Icon rxt leaf question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erichudgins, Sep 7, 2018.
  1. Sep 7, 2018 at 7:03 PM
    Erichudgins
    Erichudgins [OP] New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Got the rxt leaf pack, currently on setting 1. I was on setting 2 but removed hitch and stock spare and added a high clearance bumper. I do have the sdhq chase with a spare and a pro eagle jack. Once I added the rear bumper it had the rear shock way out of the ride zone. 3+ inches over stock ride height. Once back to setting one. The truck sets level at best but with ANY weight added to the bed, it will start to sag. There seems to be no in between setting. Anyone have any advice on how to find that balance? I guess I could go back to setting 2 and add my 2nd spare.. but I didnt really want to drive around with it at all times.. all suggestions are welcome
    dcsleeper408 likes this.
  2. Sep 7, 2018 at 7:06 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  3. Sep 7, 2018 at 7:12 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    @joonbug might be able to help. I think he has these leafs.
  4. Sep 7, 2018 at 7:22 PM
    TheBeast
    TheBeast The Beach
  5. Sep 7, 2018 at 7:47 PM
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
    I have mine on option 3 and stay weighted. Without weight it sits way to high but I keep a decent amount of tools and goodies for random use inside the topper.
  6. Sep 7, 2018 at 7:49 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    There really is no in between imo. At setting 1 weight is really compromised. With my full spare and some basic tools I was at a decent height.
    If you are happy with the way it rides and really want to stay at setting 1 you can get a tc/camburg shackle. It will give u a little more height with little compromise. So if you add a bit more weight than what you usually have it won’t go down too much.
    I haven’t test this out, but it’s one of the options I can think of that can help your situation out.
    I opted to stick with the option 3 even though I’m on stock pro rears with no more rack and tent.
  7. Sep 7, 2018 at 8:02 PM
    crochetjohn
    I found it was pretty bouncy with the stock pro rears on. I was trying to pace buying all of MT. Didn't wait long. The Omega's made a really noticeable difference.
  8. Sep 7, 2018 at 8:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’m in the same boat. I mostly drive with an empty bed and don’t want my daily driving too rough. On day trips I’ll have a couple hundred lbs. On overnighter trips probably 4-500 lbs. I’m on the lowest setting and my leafs are almost flat already. I think I’m gonna try the middle setting as soon as @dcsleeper408 helps me do it. Hint hint. The ride is probably gonna suck with an empty bed but I don’t think I have a choice.
  9. Sep 7, 2018 at 8:36 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I have my icon rxt on setting 3 but that is becuase I used it to replace my 4in lift block! I went off roading with it today and it did great! I also like how it doesn’t squat as much with a load!
  10. Sep 7, 2018 at 8:48 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I have a box of tools full spare in maybe at 350lbs?
    It does feel a little bit bouncy, but nothing that drives me and the family crazy.
    Really can’t wait to put the new suspension on.
    joonbug likes this.
  11. Sep 7, 2018 at 8:52 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :anonymous:
    joonbug[QUOTED] likes this.
  12. Sep 7, 2018 at 8:59 PM
    Mountains49
    Mountains49 New Member
    2018 White Platinum
    Same situation here. Daily driver and predominantly unloaded - sits about perfect and rides great. Throw some gear in the back and it sags a bit. I’ll be adding an ARE cap in the next few weeks and I’ll see how it sits - probably going up to 2nd setting. May think about shackles like @dcsleeper408 mentioned.
    joonbug and dcsleeper408 like this.
  13. Sep 8, 2018 at 6:10 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    @dcsleeper408 @joonbug wouldnt the shackles be kind of a bandaid? I may be totally wrong but amongst just changing the ride height, it's not going to stop the sagging of the springs itself is it? Itd be like taking the arch out of the spring and trying to put it back with shackles right?
  14. Sep 8, 2018 at 7:13 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think running longer shackles give the springs more leverage. When I ran CB shackles on the stock leafs it def helped with sagging, but it was also slightly higher so there was more to play with. I'll most likely go to option 2 but need to figure out the fronts first so I'm not riding ass up
  15. Sep 8, 2018 at 7:42 AM
    GiantsFanDan
    Time for Deavers :crapstorm:
  16. Sep 8, 2018 at 7:47 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    I feel you. I was def ass up. It didnt look to bad in pics but when I stood behind the truck the rear bumper literally hit my belt line lol. Just super super stiff ride. Had plenty of travel lol just a terrible ride. I may just go back to option 2 and throw the extra spare in the bed and just roll with it. That should help at least settle it a little.. right now it sets 7 or 8 inches from the bumps.. and if I get down on it pretty good it squats, so I'm sure shes getting real close.
    dcsleeper408 and GiantsFanDan like this.
  17. Sep 8, 2018 at 7:47 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    As I just sold a set...:annoyed:
  18. Sep 8, 2018 at 7:53 AM
    GiantsFanDan
    I know. Just giving you a hard time ;) .You bought u748’s too? Correct?
  19. Sep 8, 2018 at 8:10 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Lol yessir. I still think those may have been overkill truthfully. I'd probably be in the same boat.
  20. Sep 8, 2018 at 9:02 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    It will be.. I think with the camburg or tc shackle it will be a small compromise. I’m surprised you have any arch at all. My tool box full spare and some small gear put my packs flat. At option 3 I got a small arch with little weight in the bed. I’d rather have rake so when I load up it settles down.
    Our leaf packs are long. They will look flat, but if you aren’t hitting your bumps I think you are ok.
    If you are worried about weight load go up to option2
    If you want a little height to negate a little more weight I say option 1 with tc or camburg shackle.
    boardude likes this.
  21. Sep 8, 2018 at 9:15 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Wow that's crazy man. I'm probably close to stock weight as far as overall load goes. I'm sure the chase and the spare are close to what the stock hitch was.. now that I'm thinking about it, I forget sometimes how damn heavy that pro eagle is.. I may just set it back to option 2.. at least it wont be flattening the overall pack. I'll post a pic shortly..
    dcsleeper408[QUOTED] likes this.
  22. Sep 8, 2018 at 9:19 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Driver20180908_111636.jpgpassanger20180908_111641.jpgride height with no extra weight in the bed20180908_111656.jpg
  23. Sep 8, 2018 at 9:30 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    @dcsleeper408 how much did yours settle, if at all, after you threw yours on?
    GiantsFanDan likes this.
  24. Sep 8, 2018 at 9:32 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Mine look like that too with my normal weight. Add another 50lbs and they are totally flat
  25. Sep 8, 2018 at 9:33 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    You guys think it makes a difference with the chase being over the axle vs the weight being in front or behind the axle?
    GiantsFanDan and dcsleeper408 like this.
  26. Sep 8, 2018 at 9:36 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Exactly im at an event and I just hauled a canopy tent and a table and some probably 100 lbs of supplements.... and it was flat..
  27. Sep 8, 2018 at 9:37 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I say go option 2.
    If you wanna bring it down position some weight towards the tailgate of the bed lol.
    I might go to option 2 if I end up leaving the rack off.
  28. Sep 8, 2018 at 9:52 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Option 2 FTW!!
  29. Sep 8, 2018 at 10:07 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Lol didn't you just come from that?!
  30. Sep 8, 2018 at 10:12 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    I did lol. But I really thought that it wouldnt be the drastic of a change. When I say she was jacked, I am not exaggerating lol. I'm gonna leave it where it is until I get my other spare. Then go back. I have to remember this pack is only a couple months old. Maybe itll settle a little more before I put it back.. or maybe I'll have to just buy more stuff and put it in the bed:) I'm sure you can help me @boardude
