33’s or 35’s
Discussion in 'Wheels & Tires' started by blakekircher, Oct 10, 2018.
  1. Oct 10, 2018 at 7:50 PM
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    here is a nice to see the difference in tire size before you buy and here is an with preview , right now I have 275/55/20 and will be moving up to 325/60/20 $995 after rebate after a 3inch lift in the front and 1 inch in the rear. this how my truck looks now. I still have about %75 tread left on my current tires, what should i ask for them?
  2. Oct 10, 2018 at 8:13 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    If you want to maximize towing and mpg, keep it close to stock.
    Every truck is different but in general...
    35's don't fit without lift/chopping
    34's need 2" and maybe rolling in the front fender (295/70R18)
    33's is what I'd do if I towed all the time, no lift/level (275/70R18)
    32's are stock (275/65R18), anything heavier is a mpg hit
    Toyota doesn't give us much in the front wheel well, stock offset is +60. If you get new rims, keep it at least +20 to avoid rub. This is 35" 0 offset on 2.75" lift, cuts required to make it work:
  3. Oct 10, 2018 at 9:40 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Millage is pretty much the same. I did feel a slight power lose just from gunning it at the light but not much. I have pulled the same load through the mountains when it was stock and with the 33s it does search 5th and 6th gear more often the it did stock but again very little deference.
    15whtrd[QUOTED] likes this.
  4. Oct 10, 2018 at 10:33 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Here's 33s with 3/1 ProComp leveling kit. If I had it to do over I'd go 295/70/18. (Psst: I know where I can get you a set of 33s with only 5000 mi on them.) :spy:InkedIMG_9614_LI.jpg
    Dgjman, tbutler, equin and 6 others like this.
  5. Oct 11, 2018 at 3:14 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I'm in the same boat. I like them for the mpg, power, and price. 75% of the time I think they look ok. 25% of the time I think they look a little small. I don't think they look out of place or draw attention.
    My 275/70/18s have a lot of life left in them as well. I will run them until I need new tires. It would bother me more to put on new tires when I didn't need them.
    sdde4n[QUOTED] and Sunnier like this.
  6. Oct 11, 2018 at 4:13 AM
    Sunnier
    Sunny
    San Diego, CA
    This looks great! I've come back to look, like 5 times, tonight. Thanks for posting pics! I wish everyone else that weighed in would edit and add a pic. :)
    Can you (patiently, as though it's not been answered 1.329k times on this forum) tell us what you had to do to fit them: wheel offset; trimmed/ removed what? Thank you!
    Yep. Can't buy new shoes when I've got perfectly serviceable shoes now. But, when these wear out... options!
    sdde4n, OBXTundra[QUOTED] and 15whtrd like this.
  7. Oct 11, 2018 at 5:06 AM
    War Machine
    War Machine SSEM # 5 3MW
    Is there an easy way to tell what my lift is? It came already lifted, and I didn’t get anything telling me what it is. I have 33’s now, but would like to go with 35’s when I eventually get new tires.
  8. Oct 11, 2018 at 5:17 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    295/65/18 on a 2/0 lift. Same lift as a PRO. They will fit with a stock bumper, based on research here, but you need to massage the inner front plastic a little.
    blue16 likes this.
  9. Oct 11, 2018 at 5:36 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Post pic's of your coilovers.
  10. Oct 11, 2018 at 5:46 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Wheel offset is +25 and I believe it's a 6" backspacing. Skid plate has been trimmed, pushed fender well forward about a inch and trimmed the mud flap where it cover's the cab mount. Truck is sitting on bilstein 6112's at 1.9 setting in the front with a driver side CB shim.
  11. Oct 11, 2018 at 5:50 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Those 33’s 275/70R18? I think they look pretty good.
    An aggressive tire and wheel, lower offset than +60, and lack of fender flare makes them look bigger too.
    3/1 lift gives it balance to the eye where the center of the wheel is lower than the bottom of the body, a truck stance.
    I’m 295/70R18 +18, 2.5” lift, 2 mpg loss at least. Next time I’ll go 285 and lighter wheel. The fender flare gives the illusion they’re smaller.
    Dgjman, Sunnier, blue16 and 4 others like this.
  12. Oct 11, 2018 at 6:22 AM
    atxtundra
    atxtundra New Member
    3” toytec eibach front suspension
    295/70-18 on 18x9 methods (+18)
    Perfect stance IMO
    thedonn, Matty4wd, Sunnier and 8 others like this.
  13. Oct 11, 2018 at 6:29 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Oh, dang!!! :eek2: :thumbsup::bowdown:
    This needs to be posted on the Black Tundra Porn thread!!! :woot:
  14. Oct 11, 2018 at 6:29 AM
    Rica25
    Ricardo
    Tulare
    20181007_083910.jpg 20180917_175953.jpg295 70 18 RGS ......I had Toyo Open country prior to these for only 3 months 275 70 18 and were to small for me these RGS look great and very quiet but big difference in the weight very noticeable and also mpgs si next time I was thinking sticking with the RGS but maybe doing 285 70 18
    JoshuaA, parker44 and blue16 like this.
  15. Oct 11, 2018 at 8:45 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Nice! I have similar side steps. How high are they off the ground now? Got a 5 year old that needs to be able to climb in. Lol. :)
  16. Oct 11, 2018 at 9:28 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I'm 5'2" and not a child and I should use a ladder to climb in!! :rofl:
    Dgjman likes this.
  17. Oct 11, 2018 at 9:32 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    I’m 6’3 so I got no problems. Ha!
  18. Oct 11, 2018 at 10:52 AM
    sdde4n
    sdde4n New Member
    Leitner Designs ACS
    They’re 33x12.5. My truck was too new to say what affect they had on MPG when we towed a 30ft TT 2300 mi to OR and back this July. It was less than 9 MPG at times.
    OBXTundra and JoshuaA[QUOTED] like this.
  19. Oct 11, 2018 at 11:01 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    285/65/18R Stock height minimal rubbing cooper stt pro
    Beatle, J&ATundra, equin and 4 others like this.
  20. Oct 11, 2018 at 11:10 AM
    #50
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    Those STT Pro's are mean! Hopefully getting mine soon.
    aperezsh[QUOTED] likes this.
  21. Oct 11, 2018 at 11:27 AM
    #51
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    That’s why it looked wide in your pic! Nitto RG 295/70R18 are 11.7”. Haven’t checked weight differences as I don’t know your brand/model, but I suspect the same mileage if you were to do it again and went with 295’s like mine. I also pull a 30ft TT, about the same mileage as you. Your 33’s also cost more than 34” 295’s.
    I don’t tow often or far so the mpg loss isn’t a huge deal. The slight benefit is I feel more planted with heavier wheels/tires over stock I guess.
  22. Oct 11, 2018 at 11:33 AM
    #52
    Sunnier
    Sunny
    San Diego, CA
    Thanks for the details!
    Casper3[QUOTED] likes this.
  23. Oct 11, 2018 at 2:02 PM
    #53
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Mine is on 3/1.5 lift with 37's (20x9 +20mm wheels).
    Mwray8909, Big J, equin and 7 others like this.
  24. Oct 11, 2018 at 2:12 PM
    #54
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Niiiiiccceeeee truck!!! Good stance, great color!!! Would be awesome if it had the light bar in the hood bulge, IMO :D
    matictundra[QUOTED] likes this.
  25. Oct 11, 2018 at 2:20 PM
    #55
    matictundra
    Franco
    AZ
    I making my own custom bumper that will incorporate a 30" LED light bar and 12K winch. Life budget is getting in the way, lol. Here is overlay sample pix...
    Ted4311, J&ATundra, Mwray8909 and 5 others like this.
  26. Oct 11, 2018 at 2:27 PM
    #56
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Oohhh, me likey. Post pics when it's done, on separate thread...light bar porn or something lol :rofl:
    15whtrd and matictundra[QUOTED] like this.
  27. Oct 11, 2018 at 6:49 PM
    #57
    Big J
    Big J New Member
    2020 4x4 crewmax
    Wow! What all did you have to do to fit 37’s on only 3 inches of lift?
  28. Oct 11, 2018 at 6:56 PM
    #58
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    I would go with 35 inch tires. I have hankook 315/75/16 mud terrains. I really love them , no issues
    J&ATundra, equin and Matty4wd like this.
  29. Oct 11, 2018 at 7:23 PM
    #59
    matictundra
    Franco
    AZ
    See items in green...
    equin, Big J[QUOTED] and Rica25 like this.
  30. Oct 11, 2018 at 8:47 PM
    #60
    Big J
    Big J New Member
    2020 4x4 crewmax
    Not as bad as I thought. Lol. :thumbsup: Thanks for info.
    matictundra likes this.
