Water Pump
Discussion in '2.5 Gen Tundras (2014-2021)' started by Achuop, Jul 28, 2018.
  1. Jul 28, 2018 at 8:33 PM
    Achuop
    Achuop [OP] Stormtrooper 5.7
    Anthony
    Orange County, CA
    2015 Tundra Crew Max TRD 4x4
    TRD Pro grill, Magna Flow Exhaust, 3/2 leveling kit, TRD sway bar, black out emblems, Bakflip G2 cover, 20” ProComp wheels and Tires and lots of love and affection.
    This just happened and I just passed my 60k warranty. I’m at 61k Dang it!
  2. Jul 28, 2018 at 8:51 PM
    Figures... Surprised it didn't last longer than 60K. I bought a spare pump to use when mine goes. I'm at 91K. A typically terrible location to DIY. Lots of labor involved. I dread the day when it's time to replace.
    jewsNbrews and GNTundra like this.
  3. Jul 28, 2018 at 9:55 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    That sucks. They usually last much longer than that.
  4. Jul 28, 2018 at 9:58 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    Get a hold of Toyota and plead your case.
    Rocko9999, Toe404, OBXTundra and 5 others like this.
  5. Jul 28, 2018 at 10:03 PM
    nk1794
    San Jose, CA
    :thumbsup:
  6. Jul 28, 2018 at 10:17 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I think they might work with ya.
    Baja Mike and nk1794 like this.
  7. Jul 28, 2018 at 10:20 PM
    Achuop
    Anthony
    Orange County, CA
    Just snap a picture of the mileage. Lol
    I’m having a my colleague brother look into it Monday. He’s a Toyota Mechanic. Helpfully he can help me out.
    nk1794 likes this.
  8. Jul 28, 2018 at 10:30 PM
    Toyota has done some good faith work for me in the past. Toyota dealerships for the most part are very reasonable when it comes to issues like this.
    GNTundra and 15whtrd like this.
  9. Jul 28, 2018 at 10:42 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    I'd think Toyota would work with you on a warranty that's just over 800 miles past. In this day and age they know how much a "bad Yelp review" could do. It would hurt them more than helping you. Plus it brings back a return customer.
    If they say no, use my post as an example that they should fix it.
    jewsNbrews, 15whtrd, GNTundra and 3 others like this.
  10. Jul 29, 2018 at 3:49 AM
    That sucks! Just hit 58k on mine and hope I don't see this either at 60k.
    15whtrd likes this.
  11. Jul 29, 2018 at 9:56 PM
    Achuop
    Anthony
    Orange County, CA
    Thanks guys. I’ll gice Toyota a call first thing tomorrow morning.
  12. Jul 30, 2018 at 5:09 PM
    Achuop
    Anthony
    Orange County, CA
    Went to get it checked and he said I am good. Nothing to really worry about. He said if Toyota won’t cover it under warranty he will do it for $230.
    Not bad.
    Rocko9999 and Blueknights75 like this.
  13. Jul 30, 2018 at 5:32 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    +2, replaced mines at 90xxxx in 2013. Took a day to remove and clean, next day prep and install.
  14. Jul 30, 2018 at 6:07 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Be glad it is not a Gen I (4.7) with the water pump behind the timing belt. Royal PITA and one of the stupidest designs I've ever seen.
    Vglav and Black Wolf like this.
  15. Jul 30, 2018 at 7:56 PM
    The 2nd gen pump is pretty much behind everything....
  16. Jul 31, 2018 at 5:16 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It's not really a huge problem considering the timing belt should be changed every 90k as long as a good pump is used it'll make it that long.
  17. Aug 2, 2018 at 4:25 PM
    Achuop
    Anthony
    Orange County, CA
    Big shoutout to Toyota Corporate and Tustin Toyota for replacing my water pump under warranty when it is out of warranty. :)
  18. Aug 2, 2018 at 5:59 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Belt. ???
  19. Aug 2, 2018 at 9:03 PM
    Achuop
    Anthony
    Orange County, CA
    Hell yeah! I’m super stoked. Especially because I have a long road trip hauling my trailer to Whistler in Canada.
    SouthBoundSteve and landphil like this.
  20. Aug 2, 2018 at 10:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That was 4.7L talk, which have a timing belt. 5.7L and 4.6L run timing chains.
  21. Aug 2, 2018 at 10:19 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That should be a good torture test. :thumbsup:
    Glad you were taken care of, I think it’s safe to say from the staining in your photo that it had been happening for a little while before you discovered it.
  22. Aug 2, 2018 at 10:51 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    It’s usually only the gasket leaking, but Toyota typically replaces the whole thing if they do it under warranty. Just had work done on my timing chain and they only replaced the gasket on my water pump.
  23. May 18, 2022 at 9:55 PM
    Vglav
    Vglav New Member
    2009 toyota tundra double cab 5.7
    I got 120,000 out of mine on a 2009 Tundra 5.7, double cab SR5.
    I may have had a 1"x1" spot of coolant dried up behind the pump, probably from the weep hole, which usually means failure isn't far behind!
    I'm really surprised how cheap Toyota parts are, that hasn't always been the case! I guess since they make Tundras about 15 miles from my house, that's why!!!
  24. May 18, 2022 at 10:02 PM
    Vglav
    Vglav New Member
    Kinda funny, everyone has a unique problem, not so serious more of a nuisance... 2009 Tundra, 5.7, do all my own maintenance and only issues I've had is a) fcuking air pumps, as a mechanic I put in block off plates and module, no more limp mode and I got tired of using my OBD II scanner every other day to fix it, b) fcuking drivers side power window and power door locks, 120 k replaced 3 drivers side windows, freaking cheap plastic sash guide, absolutely garbage! Other than these issues, no motor or drivetrain issues... Oh and eats breaks like candy, 3 sets in around 90 k, then again I drive like a maniac!!
  25. May 19, 2022 at 3:49 AM
    What brakes are you using that only get 30k miles of service life?
