  1. Sep 7, 2015 at 8:47 AM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Saxon123, Hasteen and Bob like this.
  2. Sep 7, 2015 at 1:00 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Sitting waiting for paint;)
  3. Sep 7, 2015 at 5:07 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Waiting to see the final product.
    Im on hiatus with mine so no posting.
  4. Sep 9, 2015 at 6:13 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
  5. Sep 9, 2015 at 6:58 PM
    Mike Tread lightly.
    south carolina
    That box looks familiar. So much for the fragile writing on it.
    Looking good man.
    Slicksilver19 likes this.
  6. Sep 10, 2015 at 7:18 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    ;) it served it's purpose
    tigerfan51 likes this.
  7. Oct 4, 2015 at 12:19 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Truck hinge-001.jpg Truck hinge-002.jpg Well, not too exciting, but i fixed the rear pop out window hinges yesterday. One was completely broken and the other was cracked through. Cheers.
  8. Mar 7, 2016 at 10:41 AM
    shorty8341
    shorty8341 New Member
    Springfield MO
    2021 Tundra TRD Sport 4x4
    Added TRD PRO 18 in wheels, and TRD dual exhaust. More to come.
    Put on a Volant CAI, and Magnaflow cat back exhaust single in, single out 2 1/2 in to 3 in.
    Tdog111, fhorton50 and 1GenTundraz like this.
  9. Mar 7, 2016 at 12:33 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Fuck yeah^^^
    Do me a favor, let me know if u set a p0101 code in the near future. Probably while towing, I'd be curious
  10. Mar 10, 2016 at 8:55 PM
    rdp5008
    rdp5008 New Member
    Russell
    2001 Tundra SR5 2wd
    ARE Camper Shell
    ^^^^^ I did this today!
    Also replaced the struts on my camper shell so I don't get knocked in the head every time I open the back camper shell window.
  11. Mar 11, 2016 at 5:15 PM
    shorty8341
    Springfield MO
    I will let you know if I get a code next time I pull anything. Probably won't be for a while.
  12. Mar 11, 2016 at 5:17 PM
    shorty8341
    Springfield MO
    Just ordered JBA headers. I will put those on in about a week, along with replacing my water pump, lower ball joints, and fixing my oil leak from my right side valve cover.
  13. Mar 11, 2016 at 6:57 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Passenger side valve cover? Probably not the valve cover.... can seals are known to leak,specifically the pass side. Kind of an extensive repair, intake camshaft has to come out.
  14. Mar 11, 2016 at 8:11 PM
    shorty8341
    Springfield MO
    If it is im not worried. Not too hard of a repair. I'm a toyota tech lol. But usually if you remove the cover and front cap, replace the gasket and put down fipg your good. Most of the ones I've seen weren't the cam seal. But if is then I'll take care of it.
    Ronnie207 likes this.
  15. Mar 11, 2016 at 8:43 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Well then u know how to do it; ) I'm a tech too, where u work? I did both mine and replaced seals, stupid not to since ur in there.
  16. Mar 13, 2016 at 8:26 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I sold mine to my dad. Now hunting for a third gen.
  17. Mar 16, 2016 at 11:18 AM
    garnaz
    garnaz New Member
    Do these help with holding latch tighter?
    Where can they be found?
  18. Mar 16, 2016 at 10:23 PM
    rdp5008
    rdp5008 New Member
    Russell
    2001 Tundra SR5 2wd
    ARE Camper Shell
    T2ndLife likes this.
  19. Mar 17, 2016 at 1:14 PM
    garnaz
    garnaz New Member
  20. Apr 3, 2016 at 3:13 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    Changed oil and filter today. Put Mobil 1 5w 30 in with Toyota filter. Changed out the air filter to K&N Filter. Installed a exhaust tip on the tailpipe. Cut off 3 inches of the tailpipe so it doesn't stick out too much. I like the look, eventually hope to put on a Magnaflow muffler to give it more of a throaty growl.
  21. Apr 4, 2016 at 6:54 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Picked up some herculiner from Lowe's with a gift card I had from Christmas
  22. Apr 5, 2016 at 6:24 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I did hurculiner on my taco... lot of work i thought.... works well tho
  23. Apr 5, 2016 at 6:56 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Thanks, I probably scuffed up the paint more than I should have but I wasn't in a hurry.
  24. Apr 5, 2016 at 6:57 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Yes it was more work than I anticipated, but it turned out nice. You rolled it over your plastic Tacoma liner?
    Tundraboy likes this.
  25. Apr 6, 2016 at 12:48 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Hahahaha no, I did exactly what you did.
  26. Apr 7, 2016 at 5:41 PM
    freerider8
    Fairview PA
    Minimal but just had a recent surgery so mods are very limited. Can't drive for two weeks so I am bored out of my mind. Installed new these new lights inside to try and provide more interior lighting. They are ok, not totally sure how I feel about them yet. Old lights are the yellow look, I definitely like the blue look better.
  27. Apr 12, 2016 at 5:02 PM
    shorty8341
    Springfield MO
    Changed out my water pump, new front crank seal, new cam seals, and headers installed.
    Tundra Texan, MooreKen and LIL. H 88 like this.
  28. Apr 15, 2016 at 12:38 PM
    freerider8
    Fairview PA
    Installed the side window covers today now that it is finally warm enough to do so. I posted a before and after photo. I definitely like the look it provides. My only regret is on the drivers side for the rear window the cover is placed a little toward the front of the truck by about an 1/4 inch or so too much and when the window is open it pushes out on the cover. Live and learn, should have opened the window first to do a test run. Just won't open it I guess. Otherwise a very easy install, just have to take your time to line them up good.
  29. Apr 15, 2016 at 5:32 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Which headers!?
  30. Apr 15, 2016 at 10:34 PM
    shorty8341
    Springfield MO
