Slowly getting the bugs out
Discussion in 'Towing & Hauling' started by galaxyflyer1, Jun 24, 2018.
  1. Jun 24, 2018 at 6:36 PM
    galaxyflyer1
    galaxyflyer1 [OP] New Member
    Bob
    20180624_155927.jpg Hey all. Using my 2017 5.7 SR5 double cable( with a TRD rear Sway bar) to pull my 16' TT. Fully loaded probably around 3800 lbs of towing. Tongue weight is about 400 pounds.
    With my bike and gen also in the bed, the back sags about 3". So I opted to go with Firestone air bags instead of a weight distribution system because of the low weight rating of the trailer's single axle. About 70 lbs in each bag brings the truck back level. The ride does feel much better and my "boating effect" seems to be gone.
    What I'm noticing now is (or it was always there), kind of a jerking feel making the truck rock a little from front to back. This is during driving straight down the road. I do use a trailer hitch sway bar system and when watching the mirrors, I don't see sway. Just kind of jerking actions as if I was hauling a huge water tank that is slushing. That's probably the best why to describe it. Before using the airbags, the trailers nose was down about 3 inches. Now looking at it and using a level, It seem to be pertly straight. But I know that its always best to in error with the nose slightly down. Is this perhaps my issue? I can't move any weight around in the trailer because I really don't add much but cloths and fill the stationary trailer water tanks. Maybe I should lower the hitch an inch or so?
    Your thoughts please,
    Bob
    ColoradoTJ likes this.
  2. Jun 24, 2018 at 6:38 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Jun 24, 2018 at 6:46 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    From that picture it looks like the camper tongue is up a little, you need to drop it down some. Also the airbags will make your truck ride very different, I added a set to my wifes Tacoma and hate the effect it has on the truck.
  4. Jun 24, 2018 at 7:18 PM
    Hey Bob.
    What camper do you own, make and model.
    How do you know the tongue weight is 3-400 lbs?
    TXMiamiFan likes this.
  5. Jun 24, 2018 at 7:22 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Is that an 82 XL500?
    D1227 and Pudge like this.
  6. Jun 24, 2018 at 7:22 PM
    galaxyflyer1
    Bob
    OK Thank you. I think that will be my next test.
  7. Jun 24, 2018 at 7:27 PM
    The reason I ask is 70 lbs in the bags is....A Lot.
    I used to have 70-80 lbs on this set up.
    Watt maker likes this.
  8. Jun 24, 2018 at 7:32 PM
    galaxyflyer1
    Bob
    1983 Honda 250XLR my baby! Trailer is a 2018 Cherokee Wolf Pup 16BHS. Trailer GVWR is 3917. Axel tag indicates 3500 max. But what about the extra 417 Pounds? well that's distributed to go to the tongue according to the specs. So, for those who wonder why I don't use a WDS, is that much of the truck bed weight will go straight to that under rated trailer axel.
    Pudge likes this.
  9. Jun 24, 2018 at 7:38 PM
    galaxyflyer1
    Bob
    Maybe I can go with less PSI in the bags. What are the symptoms of over airing?
  10. Jun 24, 2018 at 8:14 PM
    So your capacity and tongue weight are tied together, but your capacity is higher than tongue weight.
    So let’s just say you have 1500 lbs of capacity. For ease of things, let’s just say you have a max tongue weight of 900 lbs.
    Trailer tongue weight is 500 lbs with everything inside the camper.
    So you have 400 lbs left in tongue weight, 1100 in capacity.
    Let’s say you are 200 lbs, bike is 200 lbs and generator is 100 lbs.
    You still have 600 lbs of capacity, but getting close to the 3/4 capacity of your truck. It will sag.
    You need 3/4” of rake to make the traction control happy on Tundras. Try using less air in the bags, and I will tell you why.
    The water splashing effect you have is very common on TT, and it’s called porpoising (kinda like how a dolphin swims, or sea saw effect). What makes this worse is you have a single axle trailer with the axle positioned behind centerline of the trailer. This tows and reverses like a dream, but for comfort, your SOL. Then the suspension is cycled, the trailer is like a huge lever on your rear suspension. Rear suspension compresses and rebounds violently (welcome to leaf springs, and you even made it worse with airbags), this action tosses the tongue upward and that’s why you feel the sea saw effect.
    Some things you can try. Lower the bag pressure and let your factory suspension absorb more.
    Shocks that are tunable and really slow down the rebound. This is pretty expensive. Another route is getting a Load Distrabution Hitch.
    https://www.equalizerhitch.com/find-your-hitch-size
    Sell the air bags. They suck for anything other than heavy loads over the axle in the bed or a 5th wheel/GN setup.
    If you live in CO, you can test my LDH out to see if it helps. Even help you set it up.
  11. Jun 24, 2018 at 8:26 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I have a TT similar in size and I put 25 psi in the bags to make it level...
  12. Jun 24, 2018 at 8:35 PM
    Something doesn’t sound right does it Jeremy?
    Black Wolf and jeremyd[QUOTED] like this.
  13. Jun 24, 2018 at 8:36 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    nope
  14. Jun 24, 2018 at 9:02 PM
    galaxyflyer1
    Bob
    Excellent Point. You have described this perfectly for me. Before I get rid of the bags, I will try less air. You see, I measured the wheel well before loading (39") then aired up to get that back after loading. I think I hit a point during air up, after so much air, the movement was very slow. Perhaps that's were I should have stopped? Should I leave some sag? when you say 3/4" rake, you mean ass up 3/4" more than front right. I can't do a WDS on that trailer. Axel is to under rated.
  15. Jun 24, 2018 at 9:06 PM
    I would try the bags at 45 psi and drop 5 psi until your desired result.
    You need 3/4” higher in the rear than the front. So if the truck was completely level, bump up the air bags until another 3/4” upward movement.
    D1227 and jeremyd like this.
  16. Jun 24, 2018 at 9:21 PM
    galaxyflyer1
    Bob
    One last question if you can answer this. How much rake is usually present on a stock Tundra. I was assuming that by adding air to achieve the "before measurement" put me back to stock, which may be the wrong way to do it. Hoping that a stock Tundra has more than 3/4 rake, less air may do the trick for me and still have plenty of rake.
    Thanks for all your time.
  17. Jun 24, 2018 at 9:25 PM
    I don’t have a good solid answer since a Tundra is no longer in the garage. One of the fine members on this forum can answer that for you. If I had to guess, 2.75-3”.
  18. Jul 4, 2018 at 2:08 AM
    Update?
    15whtrd likes this.
  19. Jul 4, 2018 at 1:39 PM
    galaxyflyer1
    Bob
    I'm taking your advice. The next time that I hook up and go camping, I will use just enough air so that there will be a slight rake. I'm with you. I think that pumping the air bags up to create the stock height (70 lbs) took out a lot of the "working" suspension. Gotta find that golden spot. After my next trip (perhaps in a couple of months) I will update everyone.
    Thanks for all your help.
    Bob
  20. Oct 1, 2018 at 3:07 PM
    galaxyflyer1
    Bob
    OK, finally went on another camping trip and wanted to update my air bag questions.
    Looking back, I think I inflated the bags PRIOR to attaching the trailer. And I pumped them up to 50 #.
    This time I pumped them to about 25 # with trailer on and that made the truck sit level. It felt much better.
    Thanks for all your help,
    Bob
  21. Oct 2, 2018 at 2:23 PM
    PMG
    PMG New Member
    awesome..
