Cruise control probably
Discussion in '1st Gen Tundras (2000-2006)' started by Bam, Aug 29, 2018.
  1. Aug 29, 2018 at 4:14 PM
    Bam
    Bam [OP] New Member
    Hattiesburg Ms
    2006 pre runner 2X4
    I have a 2006 tundra tundra the horn the cruise all controlled from the steering wheel quit working at the same time any ideas what it is I have checked all fuses and all connections that I can find anyone have any ideas
    Y0TA PR0 likes this.
  2. Aug 29, 2018 at 4:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I think I've heard of this before. Bad spiral cable maybe clock spring? I think that's what its called
  3. Aug 29, 2018 at 5:21 PM
    Pudge
    CT
  4. Aug 29, 2018 at 5:26 PM
    Pudge
    CT
  5. Aug 29, 2018 at 6:00 PM
    Bam
    Bam [OP] New Member
    Hattiesburg Ms
    2006 pre runner 2X4
    The 2006 4.0 6 cylinder has no cables for the Cruise control It works the throttlebody electronically through the PCM. It does not have a accelerator or Cruise control cable
  6. Aug 29, 2018 at 6:04 PM
    Pudge
    CT
    I don't think the spiral cable / clock spring is an actual cable. It's something to do with the air bags or something. Common issue with those year tundras and tacomas. Symptoms are usually horn and cruise. I mean maybe it's something else and I'm totally wrong.
    NewImprovedRon likes this.
  7. Aug 29, 2018 at 6:20 PM
    Pudge
    CT
    Those electronic controls run through the clock spring.. .
  8. Aug 29, 2018 at 6:50 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME!
  9. Sep 9, 2018 at 7:48 AM
    bmf4069 Yup, that's car parts in a dishwasher
    Quick question, if your clock spring craps out wouldn't the airbag light come on?
