Best Place to Purchase Katzkins
Discussion in '2.5 Gen Tundras (2014-2021)' started by mgh-pa, Oct 7, 2018.
  1. Oct 7, 2018 at 5:58 AM
    mgh-pa
    mgh-pa [OP] Perpetually a New Member.
    2016 Tundra DC SR5
    If I don't get rid of my truck for a crewmax, one thing I really want to do is install katzkins due to the kids.
    Our only authorized installer within 50 miles wants $1900 installed for all black w/gray piping and heat units. I think that sounds a little steep for a DC. Even if it's not, I don't want to drive the 48 miles to drop the truck off for a day and a half. Would be easier if I could find a more local installer.
    I was considering buying them online and searching for a third party (or dealer) to install them. The problem is most sellers on ebay sell just sell the leather with no customization or options for heaters, etc. I found a few online retailer's that claim to be authorized Katzkin dealers but it seems a little shady when there aren't any reviews of the site.
    Looking for recommendations from those who purchased outside of an authorized installer.
    Thanks.
  2. Oct 7, 2018 at 6:05 AM
    jdg1982
    jdg1982 New Member
    New Roads, LA
    2017 Magnetic Gray Tundra SR5 4x4
    I can’t recommend an installer, but I called an installer in the Denver area. The cost was $1400 for a CM. Just to give you an idea on price..
  3. Oct 7, 2018 at 6:06 AM
    mgh-pa
    2016 Tundra DC SR5
    Was that quote with any customization?
  4. Oct 7, 2018 at 6:07 AM
    jdg1982
    jdg1982 New Member
    New Roads, LA
    No, that was for a all black. No piping or stitch colors.
  5. Oct 7, 2018 at 7:19 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    The most economical way is $550 from seller “touchups” minus 15% eBay coupon when it comes up, install yourself over a weekend. That’s the route I took as my nearest installer wasn’t cheap and in another city.
    It’s doable but takes about 2h per seat, treat it like your reupholstering not putting on a cover in that you press out the wrinkles and use a $20 steamer off Amazon, one that you would pack in a suitcase on vacation, then it won’t be one time use. You can use twist ties or hog rings and hr pliers ($25 for the set, faster, hold/clamp/done). There’s not that many and they clip the piping to the foam’s piping in certain seams, not all. It’s basically the reverse of pulling the cloth off.
    You can also buy seat warmers on Amazon, you ground the one wire, the other wire is wedged into a fuse called “Seat Heater” in the set of fuses by the left footwell, so it only turns on when the truck is on. You can install the switches wherever you want, mine:
    “touchups” offers a few specialty ones for more but you’ll need to go to Katzkins themselves for customization (2-tone, piping, logos, etc).
    https://m.ebay.com/sch/i.html?_from=R40&_nkw=tundra+double+katzkins&LH_BIN=1&_sop=15
    I definitely recommend K’s DIY or not, you’ll love your truck all over again and it’ll feel brand new.
  6. Oct 8, 2018 at 12:58 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    You might try sending a message to Touchups. I did before I ordered mine and they said they do not have them in stock but order once they sell a set. They might be able to order what you are looking for.
    Also Like JoshuaA said they are not hard to install. Mine cost me around 800 with seat warmers and a day in the garage. I posted a write up of the install if you decide to try it.
    JoshuaA likes this.
  7. Oct 8, 2018 at 1:24 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I'm getting all black leather with gray double stitching including heated seats in my DC. Located in Denver. My friend works for a dealer and the company that does all of their custom leather is doing it for $1,300. I thought this was a fair price including install.
    NoMoTaco, plumber802 and Patch999 like this.
  8. Oct 8, 2018 at 1:34 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
  9. Oct 8, 2018 at 1:35 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    :popcorn:
    One question about Katzkins with seat heaters, how do you turn them on? Do they install a button for this on your dash?
  10. Oct 8, 2018 at 1:55 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    There’s a few different ones on Amazon, I got these, you need one set for each seat as there’s a panel that sticks to the seat and one on the lumbar. They both come through the middle out the corner of the leather opening and connect to a harness that’s long enough to install the switch anywhere you like (you can see where I did above). If you really wanted to, you could install seat heaters front and back. Push up and it’s a red lit high setting, gets nice and warm fast, push down and it’s a green lit low setting to maintain the heat, or turn it off in the middle toggle. That space in the middle of the pad allows you to install hog rings where a seam rod would be.
    This is how the center console is removed to install your switches.
    There are 2 long wires that come out of the harness. One is a ground, the other you tap into the fuse box I explained above to power the seats when the ignition is on.
    Patch999 and dandailey[QUOTED] like this.
  11. Oct 8, 2018 at 2:03 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
  12. Oct 8, 2018 at 3:13 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    XDS and Patch999 like this.
  13. Oct 8, 2018 at 5:38 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Next time I'm going with a upgraded leather kit from the get go. The first time around I went with the $550 eBay kit. After two years of gentle use I wasn't happy with the way they looked. I was about to spend upwards of $1K to get a upgraded kit to replace them. I ended up finding a leftover Katzkin Night runner kit for only $299 that I liked better. Do it once and do it right!
  14. Oct 8, 2018 at 6:24 PM
    mgh-pa
    2016 Tundra DC SR5
  15. Oct 8, 2018 at 6:48 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    These go over cloth ?
  16. Oct 8, 2018 at 7:07 PM
    TheBeast
    TheBeast The Beach
    no you remove cloth first
  17. Oct 11, 2018 at 4:15 PM
    GlobalGuy
    GlobalGuy GlobalGuy
    Frank
    Buffalo, NY
    2018 Silver TRD Double cab
    Where does one find a leftover Katzkin kit?
    Thanks
  18. Oct 12, 2018 at 6:12 PM
    thomasbus337
    2020 TRD Sport DC
    They pop up on eBay from time to time. My guess would be they are either overstocked or ordered for a customer and then not needed. The leather kit I have in my truck now is actually older than the truck itself(seat covers made Oct 2015 and truck built April 16)
  19. Nov 10, 2018 at 5:19 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    The company that does custom katskin covers for the Toyota dealerships here in N Virginia charges about 1500 for all black leather and install. However they would charge about 650 if I supplied the katskin.
  20. Nov 10, 2018 at 5:39 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    If they're using the basic Katzkin, they're charging $950 for it ($550 ebay - 15% coupon). $650 labor for 4h (pro time) if you bring your own.
    DIY and have extra cash for upgraded perforated leather, seat warmers/cooling kit.
  21. Nov 10, 2018 at 6:20 AM
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    OR18TRD likes this.
  22. Nov 10, 2018 at 7:22 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Ask a local upholsterer how much for the install if you were to order/supply. Maybe $100-200 per seat.
  23. Nov 10, 2018 at 7:23 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    panicman likes this.
  24. Nov 12, 2018 at 4:47 PM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
    Interesting stuff on the overstocked Skinz...
  25. Dec 12, 2018 at 10:11 AM
    Touch-Ups
    Touch-Ups New Member
    Toby
    Jonesboro, AR
    Hello. I am the aforementioned "Touch-Ups", if you have any questions about Katzkin, Alea, or Roadwire leather kits, or seat heaters and degreez systems, I'll see if I can help. Good job on the Nightrunner kit btw, and nice switch placement too. I've always liked that kit.
  26. Dec 12, 2018 at 12:11 PM
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    I bought an alea kit from touch-ups on ebay. Turned out great.20181008_164136.jpg
  27. Dec 12, 2018 at 12:30 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I know i paid too much because i got the Katzkins thorough Toyota..but full warranty.
    Hammerdog, panicman and Cement_Trd like this.
  28. Dec 12, 2018 at 12:58 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Is there any difference between the katzkin kits from eBay or from an authorized shop?
    Does the degreez kits gice cooled air or just ventilated?
  29. Dec 12, 2018 at 2:38 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I just finished my install.
    Got them from eBay.
    Couldn’t be happier.
  30. Dec 12, 2018 at 2:51 PM
    Touch-Ups
    Toby
    Jonesboro, AR
    No difference. You have to be an authorized dealer to buy them anyway. The 550ish kits on eBay are the exact kits we install. I basically have stacks of stock kits and one may get installed, or it may get sold online...Same kit. The degreez system works by raising or lowering the ambient cabin air temperature by around 20 degrees. Katzkin has a great guide here: And just so you know, the degreez system they sell is literally the exact same system used in Ford vehicles.
    https://katzkinvrs.com/_manage_/res/marketing/Degreez System Presentation and Installation Guide.pdf
