Thinking through Suspension...
Discussion in 'Suspension' started by back_cast, Oct 3, 2018.
  1. Oct 3, 2018 at 7:18 PM
    back_cast
    back_cast [OP] New Member
    Denver, CO
    2018 5.7L 4x4 Crew Max SR5 - TSS package (gulf states toyota)
    I’ve been trying to understand the order of upgrades that i want to do. Let me know if you have any input on the following....
    Suspension
    I think I've settled on this bundle.
    Kings (front/rear w/ adjusters) and TC UCAs.
    http://dirtydeedsindustries.com/pro...ar-front-shocks-compression-adjusters-bundle/
    If I were to go this route, would you guys recommend adding some Coachbuilder shackles to the bundle for the rear leaf springs?
    Anything else I'm forgetting? I'd like to be able to run the truck without worrying about angles of CV joints, caster/camber, etc...
    Tires/Wheels
    I'm currently running the stock setup from the dealership. The wheels are 20".
    For the type of "offroading" that I want to do, I should probably look into selling these wheels and going with something smaller to fit more rubber. What wheel size do you recommend if running 34-35" tires all terrains?
    Also, wheel offset? Is there a general amount of backspacing I should look for if I install the above suspension?
    Exhaust
    I'm still leaning towards the 8" system that BA mufflers sells. The reason I haven’t pulled the trigger on exhaust is because I've heard that after lifting the vehicle and stuffing a larger spare tire under the bed, the helmhotz resonator may not have enough room to fit. Anyone have experience on this? Can you even fit 35s under the truck or do I need to be thinking about some sort of carrier in the bed? If I can fit 35s underneath, will I be able to install the resonator?
    Sorry for barfing out all of these questions....but i wanted to get yalls opinion on this stuff...
    Thanks,
    Jeff
    SoCal619 likes this.
  2. Oct 3, 2018 at 7:24 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I'm running 18's on Nitto Ridge Grappler 35's and I really like the choice. Lots of sidewall, plenty of width and perfect for daily driving. Road noise is minimal. My +18 offset needed a cab mount chop as well as a bumper spacer and some heat gun work to the fender well lining to keep from having to cut it.
    back_cast[OP] likes this.
  3. Oct 3, 2018 at 7:27 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Can’t go wrong with the King/TC route man, shackles in the rear wouldn’t be a bad idea to keep some rake. I run 295/70R18 on 18x9 wheels with a +12 offset, the general sweet spot for minimal rubbing is +18 to +30. It becomes more important to stay in that range when you go up to 35x12.5’s with the increased width.
  4. Oct 3, 2018 at 7:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Jeff.
    King TC= great combo. Get it installed and drive it a little. Then decide if you wanna upgrade the leafs with Deavers or something like that and do shackles at that time.
    If I could do it over (and I probably will) I'd get a 17" wheel. Careful, not all 17s fit over the calipers. But tires are cheaper and the wheels are too. As for offset, +18 to + 30 generally works pretty well. You may, depending on exact setup, need to make some room in the front wheel wells, the lower the offset the more likely you'll need a CMC.
  5. Oct 3, 2018 at 8:20 PM
    Squatchtundra
    Squatchtundra Hammer Down
    Olympic Peninsula
    2018 limited cm MGM
    Kings and Total Chaos UCA with ko2's
    I'm a little bias but it's a killer combo.
    1UPPER, equin, papasmurf and 3 others like this.
  6. Oct 3, 2018 at 9:08 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I love my kings, save a little money and get the ones with no adjusters. Suspension experts will say most will love the shock valving out of the box from King, I do.
  7. Oct 3, 2018 at 9:18 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    What’s up Jeff! As already mentioned the King TC combo is a solid choice for suspension. I would get the TC shackles if you want to fit a 35” spare in the stock location. Pair them with some Deaver leafs if you don’t tow heavy. The coach builder shackles are really nice but they are thick. I had to remove my CB shackles and use the TC shackles to fit a 35” spare underneath.
    I would go with 17” wheels and at least a +25 offset. I think the Icon six speeds are really nice.
    I have the 8” dirty deeds exhaust system with the helmholtz and it fits with my 35” spare. You just need to be precise when locating the helmholtz
    back_cast[OP] and papasmurf like this.
  8. Oct 3, 2018 at 9:22 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Im probs going a kings route also but sticking to the offroad rims. Do i need wheel spacers if i go up a size in tire from stock?
  9. Oct 3, 2018 at 9:22 PM
    Sas
    OKC, OK
    Did you have to mod anything else under the bed to get the 35" to fit?
  10. Oct 3, 2018 at 9:26 PM
    jc153
    San Diego
    Yeah just do the bfh mod to the stock metal tire locators. Hahaha They hang down in the way. You can also cut them or remove the rivets. I was lazy and just banged them flat.
    equin, joonbug and Sas[QUOTED] like this.
  11. Oct 3, 2018 at 9:30 PM
    Sas
    OKC, OK
    I don't have a grinder (yet... where you at @nk1794) so BFH therapy it is.
    nk1794, 831Tun and jc153[QUOTED] like this.
  12. Oct 3, 2018 at 9:34 PM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    Awesome list. I run 18x9+20 I think they’re perfect. I would go slightly more aggressive if anything.
    I have the 3/1.5 Toytec/Eibach setup with TCUCA’s and am pretty happy with it.
    You can see the rake with the 1.5” shackles here
    Can see the offset here with the 35x12.5x18’s
    Suspension shot
  13. Oct 3, 2018 at 9:35 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Drill. Takes FOREVER but it's nice and clean in the end. I'm not ready for BFH therapy on a 40k+ truck.
  14. Oct 3, 2018 at 9:38 PM
    Sas
    OKC, OK
    I've got some cobalt drill bits so I may actually go this route instead.
    831Tun[QUOTED] likes this.
  15. Oct 3, 2018 at 9:51 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    So to get factory rake with a 3” lift up front is just a 1.5” shackle by itself?
  16. Oct 3, 2018 at 10:25 PM
    TunderStorm
    Michael
    From my research some people were having issues with lifting the 18’s and the TSS. So in order to keep the rake similar to factory, I had the shackle set to 1.5” rather than 1” just to be safe.
  17. Oct 3, 2018 at 10:57 PM
    Fish2eat88
    Jay
    295/75 3/2 lift
    Whats your measurements from hub to fender? So all you have is a shackle?
  18. Oct 4, 2018 at 4:31 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    I’m trying to understand also....If one were to do the King (or any suspension) route with the toytec progressive AAL in the rear, or any Leaf pack for that matter, what would adding shackles do? How do they work together? I have an ‘18 myself and looking to do a 3” front (toytec Boss, King, or OME), and want about 1.5” in the rear also to keep a little rake. Thanks in advance for letting me chime in fellas!
  19. Oct 4, 2018 at 5:58 AM
    back_cast
    Denver, CO
    Lots of good information here so far. Thanks for following up guys.
    I need to talk to Keith and see if he has any discounts going on :)
    bigzrs01 likes this.
  20. Oct 4, 2018 at 6:25 AM
    TunderStorm
    Michael
    Yes just a Toytec shackle set to 1.5” in the rear and the Toytec Boss shocks.
    From my understanding a shackle is just another way to raise the rear. As opposed to a block/spacer.
    I haven’t taken measurements and am not with my truck until later this month.
  21. Oct 4, 2018 at 6:26 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Good deal. Any input on shackle versus leaf spring? One or the other, or both?
    I always heard to stay away from block/spacer lifts, on any vehicle at that.
  22. Oct 4, 2018 at 6:37 AM
    TunderStorm
    Michael
    Quoting someone else from another thread here:
    “The stock shackle bushings are locked into the eyes and do not spin freely. This causes some wind up of the rubber in the shackles that can contribute to bed bounce. The beefier shackles also have less side to side flex, improving ride a little bit too.”
    Imo they were better than blocks so I went that route. I wasn’t going all out on this truck as I have other vehicles so that is why I didn’t get leafs or kings/icons etc.
    I imagine it would depend on your goals as to wether you want to go all out and do leafs and everything. Shackles are cheap so if you’re spending all that money on new suspension I figure aftermarket beefier shackles would be a no brainer.
    But I’m no suspension expert. I would talk to Toytec or just do some research regarding your desired setup and wether to add leaf packs or not.
    equin and bigzrs01[QUOTED] like this.
  23. Oct 4, 2018 at 6:41 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Makes perfect sense. I was planning on contacting toytec today so I’ll be sure to ask and get their input.
    Thanks man! Love your setup btw
    TunderStorm[QUOTED] likes this.
  24. Oct 4, 2018 at 12:13 PM
    jc153
    San Diego
  25. Oct 4, 2018 at 1:53 PM
    back_cast
    Denver, CO
    jc153[QUOTED] likes this.
  26. Oct 4, 2018 at 2:15 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Shoot, that dirty deeds buy is very nice. Guess I’d better decided by Monday!
