Steering wheel shake
Discussion in 'Wheels & Tires' started by Bferg1269, Jul 21, 2018.
  1. Jul 21, 2018 at 9:21 PM
    Bferg1269
    Bferg1269 [OP] New Member
    I have a higher speed shake in my 2015 tundra crew max. I have had the tires balanced and wheel Alignment. The shake happens between 55 and 69 mph? What would be my next option
  2. Jul 22, 2018 at 4:00 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Just went through that myself. Had it done at the dealer, the shop that originally did it didn't do it right.
    Black Wolf likes this.
  3. Jul 22, 2018 at 4:25 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Probably tires still. Could be brake rotors
    Pale_Horse likes this.
  4. Jul 22, 2018 at 4:36 AM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Make sure they are getting road force balanced on a hunter balancer.
    Check rotors as mentioned, 2015... probably about time to do them unless you already have...
    Welcome and good luck.
  5. Jul 22, 2018 at 6:20 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Road force, and dynamic balance. Dont let them get lazy and do a simple terrible static balance.
  6. Jul 22, 2018 at 6:49 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I had a bent wheel once...our roads are that bad.
  7. Jul 31, 2018 at 3:36 PM
    whoawalk
    whoawalk New Member
    Norm
    2016 Tundra Limited Crew Max
    I am having the same issue. I had a slight pull to the left had it aligned and the tires rotated and then this steering wheel shake started. I took it back to the alignment shop, he said it was the wear pattern on my tires and I probably needed to replace them (although, I did not have the shake when I took it in), did that took it back to be aligned after putting the new tires on and the fella tells me I have a bent wheel. Had another shop check it, no bent wheel and they balanced each tire however still have the dang shake! Now a third shop states that a dynamic balance will not work on the stock wheels (no outside lip) and recommends a road force test? I need some advice as, I am about to go Cra Cra here.
  8. Jul 31, 2018 at 5:34 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO.
    I have the same issue with mine being felt between 50-60 mph. It is NOT the tires/wheels on mine. I’ve had 3 sets of tires and 4 sets of wheels. It does nothing. Road force etc etc...
    It’s driving me nuts. I have an appointment with Toyota next week and it better be rectified or I’m buying an American truck...:anonymous: Maybe not but I can’t live with this shake..
  9. Jul 31, 2018 at 6:05 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
  10. Aug 8, 2018 at 1:22 PM
    wrechst
    wrechst New Member
    Willy
    2008 Toyota Tundra
    had installed new front rotors and brakepads and my steering wheel vibration was better but still there. my problem was that I did not do a good enough job cleaning all the rust out with a steel wire brush between and around the bolts where the rotors sit. Once that was done propertly my tundra is now as smooth as silk. simple but had me stumped had checked & balanced tires, checked driveshaft etc. etc. !!! :)
    mtntop and TheBeast like this.
  11. Aug 9, 2018 at 8:17 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    what bolts are you referring to? I have had wheels balanced and got my alignment today (desperately needed alignment, numbers were baaaaaaaaaaaad), but I think its still a little shakey. I think this has to do with tire wear, but still shouldn't be all that bad.
  12. Aug 9, 2018 at 8:21 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Dont drink so much coffee maybe it will disappear...jk..welcome from Ventura California..
  13. Aug 9, 2018 at 8:33 AM
    wrechst
    wrechst New Member
    Willy
    2008 Toyota Tundra
    Sorry not the best description not bolts exactly... I meant clean all the rust off the wheel assembly where the brake rotors butt up against also clean off behind the exposed threads really well... I thought it was a good enough job being the weekend mechanic i am and it was not... you really have to get in there and get all rust off so the rotor sits perfectly against the wheel assembly am still kicking myself for that!
  14. Aug 9, 2018 at 8:49 AM
    SullyMoto19
    Tyler
    Houston, Texas
    seems tedious, but I may need to do it. the salt water and beach trips are prolly killing me.
