Most accurate tire gauge?
Discussion in 'Wheels & Tires' started by Eclipsed & Floating, Jul 28, 2018.
  1. Jul 28, 2018 at 4:40 AM
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    i have multiple gauges, deflaters, and compressors. All seem to be a little inaccurate but the most accurate is my compressor.
    What’s your most accurate source of gauging tire pressure, and when’s the best time to gauge/fill your tires?
    Please list pics, models, or links of where to purchase
  2. Jul 28, 2018 at 6:31 AM
    Aurora CO
    We get Snap-On Industrial Digital Aircraft Tire Pressure Gauge Kits sent in all the time for calibration verification. Damn good. Not junk.Cal'd them up in Anchorage too. Kits aren't cheap but you won't find anything better to use on your truck.Especially white ones..... Haha
  3. Jul 28, 2018 at 6:36 AM
    Mr Badwrench
    Mr Badwrench New Member
    I just use a "Slime" tire gauge that I picked up at Walmart.
  4. Jul 28, 2018 at 6:39 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Go ahead and forward one to me when you get a minute :fingerscrossed:
  5. Jul 28, 2018 at 6:46 AM
    Aurora CO
    I'd like to have a kit for myself too! Aircraft rated digital tire pressure gauges are pretty accurate and have great repeatability. Overkill for a truck? Nope. Back in the day your traditional pre digital aircraft tire pressure inflator gauges were verified every month. Digitals are checked yearly. (sometimes every 6 months).
    BTBAKER likes this.
  6. Jul 28, 2018 at 8:19 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  7. Jul 28, 2018 at 11:36 AM
    Eclipsed & Floating
    Voluptuous Whitey
    That seems pretty slick. I'm wondering how many tires it can inflate. For example, if you're out on a trail and need to reinflate after the run, or to inflate a flat that you plugged. How much air can it pass without overheating or shutting off
    Sunnier likes this.
  8. Jul 28, 2018 at 11:40 AM
    Sas
    OKC, OK
    Dewalt is pretty stout. I would think it could handle all 4 plus any spares pretty easily.
  9. Jul 28, 2018 at 11:53 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
  10. Jul 28, 2018 at 1:28 PM
    Eclipsed & Floating
    Voluptuous Whitey
  11. Jul 28, 2018 at 2:40 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  12. Jul 28, 2018 at 2:40 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Yikes!!!!
  13. Jul 28, 2018 at 3:33 PM
    Aurora CO
    The aircraft spec Snap-On's are even more! A 0.1 % bourdon tube Heise (the best) metrology grade mirrored pressure gauge can get quite spendy $$ real fast. A typical decent bourdon tube is 3/2/3 spec as in 3%/2%/3%. Digital gauges for everyday use like the Intercomp and Snap-On can meet 0.1% spec @ full scale and rarely need to be adjusted. Depends on use. By far bourdon tube design are still the go to gauge. We calibrate thousands of them each year compared to hundreds of digitals. The catch with bourdon tube type is they can go out of spec easily and can be a pain to adjust linearity and span into spec compared to digitals which are usually "right on" or broke and fairly easy to adjust into spec when needed. A big red flag is when a manufacturer claims their product never goes out of spec. Everything can go out of spec. Everything. We get new in box instruments from all kinds of test equipment mfrs and sometimes fail calibration right out of the box. Even $180,000 test sets.
  14. Jul 28, 2018 at 3:44 PM
    Eclipsed & Floating
    Voluptuous Whitey
    That’s why you need to get us a couple with your “5 finger discount”
  15. Jul 28, 2018 at 3:55 PM
    RitcheyRch
    Richard
    Santa Clarita, CA
    It wasn't that much when I bought mine about 10-15 years ago.
    Black Wolf likes this.
  16. Jul 28, 2018 at 3:56 PM
    Aurora CO
    Jail sucks...Those Intercomps are nice. $300 isn't that bad actually. Tire pressure is critical on race tires. Maybe not so much for us but still a nice to have.
  17. Jul 28, 2018 at 8:41 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I have this one attached to my ARB Compressor.
  18. Jul 28, 2018 at 9:15 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  19. Jul 28, 2018 at 9:41 PM
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Exact one I’ve been using for a long time as well. Durable easy to read gauge. Doesn’t require batteries or technology. In some products the KISS principle is key and this is one of them. Plus they aren’t overly expensive so I don’t feel guilty using and abusing.
    BlueBottle[QUOTED] likes this.
  20. Jul 28, 2018 at 10:01 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
  21. Jul 28, 2018 at 10:06 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Black Wolf and nk1794[QUOTED] like this.
  22. Jul 28, 2018 at 10:07 PM
    nk1794
    San Jose, CA
    This one is built to last.
    agentcox000[QUOTED] likes this.
  23. Jul 29, 2018 at 4:15 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Mayyyyyybe
    Mr Badwrench, GNTundra and Black Wolf like this.
  24. Jul 29, 2018 at 4:39 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    you guys are crazy. I use an Accu-Gage RS60XA for $15 on Amazon
    On a typical trip, I'll check street pressure, 40 front, 36 rear. When I get to the trail, I'll air down to the terrain. General trail, 22 front, 20 rear. If I hit rocks, I let out 2 psi. If I hit sand I go to 18 and 16. Air back up to street pressure to go home. If I'm at altitude, say 8k feet, I'll add 4 psi for when I get back to sea level.
    I have no idea if its an accurate gauge. Who cares??? I know what the tires are supposed to look and feel like on the trail over different terrain and once I know what that is I just remember the number. As for street pressure, there is no way 2 or 3 psi is going to make a difference unless you are running super low volume tires like the low profile ones on my lexus.
    But if you got the money to burn, then burn it
  25. Jul 29, 2018 at 4:52 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I couldn’t care less either but my truck is pulling right and have a bit of a shimmy in the wheel. It wasn’t doing it until I moved out of CO (11,000 was my house). I got to sea level and my low pressure light popped on. That wouldn’t have even bothered me except that I wasn’t low...I was over inflated (46+) all the way around. I dropped all 4 to “40” and that’s when it started. Now, I’ve jacked around with different pressure gauges, including my ARB deflator and it’s still doing it, with no ther variables to contend with. It’s not the end of the world and I’m certainly not gonna pay more than $30-50 to read my pressure but uneven wear sucks balls when I don’t wanna pay for new tires anytime soon due to overcompensating for the pull to the right
  26. Jul 29, 2018 at 5:27 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I understand. You certainly need to get the pressure correct on your tires. But a $15 gauge is good enough. It doesn't matter how inaccurate it is, it will read the same on the left and right tires so just make them the same to correct any pulling you might have due to air pressure.
    Also, if you buy a dozen different gauges at all price points I highly doubt you will see more than a 2-3 psi spread in accuracy.
    Also, the gauge I posted is a bourdon tube and has been initially calibrated to some ansi standard. No, its not as accurate as an expensive aircraft gauge, but its good enough
  27. Jul 29, 2018 at 5:51 AM
    Aurora CO
    I've taken apart and adjusted thousands of bourdon tube gauges over the years. Cheap is cheap. Bourdon tubes are not all the same. Not all metallurgical processes are the same. Not even close. There are high quality tubes and poor quality tubes. What about dial assembly quality? The are some cheap worthless crap gauges out there. A customer recently sent in 25 no name Chinese 60psi pressure gauges bought off Amazon supposedly factory calibrated at +/- 3%. Hahahaha. 6 failed hysteresis check and 4 we couldn't get to pass linearity. One was reading 47psi at 55psi test point. Ah...-8psi low. This was a 40% failure rate. Customer wasn't happy. Chinese moral of the story...."cheap is cheap", "crap is crap"
    And.....the most accurate doesn't necessarily mean the best..."for your use".
  28. Jul 29, 2018 at 7:18 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Not to thread jack but where are you living now and how are you liking it?
  29. Jul 29, 2018 at 7:20 AM
    Aurora CO
    That is a decent gauge. If in cal every year then send in for cal every two. We adjust calibration intervals at times when a unit historically is in cal. Depends on end user and use.
  30. Jul 29, 2018 at 7:38 AM
    mcroyo
    mcroyo New Member
    COS
    2017 MGM SR5 Crewmax
    Idatalink maestro, get my psi thru my headunit
