Broke Down- Pre Collision System Malfunctioned
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bigjoe7757, Jul 20, 2018.
  1. Jul 24, 2018 at 12:14 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Thought I wanted a 2018 with the TSS until my wife got a new Honda Pilot with Honda Sensing (Honda version of TSS) and realized I didn't like the features. I ended up with 2017
    Watt maker and Bigjoe7757[OP] like this.
  2. Jul 24, 2018 at 1:14 PM
    Bigjoe7757
    Bigjoe7757 [OP] New Member
    2021 Tundra CrewMax TRD Sport
    Just got a call from the dealership, they said that with the help of a special Toyota hotline they were able to figure out that one of the Oil Control Valves went bad. They said this controls timing and other engine features and is what caused all the error codes. I asked why this would set off a Pre Collision System malfunction. They said it will set off all kinds of codes. They said when they examined the old part it had gasket material in it and they think this is what caused it to fail. I’m not sure if I’m buying it but hopefully it’s fixed. So they are ordering it and I can pick it up tomorrow after noon.
  3. Jul 24, 2018 at 1:21 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Gasket material in it? That's worrisome. They going to get into the engine to see where it came from?
  4. Jul 24, 2018 at 3:12 PM
    Bigjoe7757
    Who knows, they didn’t seem to think it was a big issue, I asked them to check the oil pan, who knows if they will
  5. Jul 24, 2018 at 4:18 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Sounds sketchy.
  6. Jul 24, 2018 at 4:22 PM
    plumber802
    Andy
    Vermont
    I'm not disputing that they found a part that was fouled with gasket material,just that it should have nothing to do with the TSS.I wonder if they might have done some type of re-calibration and kept it quiet.
  7. Jul 24, 2018 at 4:33 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    These engines are loaded with silicone gasket material during/after assembly. I sent in an oil sample to Blackstone Labs at 5K miles, and their analysis showed extremely high levels of silicone. Machines apply the silicone beads on mating surfaces and where does the over flow go? Into your oil and sensors. With a few oil changes the silicone levels dropped according to Blackstone. The days of cork gaskets are gone.
    Watt maker likes this.
  8. Jul 25, 2018 at 12:30 PM
    Bigjoe7757
    I wanna keep everyone updated in case this happens to someone else. I just called the Toyota dealership service to see what time to pick up my tundra and the service person said that they changed the Oil Control Valve and they got the codes again, so he said that they wanna check some filter under the valve cover. So still not fixed and told me they would call me tomorrow with an update.
    BamaGuyinTX and MikeyMTBs like this.
  9. Jul 31, 2018 at 10:16 PM
    Gotigergo
    Gotigergo New Member
    Any updates?
  10. Aug 1, 2018 at 1:48 AM
    Bigjoe7757
    Update, I got the truck back last night. So far on the ride home no problems, they said it was an oil control valve issue. Code was p0011. So after changing the OCV they stil had the issue. They then opened the valve cover and saw that the OCV cover gasket was not installed probperly and this is what cause the valve failure and is now not allow the new valve to build pressure. After replacing the gasket and reinstalling the valve cover and new OCV the tech accidentally broke the cam position sensor wire harnes. So they then had to get a harness and splice it into the truck, which looks like complete crap and I no doubt some day will have issues it’s it. Then after everything was back together and repaired and a fresh oil change they still had same issues. Finally they said the issue was the truck needed to build pressure with the new part and it was fine. They drove the truck like 40 miles before giving it back. I have driven it like 50 more and so far it’s good. This entire experience has really make me rethink this dealership. We shall see how this fix works as next week I’m driving 600 miles each way for vacation.
  11. Aug 1, 2018 at 6:01 AM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Wow.... that's all i Have. Totally unexceptable IMO. It didn't come in with hacked up wiring so it shouldn't leave with one.
    netranger6 likes this.
  12. Aug 1, 2018 at 7:39 AM
    BamaGuyinTX
    BamaGuyinTX New Member
    2018 Silver Tundra SR5
    So they didn’t replace the harness why?
  13. Aug 1, 2018 at 9:02 AM
    Bigjoe7757
    I have no idea, I asked the same question. I’m still undecided how I’m going to proceed
  14. Aug 1, 2018 at 10:45 AM
    BamaGuyinTX
    My guess is that they couldn’t get that covered by Toyota since the dealer broke it.
  15. Aug 1, 2018 at 2:19 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    How many miles on your truck? I’d tell them they are the proud owner of your truck. Ask when your new one is coming in.
    Bigjoe7757[OP] and Blueknights75 like this.
  16. Aug 1, 2018 at 2:29 PM
    Blueknights75
    Ron
    Clayton, NC
    Curious as to the miles as well. That engine bay pic doesn’t look like it should be of a 2018.....
  17. Aug 1, 2018 at 2:36 PM
    spn4125
    spn4125 New Member
    Not sure I would be too happy either with that roll of electrical tape wrapped around the wires on a new vehicle. Could they not at least put back on the stock loom? or is that under all the tape.
  18. Aug 1, 2018 at 4:03 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Yeah. Fuxk that stick
  19. Aug 1, 2018 at 4:56 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Could someone with a 18 take a picture of the same area to compare. My 17 is almost 2 years old and the wiring doesn't look that butchered or raggady. I would raise a stink to get a proper wire harness installed. You are right, you WILL have problems later on with it. These computer systems in the trucks measure all kinds of voltage to make adjustments and they are very small volt changes. Introducing the extra resistance for a poor splice job is just asking for more issues.
    Blueknights75 likes this.
  20. Aug 1, 2018 at 5:04 PM
    #50
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I would take that back asap and have them fix that because what they did just makes me speechless
  21. Aug 1, 2018 at 6:05 PM
    #51
    BamaGuyinTX
    I’m curious at to which dealership this is.
  22. Aug 1, 2018 at 6:07 PM
    #52
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Guarantee whoever approved and performed that HACK job would not have that on their own new truck!
  23. Aug 1, 2018 at 7:09 PM
    #53
    Bigjoe7757
    My truck is a 2018 4.6 CM, bought it in early May and it has 4700 miles on it. Could someone post a pic of there engine in this location I’m curious to see what it should look like. I complained to Toyota today and emailed the head of the dealer service as well as the president of the dealership group. Awaiting there response.
    ldale likes this.
  24. Aug 2, 2018 at 4:32 PM
    #54
    Bigjoe7757
    Well, the top guy from the service Dept contacted me back and stated that the harness should have been replaced. He has assigned the manager to look into why it was not replaced and stated that they are going to make things right. The harness is being ordered and they are going to call me to set everything up. Hopefully this is a positive experience and all is repaired correctly.
    Tierhog likes this.
  25. Aug 2, 2018 at 5:50 PM
    #55
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    Would have been fine if they would have told you they broke it and did a temp fix to keep you on the road while a new harness was ordered. But sounds like they were trying to be slick and got caught
  26. Aug 2, 2018 at 5:58 PM
    #56
    Bigjoe7757
    Agreed
  27. Aug 3, 2018 at 7:32 AM
    #57
    wallyblackburn
    wallyblackburn New Member
    Wally
    2018 Black Tundra SR
    Want to make sure I understand something... So, it ended up having nothing to do with TSS, right? It all came down to the failed Oil Control Valve - which sent pretty much everything into lala-land?
    Thanks,
    Wally
  28. Aug 3, 2018 at 8:15 AM
    #58
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I got the impression the initial problems caused a "cascade electronic event" too. You guys can coin that if you wish. Lol
    More common than you think. We naturally fill in the blanks sometimes assuming the trucks traction alert, TSS, etc have a specific cause and effect, but given his situation and the way all these computers communicate, I'd accept the systems were dropping off.
    I totally understand the harness replacement. It's a tough road. Toyota wants a certain image and one mechanic and a shortcut can easily ruin a reputation. Hell.. How many of us bitch and howl about the lube techs.
    The production issue was a fluke. Service stumbled and later made it right. OP should have had a demo truck, should have had a service managers apology, and maybe a few complimentary oil changes after the freebies are used up, to instill a relationship of trust and familiarity.
    Glad it ended well. That engine will run forever. How was the trip? How did the truck run?
    Bigjoe7757[OP] likes this.
  29. Aug 3, 2018 at 9:08 AM
    #59
    Bigjoe7757
    Correct, nothing to do with TSS. The Oil Control Valve and cover gasket were the issue.
  30. Aug 3, 2018 at 9:17 AM
    #60
    Bigjoe7757
    Leaving this coming week, will report back. They assigned this situation to their manager and he’s has promised me they would make this right and ensure I’m comfortable with the repair and confident in my truck. I pretty happy the way they responded to this and have delayed the rapair to when I get back.
    SNO BUS and Tierhog[QUOTED] like this.
