Dan's Mid Travel Overlander Build
Discussion in '2.5 Gen Builds (2014-2021)' started by GiantsFanDan, Apr 12, 2018.
  1. Jun 8, 2018 at 8:04 PM
    #181
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    If I remember right this is a two way breather so putting this up there instead of the stock one should suffice just like putting an ARB. Or just get a small k&n breather filter if you want to be fancy. No need to get ARB if you already ran it up there.
  2. Jun 8, 2018 at 8:08 PM
    #182
    15whtrd
    15whtrd Mr. Blonde
    Ooo I like saving money LOL.
    Once I saw the ARB kit I saw that it came with everything. I didn’t want what I did to be a waste of time so I was just looking for a universal ARB breather. But this seems like a better idea. Plus I like Toyota parts.
    Thanks for replying
    831Tun and BlueBottle[QUOTED] like this.
  3. Jun 11, 2018 at 7:55 PM
    #183
    GiantsFanDan
    GiantsFanDan [OP] New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    June 10th Poker Flat Trip
    IMG_3602.jpg IMG_3607.jpg IMG_3615.jpg IMG_3614.jpg IMG_3579.jpg IMG_3612.jpg IMG_3623.jpg IMG_3604.jpg IMG_3605.jpg
  4. Jun 11, 2018 at 8:27 PM
    #184
    GiantsFanDan
  5. Jun 11, 2018 at 9:05 PM
    #185
    BlueBottle
    '16 Platinum 4x4
    See fine print
    How did the suspension handle? Are you happy with the purchase?
  6. Jun 11, 2018 at 9:16 PM
    #186
    GiantsFanDan
    It handled great and I'm very happy with my purchase.
    TheBeast, dcsleeper408 and BlueBottle like this.
  7. Jun 15, 2018 at 9:31 PM
    #187
    GiantsFanDan
    SDHQ Hood Mounts and Vision X 4.5 lights installed. Wiring has to wait till after Father’s Day weekend though.
  8. Jun 15, 2018 at 10:05 PM
    #188
    TheBeast
    TheBeast The Beach
    do I spy another Tundra back there ? gen 2 ftw :spy::mudding:
    joonbug and GiantsFanDan[OP] like this.
  9. Jun 16, 2018 at 7:21 AM
    #189
    GiantsFanDan
    Yeah. Good eye! My parents have 2nd gen crewmax platinum.
    Erichudgins and TheBeast[QUOTED] like this.
  10. Jun 21, 2018 at 7:56 PM
    #190
    GiantsFanDan
    @Caliraisedled Switch Controller. Installing this weekend to control my Vision X lights and any future devices
  11. Jun 23, 2018 at 7:41 PM
    #191
    GiantsFanDan
    @Caliraisedled 8 switch controller installed and Vision X 4.5's wired up to the switch controller. Fun Saturday Project!
  12. Jun 26, 2018 at 2:39 PM
    #192
    Caliraisedled
    Caliraisedled New Member
    Jake
    Thanks for the pictures looks great!
  13. Jun 26, 2018 at 3:17 PM
    #193
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Tagging along. I should have mine very soon.
    Any reason you decided to install there vs the card holder near the center console?
  14. Jun 26, 2018 at 4:20 PM
    #194
    GiantsFanDan
    Just seemed to look better to me. Plus it keeps me from sticking crap in that spot
    GodlessPro likes this.
  15. Jun 27, 2018 at 10:03 PM
    #195
    GiantsFanDan
    Thanks @jlee BayAreaMetalFab for the BMC plates. Installing Saturday or Sunday with my Dad's help welding. We shall see how bad I am at welding haha
  16. Jun 28, 2018 at 5:43 PM
    #196
    GiantsFanDan
    New lens covers for Vision X lights
    Sunnier and Erichudgins like this.
  17. Jul 1, 2018 at 4:00 PM
    #197
    GiantsFanDan
  18. Jul 1, 2018 at 10:46 PM
    #198
    GiantsFanDan
    Apparently action shots were taken behind my back
    F5616061-094D-462A-AF28-C3B0AE8B17D9.jpg 176C0321-C8D1-400C-AACE-E51353BF86A3.jpg
    Sunnier, aperezsh, blue16 and 3 others like this.
  19. Jul 1, 2018 at 11:49 PM
    #199
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Got rear facing chase lights?
  20. Jul 2, 2018 at 8:15 AM
    #200
    GiantsFanDan
    I’m looking for some.
    831Tun[QUOTED] and GodlessPro like this.
  21. Jul 2, 2018 at 8:25 AM
    #201
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Nice job Dan. Those lights are gonna get used this weekend.
  22. Jul 2, 2018 at 8:29 AM
    #202
    DividedSky
    Jeff
    Would you mind taking a few more pictures of where you made your connections?
    Specifically the ground, ignition and light inputs.
  23. Jul 2, 2018 at 9:23 AM
    #203
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Here's a photo of where I ran a Blue Sea ground bus beneath the hood trim/ seal. I used the OEM ground on the inner fender as a kind of junction.IMG_20180116_095756267.jpg
    aperezsh, GodlessPro and joonbug like this.
  24. Jul 2, 2018 at 6:02 PM
    #204
    GiantsFanDan
    I can in a bit. I tied into my LED DRL’s fuse tap for the ignition. Ground I just used one one of the body grounds on the driver side. For 12v power fuse tap I just used a empty fuse spot in the fuse box.
  25. Jul 2, 2018 at 6:03 PM
    #205
    GiantsFanDan
    Thanks Joon!
  26. Jul 5, 2018 at 8:57 AM
    #206
    DividedSky
    Jeff
    Sorry to bug you, but can you clarify something for me?
    The instructions state that you need to connect Ground, Lights and Ignition...
    So the LED DRL you connected is your "Lights" wire?
    Ground is Ground, that's easy.
    Ignition is the empty slot you mention above? Have you tested it to ensure that it doesn't have power when the ignition is off?
    If you don't mind taking those pics, it would really help.
  27. Jul 5, 2018 at 9:11 AM
    #207
    GiantsFanDan
    I used a fuse spot that does get power without the truck being on. Just in case of future needs. I.e: bed lights or lights when camping.
    Ignition Wire goes to the LED DRL fuse tap I have for my 2018 headlight harness.
    Light wire goes to a wire to detect when headlights are on so tap into you parking light wire.
  28. Jul 5, 2018 at 9:23 AM
    #208
    DividedSky
    Jeff
    GiantsFanDan[OP] likes this.
  29. Jul 5, 2018 at 9:32 AM
    #209
    DividedSky
    Jeff
    Ok, I'm the first to admit that I'm super dense when it comes to electrical. I need things spelled out as if you were teaching a 5yr old. ;)
    There are three wires. Ground went to ground... Probably inside the hood compartment.
    Did your ignition go to the empty slot in the fuse box, or did it go to the LED DRL fuse tap?
    Lights wire - Is this what went to the Empty slot or did it go to the LED DRL?
    I would assume the Ignition went to the empty slot and Lights went to the DRL, but that is not what you stated above.
    Btw, I like your idea of using a slot so that you can run camp lights etc without the vehicle being on... That's exactly what I want to do!
  30. Jul 5, 2018 at 10:10 AM
    #210
    GiantsFanDan
    Red fuse tap for 12v went to an empty fuse spot in the main fuse box (I want power anytime). If you don't that, then you need to break out your volt meter to test what empty fuse spot doesn't have power when the truck is off.
    Ground can go to any ground on the truck.
    Ignition wire went to my 2018 LED headlight harness that has a fuse tap already. Did this because the DRL's only come on when the ignition is on.
    Light wire goes to your parking light wire. Use the small bulb wire for your side amber marker light from your headlight.
