Mice in Cabin Air Filter
Discussion in 'General Tundra Discussion' started by 650h1, Mar 18, 2017.
  1. Mar 18, 2017 at 7:20 PM
    650h1
    650h1 [OP] New Member
    2013 Rock Warrior C/M
    Anyone ever have mice get into their cabin air filter? I turned my heat on after work and heard this awful grinding sound. Got home and took the cabin air filter out, and sure as shit, something (I'm assuming mouse) chewed right through it, and all the pieces got into the fan. No other evidence of a mouse (no dead body). I cleaned it all out and put a new filter in, but just wondering if anyone has any tips on mice-proofing their trucks...
    Eclipsed & Floating likes this.
  2. Mar 18, 2017 at 7:47 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    dryer sheets work pretty good for prevention.
  3. Mar 18, 2017 at 7:47 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Many others who have had this issue have been told to close the cabin fresh air inlet. Before turning off your Climate Control, hit the Recirculate button which closes the flap the others are suggesting is allowing rodent access.
    831Tun likes this.
  4. Mar 3, 2018 at 4:31 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    somewhat common see this at work a few times a month. +1 on dryer sheets use them in my camper, gotta get bounce original scent. smell good and cheap enough
  5. Mar 3, 2018 at 4:40 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Actually had one storing acorn pieces in the lid of my center console, caught the little bastard with a glue trap. :mad:
  6. Mar 3, 2018 at 6:37 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    I’ll give you the same advice lots of people gave me when I was inquiring about how to parent a troubled 16 year old; you just have to sit them down and tell those mice that they can’t act like that, and they need to do as YOU say because it’s YOUR truck........
    Newm, War Machine, 831Tun and 2 others like this.
  7. Mar 3, 2018 at 6:51 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    As with anything ...easier said than done. :p
  8. Mar 3, 2018 at 8:16 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Point made I see :D
  9. Mar 3, 2018 at 8:26 AM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    Yes mice can pretty much get in anywhere. For RV owners, it's especially bad because where we park is usually near great breeding grounds for varmints. We've had mice and even a skunk or two in our RV lot. Yes, dryer sheets are supposed to help defer as well as putting some steel wool in any opening you can find underneath the camper. I've only had mice messing with the white cloth covers on my tires and never inside, yet. (Our camper does have the bottom completely covered, though, as it's heated for colder weather.) I just make sure to visit the camper every few weeks to check on her. (She's parked at the RV storage lot at the AF Academy)
  10. Mar 3, 2018 at 8:29 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Adopt a dozen cats from the SPCA. Don't feed the cats. If you already have a cat, sit your cat down and tell him/her they're not performing to standard.
  11. Mar 5, 2018 at 5:09 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I changed the cabin filter in my mom's Tacoma last week after she mentioned a lack of air flow & some noise... squirrels had built a nest on top of the filter. I'm not sure where that cloth came from, but it was in there.
  12. Mar 5, 2018 at 5:46 AM
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 Diamondback Switchback 295/70/18 TOYO AT3 TRD CAI Window Tint
    Damn wtf
  13. Mar 5, 2018 at 5:52 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    that had to be good for the engine....
  14. Mar 5, 2018 at 5:58 AM
    Rex Kramer
    Georgia
    I pulled the blower motor, and removed a few peanuts still in their shells.
    Re-installed the motor, and everything works fine now.
  15. Jul 10, 2018 at 6:36 AM
    Downeaster
    Downeaster New Member
    Western maine
    2007 Toyota Tundra Limited.
    Fisher plow system.
    I watched a number of videos on replacing the cabin air filter in my 2007 Toyota Tundra Limited. Unfortunately to
    remove the fan is completely different from those videos show. It is vertical mounted and not horizontal... Mice
    are a real pain. Too bad mfgrs don't make filters that will smell good but drive mice for the hills.
  16. Jul 10, 2018 at 7:38 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    Yes, I had a mouse get in my air vents and when I turned the fan motor on it shredded him into a million little pieces. I also had a brand new Polaris that the mice decided to chew a hole in the engine air breather and deposit corn into my crankcase. The ATV only had 99 miles on it when the engine locked up.
  17. Jul 10, 2018 at 8:06 AM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    Cabin air filter not engine air filter
  18. Jul 10, 2018 at 8:09 AM
    Downeaster
    Western maine
    Fisher plow system.
    That stinks, I have a 2013 xp900, and like you deal with mice. It isn't something you can always park in you garage.
  19. Jul 26, 2018 at 2:39 AM
    WilliamBentley
    WilliamBentley New Member
    William
    Everyone faces once in their life the problem of mice in their homes or somewhere else like you have the problem with the mice in your cabin filter. You should use some sprays that are available at stores to get them out of the cabin air filter. You should look out that from where they got the way to enter into the cabin filter. You can also contact some professional Pest Control Branford CT exterminator. Maybe they can help you find some hint that from where the rats got the way to infest your cabin filter.
