct 11, 2018 at 7:49 PM
    Damn! Black Beauty right there.
    Bad ass truck!
  10. Oct 11, 2018 at 8:07 PM
    jordanpop1
    Dude, it came out freaking amazing. It looks much better in person too. I’ll get my DSLR on it tomorrow for some pics. It’s hard to photograph black trucks
  11. Oct 11, 2018 at 8:08 PM
    jordanpop1
    That’s after the ceramic coating modesta BC05/06
    ColoradoTJ likes this.
  12. Oct 11, 2018 at 8:12 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Holy Moses!!! :thumbsup: That is one SA and BA MF'in truck!! Pardon my French :rofl:
  13. Oct 11, 2018 at 8:30 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Damn, I should have mentioned that, usually you can’t get it out of Park and the ABS and traction control light are on, but if you didn’t move the truck, you wouldn’t know.
  14. Oct 11, 2018 at 8:33 PM
    jordanpop1
    Yeah it wouldn’t go into gear is what was pissing me off. I just wanted to get it home from my detailers and it was turning into a big ordeal. It’s been two weeks since the truck arrived at the dealer and finally it’s home. I’ll mess with the lights tomorrow with 20 extra fuses lol
    JoshuaA[QUOTED] and ColoradoTJ like this.
  15. Oct 11, 2018 at 8:36 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I only know because it happened to me. I had to pop off the tab to the left of the shifter so I could take it out of Park because I was 1/2 in the garage and didn’t want to leave it like that.
    In case anyone is wondering, this is the STOP fuse under the hood.
  16. Oct 11, 2018 at 8:40 PM
    jordanpop1
    Mine was the stop fuse on the drivers side inside the cab. I wonder if it’s different on the 2019, or if there are two STOP fuses.
  17. Oct 11, 2018 at 9:28 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    It's quite possible, if yours is labeled STOP, that's where it is. The one under my hood says "STOP", there isn't one labeled as such in my footwell fuses.
    Description: FUSE 10, STOP, 15A "Stop lights, high mounted stop light, vehicle stability control system, anti−lock brake system, shift lock system, multiport fuel injection system/sequential multiport fuel injection system, towing converter"
    From here, posted and applies to 2016, curiously enough I didn't have this info in my manual: https://www.autogenius.info/toyota-tundra-from-2013-fuse-box-diagram/
    It might even be different 2017 onward, not sure.
    Gorgeous truck by the way!
