Fumoto vs EZ Drain...seeking input
Discussion in 'Performance and Tuning' started by porkitt, Jun 14, 2018.
  1. Jun 14, 2018 at 9:05 AM
    porkitt
    porkitt [OP] New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Some members have the Fumoto and I'm not sure of anybody has the EZ Drain. I wanted to ask all of you before I purchase. Any inputs, reviews both good and bad appreciated. Thanks in advance
  2. Jun 14, 2018 at 9:21 AM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    I bought a Fumoto and it is still in the garage. I installed it and was not comfortable with it hanging below the frame. I do easy off-road in CO and was concerned that one rock in the wrong spot on the wrong trail would leave me in the middle of no where. If you have a mall princess then it might not be an issue. I would be willing to sell it.
  3. Jun 14, 2018 at 9:23 AM
    porkitt
    Ian
    Tundra Pro Cement
    No skids?
  4. Jun 14, 2018 at 9:24 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I have skids all the way back to the transfer case, so my oil drain is covered. I still won't install a drain valve - I just don't trust them enough. Maybe if they had a redundant backup (like a screw in plug plus the valve). I am not sure why so many use the Fumoto valve. Some say it is to prevent a mess, some say it makes it easier (which I guess it does, but really, how hard is it to put a wrench on the drain plug and turn it)? Also, you can avoid the mess just by using a funnel. You might get some on your hands - but so what?
    Dougr6, 4x4_Angel and Stroke250 like this.
  5. Jun 14, 2018 at 9:46 AM
    I didn't see any applications for Tundra on EZ website
  6. Jun 14, 2018 at 9:47 AM
    Love my Fumoto, since I'm 6" in air plus heavy duty skid plate not worried about it being hit
  7. Jun 14, 2018 at 9:49 AM
    15whtrd
    15whtrd Mr. Blonde
    I keep going back-and-forth in my mind what it’s going to look like how much it’s going to hang down. That would really suck to knock it off on a simple rock on a trail. I don’t have heavy duty skids yet. When I get it I will mock it up and decide then.
    4x4_Angel likes this.
  8. Jun 14, 2018 at 9:54 AM
    Off road a lot?
  9. Jun 14, 2018 at 9:56 AM
    15whtrd
    15whtrd Mr. Blonde
    Not as much as I’d like to but I have taken it down some pretty rocky trails that have tire ruts so it’s got a highpoint in the center of the trail. I’ve touched my skid a few times before I lifted it.
  10. Jun 14, 2018 at 9:58 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Exactly how far beneath the frame does the Fumoto valve rest?
    15whtrd likes this.
  11. Jun 14, 2018 at 10:05 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    On my Tacoma the drain was in the center of the pan and even the Fumoto with the nipple did not hang down below the skid plate. On the Tacoma removing the skid plate was not necessary to change the filter but it was to remove the drain plug without getting coated in oil. Fumoto made the job a lot cleaner. Not sure with the oil pan plug position on the Tundra that I will be as inclined to add a Fumoto.
  12. Jun 14, 2018 at 11:05 AM
    porkitt
    Ian
    Tundra Pro Cement
    I believe its the EZ Valve 103
  13. Jun 14, 2018 at 11:05 AM
    porkitt
    Ian
    Tundra Pro Cement
    Thanks for all the replies...keep 'em coming
  14. Jun 14, 2018 at 11:48 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I put a fumoto on wife’s Camry. She puts about 150 miles a day on it. It’s great. Waiting for next oil change on tundra to put it on.
  15. Jun 14, 2018 at 12:14 PM
  16. Jun 14, 2018 at 12:48 PM
    15whtrd
    15whtrd Mr. Blonde
    Looks like it’s tucked up there pretty good. I almost got the SX series because the nipple is shorter and you can face the valves anyway you would like. Then you just snap in a plastic adapter for the hose. But it looks like it would’ve only saved maybe a quarter inch.
  17. Jun 14, 2018 at 12:49 PM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    The drain is out side the standard and RW skid plates.
  18. Jun 14, 2018 at 12:55 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I had the Fumoto F103N on my gen1 Tundra for 10 years and never had an issue. Loved it. Installed it and never had a leak ever. I just recently put the same one on my 2016 Tundra. The drains are a little slower but you can drain with a hose directly into your waste container. I usually start the drain and do my filter, then clean up the engine bay for a few minutes, and the drain is done. It's a great product.
    The main difference from what I've researched on the two are Fumoto is solid brass with a fiber washer. EZ Drain is nickel plated brass and uses a rubber oring, no gasket. Other than that, they are identical in operation, it's a ball valve.
  19. Jun 14, 2018 at 3:45 PM
    Ericsopa
    Ericsopa Old man and the sea
    I've used Fumotos on four different vehicles. Never had a problem, never a leak. I don't off road, and don't see that it protrudes at all. It's behind, but not below the plate. I like it because with a short section of 3/8" vinyl hose, you can drain directly into any container of any size. If you have empty quart containers, fine. Drain a quart, close the valve, replace container, drain another quart, etc.
  20. Jun 14, 2018 at 3:52 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'll take whoever doesn't want theirs, ya know to help out a fellow member recoup some cash...Unless it could possibly break while hopping a curb at the mall.
  21. Jun 14, 2018 at 4:10 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Thumbs up on the Fumoto for convenience, mine drains super slow though..
    TXRailRoadBandit73 likes this.
  22. Jun 14, 2018 at 6:40 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Are you guys able to use a socket to torque the fumoto? Same specs as stock?
    831Tun likes this.
  23. Jun 14, 2018 at 7:00 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
  24. Jun 15, 2018 at 8:05 AM
    Tundradrenalin
    Virginia Beach, VA
    you are not able to get a socket over it because of the ball valve latch/handle. You would have to use a crowsfoot wrench.
  25. Jun 15, 2018 at 8:11 AM
    I like that
  26. Jun 15, 2018 at 8:48 AM
    Jengel451
    The Bitterroot, MT
    it's pretty damn secure. One spring loaded seal that won't let oil out unless you put the drain fitting over it, and it has another cap with a seal when you're driving. Really low profile as well.
    Doing 12 quarts of really dirty diesel oil and not getting any of it on you is a HUGE bonus.
  27. Jun 15, 2018 at 9:03 AM
    Until you own a Fumoto valve, you just don't know.
  28. Jun 15, 2018 at 9:47 AM
    Going to order this. Quite simple. Low profile. Solid brass. Less than $40...
    15whtrd likes this.
  29. Jun 15, 2018 at 10:04 AM
    15whtrd
    15whtrd Mr. Blonde
    Wish I saw that before I already ordered the Moto
  30. Jun 15, 2018 at 10:05 AM
    Hell, I have to get something for the GF’s SUV. Might try this.
    Black Wolf and 15whtrd[QUOTED] like this.
