vibration when accelerating and decelerating
Discussion in '1st Gen Tundras (2000-2006)' started by charlesboymary, Sep 4, 2018.
  1. Sep 4, 2018 at 3:54 PM
    charlesboymary
    charlesboymary [OP] New Member
    Christopher
    2006 DC SR5 TRD 4x2
    I have been experiencing a vibration when I initially begin to accelerate from a stop that goes away but then returns around 50 mph up to 80mph. It also vibrate during deceleration at those same speeds. Is this bad U joints? Need help diagnosing if anyone else has had this problem.
  2. Sep 4, 2018 at 3:56 PM
    Casper421
    In the woods
    06 DC
    Could be a worn out carrier bearing.
  3. Sep 4, 2018 at 4:02 PM
    charlesboymary
    Christopher
    2006 DC SR5 TRD 4x2
    is that a common part to go bad on a 1st gen. tundra with 200+ thousand miles?
  4. Sep 4, 2018 at 4:17 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah buddy. Do a youtube search on 2000-2006 Tundras Carrier bearings. It looks easy. I may do mine soon to get ahead of the problem. My mechanic said for me to take it off and just bring it up to the local heavy rig truck shop and let them press the u-joints. Toyota stealerships sell the Carrier bearing. Use the OEM Toy bearing as the cheap ones wearout from the reviews I’ve read.
    Overall, its an easy DIY job.
  5. Sep 4, 2018 at 4:19 PM
    charlesboymary
    Christopher
    2006 DC SR5 TRD 4x2
    yeah i just watched a dude on you tube. Looked pretty simple.
  6. Sep 4, 2018 at 4:42 PM
    YTThao530
    YTThao530 New Member
    I have the same issues after change differential fluid with Loyal purple and went back to OEM diff fluids back to normal but maybe carried bearings or U joint too. But my 2005 Sequoia not Tundra I think they are same
  7. Sep 4, 2018 at 4:46 PM
    charlesboymary
    Christopher
    2006 DC SR5 TRD 4x2
    yeah pretty similar to be sure thanks for the input.
  8. Sep 4, 2018 at 4:49 PM
    U joints through out drive shaft? Lifted? Carrier bearing spacers? Tires wheels road forced balanced?
  9. Sep 4, 2018 at 4:51 PM
    charlesboymary
    Christopher
    2006 DC SR5 TRD 4x2
    you're suggesting it could be any of those three things causing the issue?
  10. Sep 22, 2018 at 8:07 PM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    Move a tire around. Might have a broken belt/out of round issue
  11. Sep 22, 2018 at 11:11 PM
    bmf4069 Yup, that's car parts in a dishwasher
    Did you figure it out OP?
  12. Sep 23, 2018 at 12:04 AM
    trdprobped17
    trdprobped17 New Member
    Sounds like your transmission to me. However, it could also be a bad engine mount. It’s hard to say without seeing the vehicle and testing it myself. Take it to the dealership for a cheap oil change. They will perform their free multi-point inspection in an effort to make some money off you. At that time, they should let you know all that they have found out to be wrong with your vehicle. Then, depending on what it is and the cost, you can take it from there. Good luck.
  13. Sep 26, 2018 at 7:58 PM
    charlesboymary
    Christopher
    2006 DC SR5 TRD 4x2
    i did get it figured out it was the drive shaft. as well as the seal where it connects to the trans. was worn out and leaking. But my dealership replaced the entire drive shaft instead of replacing the carrier bearing and U joints.
