Tundra want start
Discussion in '1st Gen Tundras (2000-2006)' started by 24BillyC, Sep 3, 2018.
  1. Sep 3, 2018 at 10:41 AM
    24BillyC
    24BillyC [OP] New Member
    06 Toyota Tundra 4.7. Went to crank and clicked like it was the solenoid. Tried jumping it off nothing. Changed out the starter (WOW) got all back together and it clicks like before. ??? Take battery to have tested they said dead cell. New battery in place. And turn on ignition switch clicks once and lights flicker then lose power. After about 15 sec power comes back.
    Y0TA PR0 likes this.
  2. Sep 3, 2018 at 10:49 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  3. Sep 3, 2018 at 11:00 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
  4. Sep 3, 2018 at 11:01 AM
    24BillyC
    Think yoi
  5. Sep 3, 2018 at 11:02 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    So.. Did it finally crank?
    Battery test/replacement
    Crank bolt test
    Starter test/replacement
    You did jump the starter hot to batt right?
    Relay? Trans POS. Sensor?
  6. Sep 3, 2018 at 11:07 AM
    24BillyC
    No it hasn't. And no I didn't.
  7. Sep 3, 2018 at 11:30 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Have you looked at the MAF sensor? That can cause issues with starting also.
  8. Sep 3, 2018 at 11:42 AM
    Tierhog
    Tierhog SIG-AHOLIC
    Ok. Fair enough.. Sorry this happened to you. We've all been there and it sucks..
    The easiest way to sum up your dilemma is to play a video for you.
    I believe that Scotty Kilmer should suffice. He's got 50 years of mechanical experience and he loves Toyotas..
    https://youtu.be/TSE0fOrujW0
    I know he goes off in a different direction, but the initial survey and troubleshooting is sound.
    Anti theft?
    Battery cables?
    Crank in neutral?
    jewsNbrews likes this.
  9. Sep 3, 2018 at 1:00 PM
    24BillyC
    Code came up C1241
    Low battery positive voltage or abnormally high battery positive voltage.
    Tierhog likes this.
  10. Sep 3, 2018 at 2:19 PM
    Tierhog
    Tierhog SIG-AHOLIC
    C1241 TOYOTA - Low Battery Positive Voltage...Possible causes; Low Battery Charge, Faulty Battery, Faulty Charging System, Power source circuit...Possible symptoms, Engine Light ON, (or Service Engine Soon Warning Light) ABS Warning Light ON..
  11. Sep 3, 2018 at 2:21 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    Make sure starter and battery connections are clean and tight.
  12. Sep 3, 2018 at 7:05 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Check you ground wire
  13. Sep 9, 2018 at 6:56 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Starter
  14. Sep 9, 2018 at 7:19 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    You can get the starter tested as well. Surprise they didn't do that when they tested the battery.
