Foam Cannons - There is a Difference!
Discussion in 'Detailing' started by Riskyguy, Jul 2, 2018.
  1. Jul 2, 2018 at 5:31 AM
    Riskyguy
    Riskyguy [OP] New Member
    Stewart
    2018 Tundra SR5 Crewcab
    I bought the cheap Amazon DUSICHIN SFL-001 foam cannon a couple of months ago. Mediocre results with my electric pressure washer. I tried upgrading it by using a different nozzle with a 1.1 MM orifice- no luck with that. I borrowed my son's Chemical Guys Torque cannon over the weekend and used the same pressure washer. The difference was amazing. I got a nice thick layer of foam with it. You really do get what you pay for! I am sure that other higher cost cannons will also do a great job.
    1 person likes this.
  2. Jul 2, 2018 at 6:21 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    At first I saw you were using an electric pressure washer, and I thought that was where your problem was. The fact that you got better results using the same PW on an expensive cannon is interesting though. My cheap Amazon one has no problem making a nice thick layer of foam, and if it ever goes out I would buy it again. I could buy 4 of them for cost of one of the others.
  3. Jul 2, 2018 at 6:34 AM
    Riskyguy
    Stewart
    My electric washer only puts out 1.2 GPM. I was surprised at the difference between the 2 cannons.
  4. Jul 2, 2018 at 6:50 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    I got the one off Amazon as well and had mixed feelings, until I dialed in the settings on it and got it where, I think, it should be. I'm happy with the $20.00 I spent.
    MotoTundra likes this.
  5. Jul 2, 2018 at 6:57 AM
    War Machine
    War Machine SSEM # 5 3MW
    I have an electric pressure washer, and a cheap Amazon foam cannon. I’ve gotten excellent results from both. My pressure washer is 2200 psi, and 1.3 gpm.
  6. Jul 2, 2018 at 7:10 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    We use both at my shop, I'd never be able to tell the difference, other than my pocket being an extra $60 lighter from the CG brand.
  7. Jul 2, 2018 at 7:17 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    Same results here. I have the cheap Amazon one and my in law has the Chem guys expensive one. He was so pissed when he saw mine he wished he could return it.
    Save your money and get the Amazon one
  8. Jul 2, 2018 at 8:24 AM
    Riskyguy
    Stewart
    I wanted the cheap gun from Amazon to work. I am going to give it one more try this week. I have adjusted all of the settings previously but got very little foam. I bought a 3/4" garden hose this weekend and will see if the additional water volume makes any difference.
  9. Jul 2, 2018 at 8:28 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    are you using the same soap, and soap to water amounts for the test?
  10. Jul 2, 2018 at 8:29 AM
    93civEJ1
    93civEJ1 New Member
    Tennessee
    2014 White CM Platinum
    whats the gun from Amazon? I am curious if it will work with my harbor freight electric pressure washer.
  11. Jul 2, 2018 at 9:23 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
  12. Jul 2, 2018 at 11:16 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    I use a cheap ass Amazon foam cannon with Adams Soap and a Rigid 2800PSI gas pressure washer.
    Never a problem laying down THICK soapy foam.
    nk1794 likes this.
  13. Jul 2, 2018 at 11:26 AM
    War Machine
  14. Jul 2, 2018 at 11:30 AM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I use this one from Amazon I believe I paid $35 and is amazing really thick layer of foam all the time I use it with my 3000psi Ryobi gas pressure washer even with my 2100psi electric washer
    Installer Champ Foam Blaster Gun - 1L Lance Cannon, 1/4" Quick Connector w/Soap Measurement (mL) & Pressure Dial - 90 Day Warranty https://www.amazon.com/dp/B075RRHR1Z/ref=cm_sw_r_cp_api_P6MoBbY1KYHTS
  15. Jul 2, 2018 at 4:19 PM
    Tundra Fan
    Toby
  16. Jul 2, 2018 at 4:35 PM
    Antlers
    Antlers New Member
    Alaska
    2018 SR5 TRD Cement
  17. Jul 3, 2018 at 4:27 AM
    SnrDisregardo
    Wade
    IL
    Have the same setup. Once you figure out your soap ratio and where your nozzle adjustment and water to soap on the top, works great.
  18. Jul 3, 2018 at 4:58 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Decisions decisions...
  19. Nov 2, 2019 at 7:27 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have absolutely zero problems with my under $20 MATCC foam gun from Amazon using my karcher electric power washer. I truly believe spending more is a huge waste
    War Machine likes this.
  20. Nov 2, 2019 at 8:48 AM
    Jota21
    Jota21 New Member
    pardon my ignorance, but do you just put regular car wash soap in the reservoir and use it to soap up the car? Assuming you still need to use a sponge/brush to work the dirt off? Then disconnect the foam and rinse with the normal pressure washer wand?
    Off topic: Are you guys shutting down the pressure washer between soaping/rinsing, or just trusting that unloader valve doohickey that is supposed to keep the pump from getting too hot?
  21. Nov 2, 2019 at 8:56 AM
    Pudge
    CT
    I fill the bottle with hot water almost to the top then an ounce or 2 or soap. Then foam the car and let it dwell on there for a few minutes. Then rinse off. Sometimes i will foam it again and do my 2 bucket wash as normal but the car is foamed, this doesnt work when its hot outside.
    I leave my power washer on the whole time, it shuts off when I release the trigger. I use an electric unit.
  22. Nov 6, 2019 at 11:51 AM
    briarpatch
    briarpatch New Member
    Yes...regular car soap in the cannon. I use the first soak as a pre-wash...then re-foam the car for the one bucket/multiple mitt hand wash. I don;t have to shut off my electric (SunJoe SXP3000)...the pump stops running when I let go of the trigger
    Pudge likes this.
