2018 Tundra LED headlight wiring info with diagrams
Discussion in 'Lighting' started by thomasbus337, Sep 6, 2017.
  1. Mar 31, 2018 at 2:37 PM
    #841
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    LKSR5-14[QUOTED] likes this.
  2. Apr 10, 2018 at 4:02 PM
    #842
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    Special shout out to iHacker for his harness and especially his personal support during this project. I broke the project up into two days on my 2015 limited. I spent about 4 hours doing the stuff in the cab and bringing the wires forward under the hood on the first day. Then today I spent about 6 hours taking care of everything in the front. Everything went very smoothly. The lights arrived in like 2 days from Roman at Cool Springs.
    3 pages of private discussion with iHacker, he really went above and beyond, laid everything out for the project very clearly. the new light housings are great. I could not be more satisfied with the function of the system, it's exactly how you would expect from the factory.
    if you're taking on this project its a good opportunity to do the anytime fog light mod while you're right there working with the wiring harnesses under the dash.
  3. Apr 11, 2018 at 5:42 AM
    #843
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    I would like to join you and give great feedback for all support and great harness. Thanks @iHacker and thanks for great quality harness.
    iHacker likes this.
  4. Apr 18, 2018 at 5:19 PM
    #844
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    Did the 2018 conversion on my 2014 1794. Used the TRS cable. $90, no Morimoto, super clean install and extremely easy. Their instructions for repinning the blinker are incorrect but all your guys’ photos helped fix that. Been running it for about a month and no issues.
  5. Apr 19, 2018 at 11:43 AM
    #845
    B737
    Jersey Shore
    how does the DTRL dimming feature work with the TRS harness? when you use your high beams are the low beams on simultaneously?
  6. Apr 19, 2018 at 3:16 PM
    #846
    MT1794PRO
    Paul
    2014 MGM 1794 CM
    On my 1794 the dimming is working properly as well as dual beam on high.
  7. Apr 19, 2018 at 3:51 PM
    #847
    B737
    Jersey Shore
  8. Apr 20, 2018 at 6:25 PM
    #848
    walter93
    walter93 a Newbie: speak slowly and use small words
    Walter
    Houston
    2017 White Tundra SR5 crewmax 4x4 5.7
    TRD air filter TRD air maximizer TRD dual exhaust Gatortraxx MX rolling tonneau cover
    So am I understanding that all I need is this Morimoto harness adapter and OEM LED headlights and I'm in business? I have a 2017 SR5 with amber DRL and halogens with the level feature that is a roll knob on the dash - is this "autolevel" or "manual level"?)
  9. Apr 21, 2018 at 8:19 AM
    #849
    B737
    Jersey Shore
    a great thread to use is the FIRST post of ihackers harness for sale thread in the merchandise subforum. all the info is there and it walks you through the entire install step by step. admittedly, i did not find that until after my install but ihacker talked me through.
    the TRS harness is intriguing and very clean, i havent seen much info on it, no one has posted a dedicated thread detailing it and discussing which is odd. the nice thing about ihackers harness is he does tie into the factory DTRL circuit so the new LEDs work exactly as they would from the factory, in regard to dimming, emergency brake on/off ect.
    as far as your leveling feature, its manual control (in owners manual)
    if you are on the fence order the lights from Roman. honestly there was nothing wrong with the old halogens to me, i could see just fine. But the new LED lights are a huge improvement, they look great on the vehicle. I wish toyota kept the lower LED bar on like on the previous platinums, it was more subtle i liked it better, im indifferent to the wrap around LED.
  10. Apr 21, 2018 at 10:45 AM
    #850
    walter93
    Walter
    Houston
    I read several pages of posts starting with the FIRST post, but this last one on the TRS harness seems to do the same thing but much simpler and cleaner. It also seems like an easier install. That's what prompted my questions. Thanks for the level feature response. I wanted to confirm what I suspected and didn't think to look in my manual (DOH!).
  11. Apr 21, 2018 at 10:58 AM
    #851
    B737
    Jersey Shore
    It looks like ihacker has released another version of his harness this afternoon with no morimoto controller!
  12. Apr 22, 2018 at 4:17 PM
    #852
    tonktank
    tonktank New Member
    Sandy
    Bremerton WA
    2017 SR5 Tundra Crewmax
    Just put mine in today and I think they look amazing.
    BlueBottle and B737 like this.
  13. Apr 22, 2018 at 5:11 PM
    #853
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Still love mine!
    B737, LKSR5-14 and tonktank like this.
  14. Apr 22, 2018 at 5:38 PM
    #854
    tonktank
    tonktank New Member
    Sandy
    Bremerton WA
    Your truck is gorgeous BlueBottle. Working on painting my bumpers next to get rid of the chrome.
    BlueBottle likes this.
  15. Apr 22, 2018 at 5:57 PM
    #855
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks. That will transform your truck!
    I wanted a blue Tundra but they are pretty rare.
  16. Apr 25, 2018 at 10:10 AM
    #856
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Depending how you look and quality wise
    B737 likes this.
  17. Apr 25, 2018 at 10:15 AM
    #857
    B737
    Jersey Shore
    this^ . i feel like i need a shower after anything morimoto or TRS. my experience is it is typically complete junk.
    I will prob purchase ihackers 2.0 version harness as a spare to have on hand for when the morimoto controller ****'s the bed.
    Pudge and LKSR5-14[QUOTED] like this.
  18. Apr 25, 2018 at 11:10 AM
    #858
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I got iHacker harness first version, and it's great quality, very simple and anyone could do the swap with his explanation.
    Probably i would get second version but at the time he did not make new versions without motocontrol
    B737[QUOTED] likes this.
  19. Jun 16, 2018 at 5:56 AM
    #859
    Master_tundra
    Master_tundra New Member
    2017 MGM limited
    Mine has been working perfectly for the past 6 months. Just last night I niticed the left headlight and DRL stopped working. Checked the fusses and they are good.
    What should look at next?
  20. Jun 17, 2018 at 7:17 PM
    #860
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Did you check ballast?
  21. Jun 21, 2018 at 12:48 PM
    #861
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    Did the 2018 headlights swap,best mod to date! I use the TRS harness, hooked it up according to their instruction. Everything works, but wasn’t able to control/dim the drl. So I switch some wire, add a relay.Now everything operate as it should! Huge shout out to Thomasbus337, ihacker and everyone else who contributed on this thread!!!
  22. Jun 21, 2018 at 12:51 PM
    #862
    Hobbesdsm
    Eddie
  23. Jun 21, 2018 at 6:08 PM
    #863
    Redlineaz
    Redlineaz New Member
    Does anyone have pictures of the black housing LED headlights? I have the chrome already, but I read there is a black housing set now available, so I ordered a set of black ones at my local dealer using the part numbers that I found on this forum, and they arrived chrome.
    Does anyone have them with the black housing?!? I can't find pics online to see what they look like
  24. Jun 21, 2018 at 7:59 PM
    #864
    Hobbesdsm
    Eddie
    Those are the black housing on my truck.
    Redlineaz likes this.
  25. Jul 13, 2018 at 9:20 PM
    #865
    Redlineaz
    Thanks man! I ended up going with them. I was a little bummed to discover they were black chrome, not true black, and it was a tough pill to swallow being that I already had the 2018 chrome version lights, and dished out another big chunk of change just to get a slightly darker shade of chrome. :( but it looks good at least, I dunno if $800 dollars worth of good, but oh well lol.
  26. Jul 23, 2018 at 2:32 PM
    #866
    trooper669
    trooper669 New Member
    2018 1794 MGM
    TRD front and rear sway bars/ CAI. Recon smoked tail lights. LED Bed Lights. LED grill lights Bilstein 6112 front and 5100 rear. RC 1” rear block. RC lower grill LED bar. Nitto Ridge Grapplers 295x60x20 on Fuel D-251 couplers. SDHQ ABS covers. Rear under seat storage. Body mount rebuild. Color matched mirrors, handles. Raptor step bars.
    HEy man, which tow hooks do you have on the front of your MGM? Looks great!
  27. Jul 23, 2018 at 3:07 PM
    #867
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Stock. Used removable Berliner spray to paint them.
  28. Jul 24, 2018 at 3:53 AM
    #868
    trooper669
    2018 1794 MGM
    Thanks. There is never a stop to all the cool stuff people do to these trucks.
    BlueBottle[QUOTED] likes this.
  29. Jul 24, 2018 at 4:24 PM
    #869
    BlueBottle
    '16 Platinum 4x4
    See fine print
    At least this one is cheap!!!!
  30. Jul 25, 2018 at 9:12 AM
    #870
    trooper669
    2018 1794 MGM
    Yeah, right!!! Everything else is NOT!!!
