What lift do I need for my daily rough ride?
Discussion in 'Suspension' started by Bigmurph762, Jul 12, 2018.
  1. Jul 12, 2018 at 7:17 PM
    Bigmurph762
    Bigmurph762 [OP] New Member
    2018 TRD off-road Tundra
    Stock
    I just bought my first ever brand new truck. 2018 crewmax TRD off-road. I need a lift. It's not for looks. It's for work. I drive 1.5 hrs to the mountains in WV up/down hills and winding roads. When I get to work I am up and down Jeep trails, dirt paths, rock construction entrances, deep powder dust, over 2' tall water bars...all day. 6 days a week.
    I have literally zero experience with offroading, or trail riding and I sure as hell don't have any experience or even the tools necessary to install a lift on my vehicle.
    I just want someone on here to tell me what to get based off of what I just told you it is I do all day long everyday. I'm putting about 125 miles a day on my truck. 50 of that is easily off road. I don't care what it looks like I just want it to help me and protect my 50k investment!
    I have 3-4k available to spend. Rocks are an issue too. I'm worrying I'll beat the hell out of my paint job :(
  2. Jul 12, 2018 at 7:18 PM
    Welcome from Texas, let's see your ride, check out @Toytec Lifts
    Stroke250 likes this.
  3. Jul 12, 2018 at 7:20 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO. Look @Toytec Lifts. Might wanna get some sliders and better skid plate to protect your truck.
  4. Jul 12, 2018 at 7:21 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
    :worthless:
  5. Jul 12, 2018 at 7:23 PM
    Look into RCI metalworks for underside protection
    Bigmurph762[OP], Ike74 and TXMiamiFan like this.
  6. Jul 12, 2018 at 7:24 PM
    Welcome from Ohio!
  7. Jul 12, 2018 at 7:25 PM
    Sunnier
    Sunny
    San Diego, CA
    Well. A lift won't save your paint. Look up the NorCal BASTRD's including @joonbug , @831Tun , and @dcsleeper408 for insight about how to (not) avoid pinstriping.
    If you can afford it, sounds like you best go ahead and do it right with Fox or Icon for 3" lift with external reservoirs. Probably the best alternates for serious off-roading may be ADS but there have been problems with these rotating or something. Cheaper alternatives include Bilstein. You can contact Toytech, a vendor on this site (associated with at least one of the forum moderators) and, by all accounts, they'll hold your hand and give you a bunch of options with explanations.
    RCI, SDHQ, and several others provide armour. My best advice to avoid rock damage is to avoid following other vehicle off-road at speed. I've had no damage from rocks I kick up with my truck; but I do have dings on the front and hood from rocks kicked up by others.
    We need pics of your truck (that's the price of admission on here), and I hope it's silver sky (because that seems to hide pinstriping best).
    You've definitely come to the right place!
  8. Jul 12, 2018 at 7:27 PM
    Bigmurph762
    Stock
    I just edited my post with a pic :)
    Black Wolf and Sunnier[QUOTED] like this.
  9. Jul 12, 2018 at 7:29 PM
    Bigmurph762
    Stock
    Man I was going to get the cement colored one but they sold it before I could get in :( I work long hours 6 days a week and the Toyota dealership isn't open on Sundays here in BFE. So I went with black
  10. Jul 12, 2018 at 7:30 PM
    Sunnier
    Sunny
    San Diego, CA
    Ooh, black. Sexy when it's clean and polished... but definitely not gonna hide or recover from pinstripes. Good luck, new Tundra homie!:fingerscrossed:
    jewsNbrews and JoshuaA like this.
  11. Jul 12, 2018 at 7:34 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    I would think bilstein 6112 front and 5160 rear would be sufficient. Run fronts at highest setting and a 1” shackle lift in the rear.
    If you stick with stock wheels you might be able to run 35”s and still keep your mud flaps which will help your paint a lot. Someone else who knows that for sure will likely chime in. And if not you can just step down to 34”s.
  12. Jul 12, 2018 at 7:35 PM
  13. Jul 12, 2018 at 8:10 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hmmm, Welcome BTW, if you're offroad a lot you should probably have a few things with you all the time. First, if you change your tires be sure to carry AT LEAST 1 full size spare. Keep a shovel in the truck and maybe recovery boards. Get a good kinetic rope or strap, shackles and a hitch like this
    Seize or mouse the pin to the shackle with stainless wire or a zip tie at least.
    I always air down to about 20 psi offroad so I have a compressor for inflation.
    Keep an eye out for some used TRD PRO shocks and Rock Warrior wheels. Then you can run some larger tires.
    You might want to have portions of the truck wrapped to protect the paint and/or the lower rocker panels can be sprayed with bed liner.
    joonbug, JoshuaA and Bigmurph762[OP] like this.
  14. Jul 12, 2018 at 8:14 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
    Bigmurph762[OP] likes this.
  15. Jul 12, 2018 at 9:22 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Where are you reading ADS are rotating? Thinking of getting a pair.
  16. Jul 12, 2018 at 9:30 PM
    Sunnier
    Sunny
    San Diego, CA
    Shoot, now I gotta find it. It was a feisty back-and-forth between some of the SGU guys or associates. I'll look to find it. Unless maybe @KevinK or @n2deep or someone over there chimes in to remind us who it is that's outspoken about ADS failures.
    FWIW, a bunch of guys on here have and love 'em (are you runnin' ADS @831Tun ?) and they're more affordable than Fox or Icon. And an all-race performance (no lessor street version). I definitely have them at the top of my list... but decided to find out more once I read some seriously challenge-high members on here discussing failures.
    When I find it, I'll edit this post to add a link.
    Here it is, @alpinepro4:
    https://www.tundras.com/threads/exp...id-travel-suspension.27853/page-2#post-681251
    I think @dragos28 is the guy they're talking about.
    I'm not saying there's any more problems with ADS than others, just that some have apparently had problems. I plan to find out more, and learn what customer service is like, before choosing. But I'm on no hurry. Just giving you a heads up to check it out.
    831Tun likes this.
  17. Jul 12, 2018 at 9:32 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No problems with the ADS. I do know of several ICON Omega bypass issues, like 6 trucks.
    joonbug and Sunnier[QUOTED] like this.
  18. Jul 12, 2018 at 9:33 PM
    alpinepro4
    Pat
    That would be great. They are at the top of my suspension list as well. Most of the guys who have them say they are bullet proof and ride nice as well.
    831Tun likes this.
  19. Jul 12, 2018 at 9:37 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've been super impressed with the ADS bypass shocks, whether crawling over rocks, flying through whoop in the desert or street driving the shocks have made a very noticeable difference in the ride.
    01erionracing, joonbug and Sunnier like this.
  20. Jul 12, 2018 at 9:59 PM
    n2deep
    n2deep Pavement Princess
    Not gonna hash it out again. But ADS will rotate due to the design. You need to make sure the top nut is tighten up correctly to minimize the rotation. They will get scratched when flexing and rub against the leafs. If you want them to stay all pretty then don't off-road or go with something else. They won't "fail" as one did with Dragos due to the rotation. His was a different issue that I believe was due to a manufacturer error when they were built. Which could happen to any brand.
    01erionracing and Sunnier like this.
  21. Jul 12, 2018 at 10:07 PM
    alpinepro4
    Pat
    So the rear shocks rotate then? Wonder why no one has mentioned it.
  22. Jul 12, 2018 at 10:11 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    As stated above, the top nut has to be tightened properly to keep 'em from rotating. I noticed this when installing and tightened 'em enough so that they don't rotate yet the rubber bushing isn't completely distorted.
    Sunnier likes this.
  23. Jul 12, 2018 at 10:23 PM
    Sunnier
    Sunny
    San Diego, CA
  24. Jul 13, 2018 at 3:29 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  25. Jul 13, 2018 at 7:54 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    After re-install, I had one rotate. After torquing everything back down tight, I haven't noticed movement. Just make sure the top nut is real tight.
    Sunnier likes this.
  26. Jul 13, 2018 at 8:11 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Honestly if you are going to be spending 40% of your time off-road with the truck. I would go with a higher end suspension kit. Fox or Icon shocks/lift. Then I would put some sort of slider for the rocker panels. Then I would install a better skid plate. I would also upgrade the tires to some larger BFGoodrich tires.
  27. Jul 13, 2018 at 8:14 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    Welcome from MT.
    Any of the big name suspension companies would be good. I have King's and love them but everyone has their preference.
    Kings, Icon, Fox, Bilstein, etc.
    Just find the ones that fit your budget and give you the lift/performance you are looking for.
    If you are spending that much time off road something with remote reservoirs and RCI skids for sure.
    There are half a dozen rock sliders that would be a good investment as well.
    Don't worry the fools on this site are good at giving people ideas on how to spend money they don't have.
  28. Jul 13, 2018 at 8:20 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :notsure: Icon fixed the problem! ADS’s solution is to tighten the bolt tighter. :facepalm:
  29. Jul 13, 2018 at 8:24 AM
    Welcome from CO. See ToyTec for 2.5" OME setup with DAKAR rear leafs. Won't break the bank and more than sufficient for what your doing. ToyTec's Eibach setup is good too.
    Stroke250 and Bigmurph762[OP] like this.
  30. Jul 13, 2018 at 8:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    With a $4k budget, if I were you I would start with a lift and some armor.
    $1500 on the lift (OME, Toytec, or Bilstein 6112)
    $500 for install
    $1200 on sliders
    $800 full skid plates
    Then when you come across a little more or can up the budget, get some wheels or at least some bigger tires.
