Spare Tire Size
Discussion in 'Wheels & Tires' started by harrisdoggy, Nov 8, 2016.
  1. Nov 8, 2016 at 9:02 AM
    harrisdoggy
    harrisdoggy [OP] New Member
    Josh
    2016 Toyota Tundra CrewMax SR5
    Got a stupid question - if I have tires larger than stock (275/70R18 or 285/70R18) what should I do regarding the spare? Is it "ok" to drive on a spare that is a different size (stock) for limited miles until I can get the damaged tire fixed/replaced? Thanks and sorry for the stupid question. :)
    zcarpenter92 likes this.
  2. Nov 8, 2016 at 9:57 AM
    You can run the risk of damaging the diffs with different tire sizes on at the same time.
    equin likes this.
  3. Nov 8, 2016 at 2:23 PM
    Hey Sean think I started this thread a while back not sure if u or someone else replied I got 35 1250 20 what's closest that can fit in spare wheel well I don't care about trimming
  4. Nov 8, 2016 at 2:40 PM
    35" will be your best bet with a 3" lift.
  5. Nov 8, 2016 at 3:29 PM
    Royalpeeps
    Royalpeeps Awesome!!!
    Chad
    2017 Blazing Blue Pear Tundra SR5 TRD Package
    20" Fuel Vapor wheels 35" Toyo A/T II Tires 3 inch Toytec Boss kit with SPC UCA NFAB Wheel to Wheel Black Textured Nurf Bars OCD Center Storage Organizer and tray
    I have a 35" tire on my spare. Well it's like 34.6".
  6. Nov 8, 2016 at 5:07 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    I'm a big believer in having a matching spare and doing five tire rotations. The spare tire will eventually dry rot and need to be replaced anyway, so why not get some use out of it? With a matching spare I can get off the trail in relative confidence compared to having a smaller tire that may be a street tire as well and not worry about any weird handling characteristics at normal highway speeds.
    BravoDeltaRomeo likes this.
  7. Jan 11, 2018 at 3:58 PM
    rvrats2
    rvrats2 Too Often Yankees Overprice This Auto
    Carbondalé, CO
    2011 SR5. Bench Seat!
    Are you doing a five tire rotation with tpms? When it’s time to get new tires I’m going to jump up a size and I want to find a matching wheel for a 5 rotation. I’d like tpms to work if possible.
  8. Jun 13, 2018 at 10:18 AM
    phiredrop
    phiredrop New Member
    2015 MGM Tundra Platinum
    Did you have to do anything special to make it fit underneath?
  9. Jun 13, 2018 at 12:43 PM
    gosolo
    Ray
    NW Oregon
    The TPMS for 2015 is only for 4 sensors. To do 5 tire rotation I would have to reprogram at every rotation. I’m pretty sure it’s the same for 2016, 17, & 18. I do have a matching rim and identical size tire for the spare.
    equin and NewImprovedRon like this.
  10. Dec 27, 2019 at 2:34 PM
    haysr1
    haysr1 New Member
    2015 Tundra TRD 3'' Toytech Boss on 34'' Nitto Ridge Grapplers
    Did this ever get answered and is it under the truck where the normal spare is located?
  11. Dec 30, 2019 at 8:29 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Pretty sure you have to remove one or both of the two tires tabs that are spot welding under there to fit a 35 without deforming it.
    I’ll be exploring this option soon myself. After I get my ssbuilt front bumper I’m going up to 35s :thumbsup:
    haysr1 likes this.
  12. Dec 30, 2019 at 9:05 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Would like to find out also. I have a spare 285/70/18 that I haven’t tried putting in the spare wheel well. I still have the original spare there,
    haysr1 likes this.
  13. Dec 30, 2019 at 9:16 PM
    Aerindel
    Aerindel New Member
    Montana
    Too damn big, thats how big. Yeah, I need to get on Keto.
  14. Dec 31, 2019 at 7:32 AM
    haysr1
    haysr1 New Member
    Thanks! I should be installing my new bumper this month. I currently have 285/75/17's which is almost a 34. I will end up finding a tear off of 285/70/18 to use as a spare since that will get me real close to what I have on for shoes. Please update us with your findings.
    equin likes this.
  15. Jan 1, 2020 at 8:32 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I have the same size wheel and tire combo and that’s what I did. I went with a 285/70/18 for the steel spare since it’s roughly the same diameter as 285/75/17. I would’ve liked having the exact same wheel and tire as a spare, but I cheaped out.
    Mine’s a 2015. I hadn’t thought about the TPMS issues some have mentioned on here.
    haysr1[QUOTED] likes this.
