Pluto is getting a hybrid flatbed
Discussion in 'General Tundra Discussion' started by Spvrtan, Sep 26, 2018.
  1. Sep 26, 2018 at 11:11 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I figure I'll start this thread to document this ridiculous idea and the undertaking.
    Goals:
    - More bedside clearance
    - Shortened bed overhang (ie. more departure angle)
    - Shed weight hopefully
    - Flat auxiliary gas tank (my current one is vertical and holds 45 gallons)
    - Low-profile toolboxes
    - Small flatbed for hauling moderately sized items
    - Spare tire area to accommodate up to a 44" tire
    - Ruggedness; the tubes on the sides will be beefy enough to act as sliders
    It's going to be mostly a cage using 1.5"/.120 round steel tube. 1.75"/.120 will be used for the sides and sliders. 2"/.120 will be used for the bumper. A few segments of ~6" C-channel will be used as crossmembers between the frame rails that should hold up the aux tank, boxes, and spare. That means the OEM spare tire carrier will be cut out for room, too. There will be aluminum plating on the bedsides to fill in the gaps.
    All that being said for now, my current auxiliary gas tank is for sale if anyone wants it. It holds 45 gallons and I gravity fed it into my main tanks filler neck. My toolbox is also for sale; it has some holes drilled into the bottom of it for mounting. The tank retailed for $550 before fees and I'm asking $400. The toolbox, which locks with a key, was $320 and it's yours for $200. Old, but still accurate, photos below..
    https://www.instagram.com/p/BV7rO-og2OM/?taken-by=spvrtan
    For now, I'll be sketching up a few draft designs and mocking it all with PVC once I take the OEM bed off the truck.
  2. Sep 26, 2018 at 11:14 PM
    Hey Kris, do you have a link to the fuel tank?
  3. Sep 26, 2018 at 11:14 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  4. Sep 26, 2018 at 11:17 PM
    Spvrtan
    Kris
    San Diego, CA
  5. Sep 26, 2018 at 11:23 PM
    Damn, those are pretty nice tanks. I'm sure you know what I was looking for...DOT complaint.
    I'm looking for a tag tank for my truck so I can have 60 gallons+. Thanks for the link.
    When is your expected completion of this hybrid bed?
  6. Sep 26, 2018 at 11:24 PM
    Eat. To. Much. Popcorn.
  7. Sep 26, 2018 at 11:32 PM
    Spvrtan
    Kris
    San Diego, CA
    Yea, it's DOT-compliant for diesel since it's a diesel tank. I use it for gas, which is technically not legal, but the tank can handle it just fine.
    I want to say that I aim to have this bed done in under 2 months but it's going to coincide with my trailer build. Both are the two biggest projects I'll be tackling and want to finish by the end of this year latest. The trailer was at a standstill for a few weeks up until last week when my axles finally came in and I'll be getting them on this weekend; here's the current state though..
    https://www.instagram.com/p/BmZaDwXHMfg/?taken-by=nervefoundry
  8. Sep 26, 2018 at 11:38 PM
    Is that what the manufacture said? Maybe I read it wrong. I seen the transfer was diesel only, and I assume that's what you are talking about?
  9. Sep 26, 2018 at 11:41 PM
    Spvrtan
    Kris
    San Diego, CA
    Yea, their site says as much that it's for diesel and other fuels (ie. they say "diesel only" in a few places because that's what it's DOT-complaint for). I called them over the phone about a year ago to verify that, while I couldn't legally carry gas in it -- at least in CA -- that it is perfectly safe to use it for gasoline also.
    aperezsh and ColoradoTJ like this.
  10. Sep 26, 2018 at 11:44 PM
    I agree. There are some cheap tanks out there I wouldn't even think about doing that with. Looks like you chose a quality tank supplier.
  11. Sep 26, 2018 at 11:46 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Just in it for the build :thumbsup:
    Kgfit85 and ColoradoTJ[QUOTED] like this.
  12. Sep 26, 2018 at 11:46 PM
    Spvrtan
    Kris
    San Diego, CA
    Totally. I have zero complaints with the tank for its intended purposes. The only thing I did extra was put thicker rubber strips between the bed and tank for more cushion on bumpy offroad trails; I also strapped it down with a ratcheting strap even though it is bolted to the bed.
    aperezsh and ColoradoTJ[QUOTED] like this.
  13. Sep 27, 2018 at 2:40 AM
  14. Sep 27, 2018 at 3:03 AM
    You all are making me hungry....
    Oh hell...
    :popcorn::popcorn::popcorn:
    and wash it down with beer!!:cheers::cheers:
  15. Sep 27, 2018 at 3:10 AM
    Grumpy Uncle
    Pat
    CO
    This will be BA!
    jewsNbrews and ColoradoTJ like this.
  16. Sep 27, 2018 at 3:30 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    In for updates also. I enjoy watching your threads.
  17. Sep 27, 2018 at 3:45 AM
    I guess I should have a little more also!
  18. Sep 27, 2018 at 3:48 AM
    This looks huge on a 32” monitor.
  19. Sep 27, 2018 at 3:48 AM
    Lol
  20. Sep 27, 2018 at 7:05 AM
    n2deep
    n2deep Pavement Princess
    I have been contemplating doing something similar. Want to build a tube bed with aluminum floor and hang fiberglass bedsides. Build in mounts for my RTT rack, water and fuel tank but I hate to loose my tailgate as that prevents me from having to bring a table when I camp.
    Pics for ideas.
  21. Sep 27, 2018 at 7:21 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I’ll be here waiting on more post for this build.
    08crewmax and jewsNbrews like this.
  22. Sep 27, 2018 at 7:31 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Get started already wtf
    I like that design. Do something like that and forget about bedsides. Who cares, its a dirt truck
  23. Sep 27, 2018 at 7:47 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @n2deep do it... back half the truck and call it a day...
  24. Sep 27, 2018 at 7:50 AM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    I came in cause I thought Pluto was getting flatbread. I ❤️ Flatbread. But was sorely disappointed.
    Tundyfundy, Luckydog, 831Tun and 5 others like this.
  25. Sep 27, 2018 at 8:24 AM
    Notachickmagnet
    Notachickmagnet New Member
    Now I have to join in and watch !
    :popcorn::cookiemonster::cheers:
    jewsNbrews likes this.
  26. Sep 27, 2018 at 8:36 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    This is going to be interesting cant wait for the outcome..:popcorn::sawzall::welder:
    Notachickmagnet and jewsNbrews like this.
  27. Sep 27, 2018 at 9:55 AM
    Spvrtan
    Kris
    San Diego, CA
    Yea, kinda like that. There won't be a permanent top half but I would like to eventually add a removable top ..like a hybrid shell. I'll be keeping the spare above the frame and mounted flat. I'll try and get some shitty phone sketches uploaded on the rough design.
    froggy78, saybng and jewsNbrews like this.
  28. Sep 27, 2018 at 10:27 AM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    Nice, When i was truck shopping for my second truck I was planing on building a flat bed. There's lots of potential but I'm not sure if it would have really offered any weight savings.
  29. Sep 27, 2018 at 10:31 AM
    Spvrtan
    Kris
    San Diego, CA
    Yea, it sure is wishful thinking. I need a rough idea of the bed weight itself so I can gauge what weight to aim for versus a stock bed. The only weights I could estimate are the tailgate at roughly 50lbs, tow hitch at 90, and spare tire at 65. I couldn't find anything online about the bed itself. The taillights together are maybe 5lbs. The OEM rear bumper as a whole around 40lbs.
  30. Sep 27, 2018 at 10:44 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Can't see the pics
