2018 Headlight upgrade problem
Discussion in 'Lighting' started by Sas, Aug 7, 2018.
  1. Aug 7, 2018 at 7:18 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Well, it seems I'm cursed when it comes to upgrading headlights and tail lights. These new ones from Headlight Revolution aren't working correctly either. The blinker only works when the lights are off. When they're on the blinker stays solid and the dash blinks fast acting like there's no light in there. It does it on both sides. I'm thinking the pinning is wrong or something on the harness. Thoughts?
  2. Aug 7, 2018 at 7:45 PM
    Sas
    OKC, OK
    Looks like the NSV hood bulge light and these new headlights aren't playing nicely when you don't have DRL's to begin with. There was a jumper that was a part of the original packet if you had DRL's that I didn't have to install, so maybe that needs to go in now.
  3. Aug 8, 2018 at 10:02 AM
    Sas
    OKC, OK
    Wow, this was a bit of an ordeal to get figured out. Called Headlight Revolution. They ended out having to call their harness manufacturer to get the answer. Short verison: The purple and b&w wires for the turn signal needed to be depinned and swapped.
    Okietundra and Pudge like this.
  4. Aug 16, 2018 at 12:50 PM
    Okietundra
    Okietundra New Member
    OKC OK
    2015 Silver Sky CM TRD OFF ROAD
    Glad you got it fixed
  5. Aug 16, 2018 at 12:51 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    This is why people recommend @iHacker . Hope you get your problem solved.
  6. Aug 16, 2018 at 1:11 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    That’s one of the steps before iHacker built it into his harness a while back, PNP, good QC.
