What frame fits 2003 reg cab Tundra ???
Discussion in '1st Gen Builds (2000-2006)' started by Bigtundra2003, Oct 6, 2018.
  1. Oct 6, 2018 at 5:56 PM
    Bigtundra2003
    Bigtundra2003 [OP] New Member
    Art
    2003 sr5
    Too broke to afford
    Hi All,
    Looking for info to replace a rotted frame on a reg cab 2003 tundra 4x4. Missed the recall. I am wondering if a frame from an extended cab w short box would work with minor modifications? Cant seem to find many reg cab donors. Any help from the community would be very much appreciated!!
  2. Oct 6, 2018 at 6:22 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Maybe if your reg cab is a long bed
  3. Oct 6, 2018 at 6:36 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    All regular cabs are long beds. An access cab frame with the short bed will work as they are the same wheelbase. It shouldn't need any modifications.
  4. Oct 7, 2018 at 2:55 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Did they make an AC long bed? I've only seen the regular size bed on en
  5. Oct 7, 2018 at 7:59 AM
    BestGen
    BestGen New Member
    Paul
    No they never did.
  6. Oct 7, 2018 at 8:35 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I can measure mine to see the body mount distances later today if that helps. While the frames are probably the same length they probably have different body mounting points.
  7. Oct 7, 2018 at 6:35 PM
    Bigtundra2003
    Art
    2003 sr5
    Too broke to afford
    Ya those measurements would be much appreciated. It isnt too much trouble to relocate the body mounts. It is a long bed, so it sound like I may be in luck. Thanks guys!
