Hitch Rattle
Discussion in 'Towing & Hauling' started by Over the LINE, Sep 17, 2018.
  1. Sep 17, 2018 at 8:11 AM
    Over the LINE
    Over the LINE [OP] New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    I know about the commercially available "No more rattle" devices that use some version of a screw down clamp to stop hitch rattle but I don't want to be forced to unscrew anything to change draw bars, I switch bars often enough. Any of you guys have other solutions to hitch rattle?
  2. Sep 17, 2018 at 8:16 AM
    LML 3500HD
    I remove my hitch every time after pulling into garage, lay it on the ground underneath the bumper on the floor.
    trayday likes this.
  3. Sep 17, 2018 at 4:18 PM
    Over the LINE
    New Orleans
    I use mine way too often to not have it in my receiver. I need something to whack me in the shins on a regular basis anyway.
    On my last truck I was able to use a few strategic wraps of electrical tape to snug up the fit and cushion the joint but it does not work with this one.
  4. Sep 17, 2018 at 4:30 PM
    LML 3500HD
    I use mine a lot as well.
    However, you could use the wooden shims from Home Depot for framing and wedge in and break off. That has worked for me in the past on loose receiver hitches. Sometimes the more expensive receivers have a better fit as well.
  5. Sep 17, 2018 at 4:39 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Old bike inner tube. Cut a piece and slip it over the hitch bar.
    lionix and NewImprovedRon like this.
  6. Oct 2, 2018 at 11:05 AM
    Over the LINE
    New Orleans
    Colorado, I'm not sure how your reply slipped by me. I figured no one had any ideas for me.
    I tried a plastic window shim but it failed almost immediately. Maybe I'll try wood, it might give a little more.
  7. Oct 2, 2018 at 11:08 AM
    LML 3500HD
    Try it on the side of the hitch.
  8. Oct 2, 2018 at 2:02 PM
    15whtrd
    15whtrd Mr. Blonde
    How about wrapping the hitch with some 20 mil PVC tape? Eventually you will have to re-wrap but I think it would do the trick. Or maybe taping the plastic shims to the side of the hitch.
    Over the LINE[OP] likes this.
  9. Oct 3, 2018 at 7:30 PM
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    Fox/Total Chaos/Coachbuilder
    Drill the bottom of the hitch and tap it for a large bolt. Buy bolt, weld t handle to it. Easy to tighten and loosen by hand
  10. Oct 3, 2018 at 7:32 PM
    This is a great idea.
  11. Oct 3, 2018 at 7:53 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    That's what I would do.
  12. Oct 3, 2018 at 9:23 PM
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    I cant take credit. I saw it somewhere else and it stuck with me.
  13. Oct 4, 2018 at 5:34 AM
    Over the LINE
    New Orleans
    Great idea.
  14. Oct 4, 2018 at 6:14 AM
    15whtrd
    15whtrd Mr. Blonde
    This makes total sense. I know I’ve seen that on square tubing I’m just trying to remember where. I want to say on an engine stand/lift. Drill a hole and weld and nut over it.
    NewImprovedRon likes this.
  15. Oct 4, 2018 at 10:22 AM
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    That's a better idea.
    15whtrd[QUOTED] likes this.
  16. Oct 16, 2018 at 5:29 PM
    Over the LINE
    New Orleans
    I went back to the wrapped electrical tape I used on past trucks. I had to add extra strips top and bottom along with a couple of layers. I did this in two places. No more rattle. The extra strips were the difference.
    15whtrd and NewImprovedRon like this.
  17. Dec 6, 2021 at 7:16 PM
    Between exhaust and stereo system, I would never hear it.
