07-14 38 Gallon Tank swap install thread
Discussion in '2nd Gen Tundras (2007-2013)' started by papasmurf, Jun 11, 2018.
  1. Jul 16, 2018 at 10:58 AM
    Rafter75
    Rafter75 New Member
    Papasmurf,
    Thanks for doing the 38 gal tank swap and sharing pics. The one question I have is that I noticed the fuel pump and assembly part numbers are different between the 27 and 38 gallon tanks. Have you run into any issues using the old fuel pump from your 27 gallon tank? Do you know what the difference is between the two different pumps? Thanks!!
    Y0TA PR0 and thefreqofnature like this.
  2. Jul 16, 2018 at 11:01 AM
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    So no difference in the fuel pumps, they may have a different part number for two reasons, made by a different manufacturer or because a new generation truck with new parts get new numbers so far 0 issues with my fuel delivery and damn is it nice to drive and not stop for gas every two hours.
  3. Jul 16, 2018 at 11:22 AM
    Rafter75
    Rafter75 New Member
    Thanks for the super quick reply. That will save me $400!! Have you noticed if the trucks computer has learned the difference with having 11 gallons more of fuel? For example does the fuel gauge and trip computer read correctly or is it still computing like there is only 27 gallons available?
  4. Jul 16, 2018 at 11:28 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Ummmm idk i dont use the distance to empty feature, I generally leave it on fuel mpg avg. Im trying to see my gain from gears, so idk last time i checked it said like 300+ miles to empty after full. I know my range and never rely on the electronics. Some may find this annoying not sure if there is a way to force the computer to learn. or reprogram from the deal .. i dont know. BUt yeah save the $ and dont buy a different fuel pump, the only suggestion i would say is replace the fuel sending unit. its cheap and since you will already have the pump out its a good idea, because if it fails the truck thinks its empty and wont run.
    thefreqofnature likes this.
  5. Aug 12, 2018 at 10:04 PM
    MTBShane
    MTBShane Build, Build, Build
    Shane
    2016 MGM TRD DC 4x4
    Just starting on the mods right..... now
    First off @papasmurf, thanks for the write up! You and @SoCalDave definitely inspired and made this swap seem a lot less daunting. I did the swap today and it ended up being a lot easier than I thought, and both of these guys write ups definitely are worth reading and helped like crazy... Also if you have a 16’ or newer, the holes for the crossmember you have to add are already there, so no drilling or welding required.
    Y0TA PR0, aperezsh, TheBeast and 2 others like this.
  6. Aug 13, 2018 at 9:27 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Wow thats awesome thanks bro! glad to hear it went well, and good to know the frame has holes in it already for the 16 and up... it makes sense, but because i have a 07 i couldnt confirm 100%
    thefreqofnature and 4x4_Angel like this.
  7. Aug 13, 2018 at 10:01 AM
    MTBShane
    Shane
    2016 MGM TRD DC 4x4
    Your write up was just spot on, time it took for the research and then lotta patience goes to taking time to take photos of what you’re doing while your doing it, then taking the time to figure out part numbers and then write it all up! So, you took all the guessing out of it for a lot of people (including me) very much appreciated!
  8. Aug 14, 2018 at 2:44 PM
    TheBeast
    TheBeast The Beach
    good stuff. I need to get to it.
    papasmurf[OP] likes this.
  9. Aug 20, 2018 at 10:56 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Thats a cool write up
  10. Aug 21, 2018 at 10:55 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    hey thanks!
  11. Aug 21, 2018 at 10:56 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yeah man, not the easiest thing.. but hey if it benefits a lot of people ill take the time... Im gonna do a full documentation of my rear LT install on my build thread.. hopefully starting this weekend :D
  12. Aug 21, 2018 at 9:26 PM
    MTBShane
    Shane
    2016 MGM TRD DC 4x4
    Dammmnnnnn!:popcorn:
    papasmurf[QUOTED][OP] likes this.
  13. Aug 22, 2018 at 9:46 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    LOL yeah should be pretty awesome, camburg bed cage, King 3.0 16" triple bypasses, king 2.0 bumps and custom SUA deavers
    MTBShane[QUOTED] likes this.
  14. Aug 28, 2018 at 4:06 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Looking forward to it. I'm curious about your clearance with the 3.0's when one wheel is drooped and the other compressed. We had an issue (re-solved now) because the frame is wider where the shocks are mounted, I used 3.0 Fox's with a wheel spacers because of the RW rims. We just finished mine, after trying to modify the Camburg kit because of my frame shortening, I got frustrated and we just ended up fabricated a cage from scratch. Finally got it where I'm happy, at least for now anyway lol. That frame shortening thing keeps biting me in ass every time I try to do something. I'm kind of regretting it but at least I'm seeing the light at the end of the tunnel.
  15. Aug 28, 2018 at 5:47 AM
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Bruce again, Thank You so much for this thread. Truck is getting gears and lockers hopefully next week and the next mod will be this fuel tank swap. I have measured things a dozen times and I think I can fit it or atleast I am optimistic it will fit. My biggest concern is by the rear axle.
    Mountun Goat and papasmurf[OP] like this.
  16. Aug 28, 2018 at 8:04 AM
    MTBShane
    Shane
    2016 MGM TRD DC 4x4
    How did the weekend go? Did you get it done?!?!? Want to see them pics!
  17. Aug 28, 2018 at 8:24 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Well that’s interesting.... hopefully since I have facorty frame and I spoke w camburg when I went up there to pick up some stuff that the 3.0 would absolutely clear w my setup they said yes. They said I could even go 3.5 so hopefully it’s no issue. @zackbremer is gonna come out and help me w cycling the suspension once we have everything is mocked up. So we will find out but I’m confident it will go smoothly.
  18. Aug 28, 2018 at 8:25 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    That’s awesome gears and locker and fuel tank to me now feel like priority mods for anyone w 37’s they make life so much better for responsiveness , fuel mileage and range.
  19. Aug 28, 2018 at 8:27 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Nah this is my last week of class for my masters, so I had papers to write and shit so it’s getting delayed a few weeks. This coming weekend I’m out of town w family at our river house in Parker so I’ll be starting tear down the following week. And Zack is coming out sept 8/9 to give me a hand and I’m building him a tube bumper so we will be busy
  20. Aug 28, 2018 at 11:52 AM
    #50
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    The Camburg would have worked awesome if I didn't screw it up so I know you will be fine. I just had to deal with the frame being about 1.5" wider on each side where my shocks were mounted. I had plenty of clearance except in those circumstances where one side is at full droop and the other side is compressed. But I am also curious once you get it together and do that test where your clearances with your 0 offset wheels end up.
  21. Aug 28, 2018 at 12:20 PM
    #51
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    i have spacers in the rear to match track width of the front.. so I should be ok no??
  22. Aug 28, 2018 at 2:11 PM
    #52
    trdprobped17
    trdprobped17 New Member
    Cool setup bro. Thanks for sharing.
  23. Aug 29, 2018 at 7:27 AM
    #53
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    You're running 0 offset and spacers absolutely you should be OK. I was dealing with the OEM RW +50 rims, my frame being wider and the 3.0 shocks.
  24. Aug 29, 2018 at 9:19 AM
    #54
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Sweet good to know! and yeah your issue is very specific, but makes sense
  25. Sep 20, 2018 at 9:55 AM
    #55
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    So, I'm dragging this thread up real quick like.
    For the price you paid...why didn't you get the 48 gallon tank from TransferFlow? Or is the TransferFlow not CA compliant?
  26. Sep 20, 2018 at 10:01 AM
    #56
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    cant get the TF tank in cali, without some major complication, plus you will get fucked on smog inspection...
    that being said, TF tank is 150 lbs stock 38 gal tank is like 35-40lbs max... its plastic...doesnt hang below the frame rails and is all factory toyota stuff...
  27. Sep 20, 2018 at 10:04 AM
    #57
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Makes sense. Weighing my options for later on, 26 gallons just isn't enough.
  28. Sep 20, 2018 at 10:05 AM
    #58
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    nope! and i have to say the 38 gal and 4.88's is the best mod ive done...
    5150bronco likes this.
  29. Sep 20, 2018 at 10:07 AM
    #59
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Besides ditching the bracket lift :anonymous::anonymous::anonymous::anonymous:
  30. Sep 20, 2018 at 10:16 AM
    #60
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    .... ok best mod ditch bracket lift, second best 4.88's and 38 gal tank
