Removing tint with trash bag
Discussion in 'Off-Topic Discussion' started by BlueBottle, Jun 19, 2018.
  1. Jun 19, 2018 at 8:13 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    we bought another vehicle that has tint but it is too dark and I want to remove it. Anyone ever try this????
    What’s the best method?
    https://youtu.be/XTmgN18KEx8
  2. Jun 20, 2018 at 2:28 AM
    riley804
    riley804 New Member
    2018 toyota tundra
    when I used to do car detailing many years ago, we often had to take the tint off of the cars. we use this : https://www.homedepot.com/p/Warner-...BEgIWMvD_BwE&dclid=COi75vz14dsCFUFvwQodY_oMhA and some glass cleaner . take the blade and start at the top of the window and just get the tint to start peeling and then you can use your fingers to pull the tint off. you use the glass cleaner to remove the glue. back windows with the defroster....maybe try that garbage trick as if you use a blade and hit the element, that element is ruined.
    BlueBottle[OP] likes this.
  3. Jun 20, 2018 at 3:11 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    I have used the ammonia with the trash bag method and it works like a champ. Just make sure you have all the doors open and cover interior pieces with a towel while applying. Depending on how bad the tint is you may have to do it more than once.
    -Jason
  4. Jun 20, 2018 at 10:15 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks fellows! The car is a 2015 so the tint can’t be too old.
  5. Jun 20, 2018 at 10:24 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I have always used a heat gun heat evenly and start peeling off from a top corner. Keep the window nice and hot and tint should come off easy in 1 piece since its fairly new. When window cools down i take window cleaner and scrape it with a blade to make sure all the adhesive is off and ready for next tint
  6. Jun 20, 2018 at 10:56 AM
