Bought my first handgun! Glock 19. Needs & Mods?
Discussion in 'Guns & Hunting' started by TTU19, Jul 2, 2018.
  1. Jul 2, 2018 at 6:58 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Well, I was finally able to purchase my first handgun. I ended up getting the Glock 19 Gen4. I was really close to getting the Sig P320 or the M&P Shield, but decided on the Glock. Those others will for sure be on my radar going forward.
    But for now, I have the Glock. So I wanted to ask, what are some "Must Haves" for it? I know they are all subjective to you personally and may or may not be good for me, but I just wanted to get thoughts on what you use and like. If you can provide any links for me to check out, even better.
    -Night sights
    -Holster
    -Case
    -What ammo do you like best?
    Anything else? I probably wont do anything else specifically to the gun for a while to mod it, but has anyone done the Extended slide lever, triggers, extended mag release?
    Thanks again for any info.
  2. Jul 2, 2018 at 7:04 AM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    Night sights are a must. I bought trijicon HD, but there are plenty choices. I carry mine in a stealth gear ventcore. As for ammo most brass is fine. Remington umc is the only one on my list I refuse to buy so far.
    TTU19[OP] likes this.
  3. Jul 2, 2018 at 7:09 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
  4. Jul 2, 2018 at 7:13 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I added an extended slide release (Glock brand) and did the $0.25 polish job on the internals to get a smoother trigger, you can Youtube it. Also I added a G17 trigger to mine as it has a smooth surface instead of the grooved surface trigger that came with the gun. Yea night sights a must, I need to get around to adding them to mine. I also bought a G17 magazine for mine for the extra two rounds and I bought the Glock brand G18 magazine which is 33 rounds I believe, didn't know if high capacity would be an issue around election time so I picked one up it's not practical but cool.
    Black Wolf and HighDesertSurfer like this.
  5. Jul 2, 2018 at 7:19 AM
    Rngr188
    Chad
    Harrison AR
    Here's a picture with the extended slide release also happens to have the G17 mag in her when I took this picture.
    Black Wolf, ColoradoTJ and TTU19[OP] like this.
  6. Jul 2, 2018 at 7:22 AM
    Rngr188
    Chad
    Harrison AR
    Found one with the silly G18 magazine but has a little better view of the slide release.
  7. Jul 2, 2018 at 7:26 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I will no longer buy Aguila ammo after the number of jams in my Ruger. I like Fiocchi.
    Black Wolf and TTU19[OP] like this.
  8. Jul 2, 2018 at 7:30 AM
    Rngr188
    Chad
    Harrison AR
    On the extended mag release, some say not to do it as it can get pressed while carrying the weapon and when you go to grab it the mag fall out.
    SouthBoundSteve and ColoradoTJ like this.
  9. Jul 2, 2018 at 7:34 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, I've definitely thought of that so it's probably a good call not to do that one. I do like the extended slide release idea though.
  10. Jul 2, 2018 at 7:41 AM
    Rngr188
    Chad
    Harrison AR
    Check out the 25 cent trigger job, you basically take something like Mothres Mag Wheel Polish and polish the moving components to a mirror shine which gives you a little smoothness in the action. You have to totally disassemble the weapon (slide and frame) but you will learn your weapon while doing so, there are tons of youtube videos on how to do both.
  11. Jul 2, 2018 at 7:44 AM
  12. Jul 2, 2018 at 7:50 AM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Sell it. They are an accident waiting to happen
  13. Jul 2, 2018 at 7:54 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    undercut and stipple is a must. if you wanna get crazy send the slide out to get machined for an RMR and cocking serrations. At the very least a set of trijicon HD's. I do all my own stippling and undercuts. If I can do it anyone can. If its a range gun I would also do extended slide release. If its just a carry gun you can do without it. if you are reloading in a self defense situation then you are in a really rough spot. for a holster I am a fan of Tier 1.
    4x4_Angel and TTU19[OP] like this.
  14. Jul 2, 2018 at 8:02 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    night sights are a must. For Ammo it depends on the purpose. For the range I tend to stick with Winchester white box. It isn't the "cleanest' ammo in the world but it is cheap and I clean my gun after every use anyway. The ammo I use for everyday carry is Hornady Critical Defense. I would try several different brands and find one that works best for you and your weapon.
  15. Jul 2, 2018 at 8:13 AM
    Some good suggestions on here.
    Mine are simple:
    -A good set of sights.
    -Practice, practice and get really good with your 19. I’m not going to discredit any other suggestion, but right out of the box, the G19 is more accurate than most shooters. I would spend my time developing good habits and accuracy. Speed follows these two skills.
    romad86, gosolo, ToyoMafia and 16 others like this.
  16. Jul 2, 2018 at 8:36 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I've seen the undercut and will probably do that for sure eventually. I think it would really help me and my grip. I have seen those that custom the slide and it looks so bad ass. I may also eventually do that, but probably leave it as is for now.
    On the Trijicon HDs, do you like the orange, or yellow fronts? Also, I'm assuming the rear sights glow as well right? I need to do more research on them.
    Thanks for all the info!
  17. Jul 2, 2018 at 8:43 AM
    15whtrd
    15whtrd Mr. Blonde
    Is that because you’re anti-gun, or this gun has a specific problem? Not starting shit. Just want to know. And I will leave it at that.
    gosolo, 831Tun, 5.7TRDProm and 5 others like this.
  18. Jul 2, 2018 at 9:34 AM
    War_Wagon312
    Rich
    Stock horse
    I like the yellow. Rear sight is a u instead of notch which I like better. And yes rear glow. Try them.
    gosolo and TTU19[QUOTED][OP] like this.
  19. Jul 2, 2018 at 9:34 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Hyperbole much?
    gosolo, HighDesertSurfer and 15whtrd like this.
  20. Jul 2, 2018 at 9:45 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    I'm going to guess his argument is going to be "because there is no safety"
    @OP get trijicon night sights
    I also got vickers mag floor plates so I could get the mags out easier if I have a doublefeed.
    gosolo, TTU19[OP] and 15whtrd[QUOTED] like this.
  21. Jul 2, 2018 at 9:49 AM
    Berettafan
    Berettafan New Member
    2017 CM
    great all around gun! it was my first handgun as well.
    do nothing to it until you have put a thousand plus rounds through it and are competent with the gun. practice with a purpose. lots of great drills on youtube.
  22. Jul 2, 2018 at 10:07 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Your first gun.. you need NOTHING except ammo and practice. Master that gun before you modify it. My $.02
    CNE0207, romad86, gosolo and 13 others like this.
  23. Jul 2, 2018 at 10:11 AM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    Night sights are a good place to start on my 26 I found the most useful mod was the extended mag release there was times at the range I had trouble getting it to release with 1 hand.
    gosolo and TTU19[OP] like this.
  24. Jul 2, 2018 at 10:18 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I get it, and that's the plan. But the first few things I listed seem pretty reasonable out the gate as just added accessories. As far as the extended releases, slides, etc.; it would be cool to see what others have done, but dont plan to do those until much later, if at all.
    gosolo likes this.
  25. Jul 2, 2018 at 10:27 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    One thing to consider with the extended slide release is where your thumbs are when shooting. I ride high thumbs and the extended release can induce malfunctions for me. I am not a fan of them.
  26. Jul 2, 2018 at 10:38 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    After a thousand few rounds on my g19 I changed out the trigger with Agency Arms..so far so good.
    Tripleconpanna, gosolo and 4x4_Angel like this.
  27. Jul 2, 2018 at 10:48 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    :confused:o_O
  28. Jul 2, 2018 at 12:07 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
  29. Jul 2, 2018 at 3:00 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    What kind of cases do you use when like taking it to the range? Do you use the one it came in? I figure there has to be a better one.
    gosolo likes this.
  30. Jul 2, 2018 at 3:13 PM
    saybng
    Gary
    Ventura CA
    I use the one it came with,..I would use the $$ on ammo rather then getting a new case...go to the range and keep shooting then mod after..
    gosolo, ToyoMafia and 5.7TRDProm like this.
