2018 TRD LED front turn signal lights
Discussion in 'General Tundra Discussion' started by Turtle, Sep 25, 2018.
  1. Sep 25, 2018 at 6:27 PM
    Turtle
    Turtle [OP] New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Evening all,
    Am looking for alternative to the "anemic" incandescent turn signal lights on 2018 TRD off road with full LED front lights. They are barely visible with the DRL let alone with the LED headlights. Been to "Headlight revolution" and only see information on "switchbacks". Looking for a true LED turn signal bulb (read brighter), and will play with resistors. Any information from the members would be appreciated as to source of parts, previous experience and of course to light the front end of the Tundra up at intersections turning.
  2. Sep 25, 2018 at 6:32 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    @BlueBottle did his. And a few other guys. I'd love to find a set for under $50 that don't require resistors
    BlueBottle and Jim LE 1301 like this.
  3. Sep 25, 2018 at 6:38 PM
    X2 ;)
    Boosted4runner and Pudge[QUOTED] like this.
  4. Sep 25, 2018 at 7:14 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I've got the LED turn signals on my headlights from Headlight Revolution. They're brighter than OEM, but I think the VLEDS that a couple of people are running are even brighter? Not really sure TBH. Check my albums and build page for some pics. They do require a resistor.
  5. Sep 25, 2018 at 7:19 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I have vled Triton V6. They have a plug and play resistor so no splicing needed. Bright AF! Not cheap though.
    https://youtu.be/Yuma4aclwYY
  6. Sep 25, 2018 at 7:23 PM
    Sas
    OKC, OK
    I couldn't get the switchbacks to work on mine. They were always amber so I returned them. I like the shade of amber of the Headlight Revolution's, but I wish they were brighter. I may bite the bullet again at some point and go with the amber V6's.
  7. Sep 25, 2018 at 7:24 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I didn’t get switchbacks. My drl is on the 18 led headlamps. Those lights only act as a signal only and I have never had an issue with them. I use them for both front and rear signals.
    Sas[QUOTED] likes this.
  8. Sep 25, 2018 at 7:28 PM
    Sas
    OKC, OK
    Yeah, I saw. Was just stating for the record. I had the 17's w/o DRL FWIW.
  9. Sep 25, 2018 at 7:30 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    That's what I am talking about and looking for. Are they plug and play? Resistors?
  10. Sep 25, 2018 at 7:31 PM
  11. Sep 25, 2018 at 7:32 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Will VLED also work in the back for plug and play resistors ?
  12. Sep 25, 2018 at 7:32 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Triton V6 VLEDs, resistors were not required on my stock 18 headlights.
    Before
    After
    Tundra18ttags, Jim LE 1301 and Sas like this.
  13. Sep 25, 2018 at 7:36 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Outstanding! exactly the lighting I am looking for in the front. THANKS
    Larmand and Sas like this.
  14. Sep 25, 2018 at 7:45 PM
    A little steep for 2 bulbs. - $20 if you don't need the hyper flash fix.
  15. Sep 25, 2018 at 8:43 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  16. Oct 14, 2018 at 4:53 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Evening,
    Have finished the upgrade on the front turn signal lights on the 2018 Tundra CM 4x4 off road. After watching many "you tube vids" on having to pull the grill, head light lower valance and finally the headlight itself to install VLEDS. I can attest that the LEDS can be installed without removing any of the intimidating front of your truck. I did remove the bolts that hold the windshield washer fluid bottle down and on the driver side loosened the battery hold down bracket to move battery over a bit. Did disconnect the negative battery cable. IT CAN BE DONE. I know it is protocol to post pics and I will attempt to do this. A big THANKS to @BlueBottle for the picts of a previously completed project.
    [​IMG] IMG_20181014_152637024_HDR
  17. Oct 14, 2018 at 5:24 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    I guess I am clueless at posting picts here.
  18. Oct 14, 2018 at 5:36 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
  19. Oct 14, 2018 at 5:46 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Tried and it asked for a file with no provisions to browse, tried to copy and paste and we all see the result of that. Have phone connected to computer as we speak, thanks for the suggestion.
  20. Oct 14, 2018 at 5:50 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    IMG_20181014_152637024_HDR.jpg Finally, thanks for the prod to keep working. Still outrageously happy with the improvement, fear it is just the beginning.
    Boosted4runner and Larmand like this.
  21. Jan 23, 2019 at 6:37 PM
    Tundrboyblu
    Tundrboyblu New Member
    2018 Tundra Doublecab TRD PRO
    Borla exhaust, Sentry XT tonneau cover, leather TRD seats, sunroof, Remote start, PopnLock, soon to install Focal speakers front and rear
    So I've been looking for a similar setup myself. Tried the LASFIT led bulbs that advertised themselves to have built in resistors but after installing them still does hyperflash so buyer beware! And honestly I was not impressed with the brightness. Also ditto on not taking the headlight assy, just listen the washer bottle and listen the battery to give you some room. I have Vleds on my Venza so I can attest to their brightness but they are not cheap but you get what you pay for
  22. Jan 23, 2019 at 6:53 PM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Sorry to hear about the "Lasfits" they looked impressive. Settled with VLED Tritons in the front and have since put the lower level VLED's on the rear. Resistors at every corner and work great. Been considering the third brake light and cargo in LED's also but have read somewhere here that there is interference with the key fob since there is supposed to have the pick up near the cargo/third brake lights. So that project is on hold.
