For those with no driver side interior grip handle...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cubanchem, Mar 25, 2016.
  1. Mar 25, 2016 at 1:35 PM
    Cubanchem
    Cubanchem [OP] New Member
    Pedro
    Washington, DC
    TBD
    Anyone try to add one? Saw these on a different forum for FJ Cruisers, maybe a retrofit is in order? I guess biggest issues would be interference with airbags and if there's a logical mounting location long the top of the window area as I think the front pillar has the airbag in it. Anyone with more info, please let me know.
    MOTORHEAD likes this.
  2. Mar 25, 2016 at 1:45 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    You could order this from Toyota: Here are parts numbers.
    Pillar trim:
    62220-0c050-E0 for SAND
    62220-0C050-B0 for GRAY
    Handle:
    74610-0C081-E0 For SAND
    74610-0C081-B0 for GRAY
  3. Mar 25, 2016 at 1:48 PM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    Would that not interfere with the airbag?
    FireInTheDesert likes this.
  4. Mar 25, 2016 at 1:51 PM
    chphilo
    Western PA
    Well, all Tundras from 2007 to 2013 had them from the factory. I would imagine if air bag had been an issue, they would've had a recall.
    FireInTheDesert and 4x4_Angel like this.
  5. Mar 25, 2016 at 1:51 PM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    OK, good point. thanks
  6. Mar 25, 2016 at 2:52 PM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    Thanks for the write up
    rv740 likes this.
  7. Mar 25, 2016 at 3:30 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    this is a really good and helpful mod. Seems a shame this standard item on previous models was eliminated. I am thankful to these forums for help with solving issues like this.
    FireInTheDesert and Relentless like this.
  8. Mar 25, 2016 at 4:09 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I sure wish i had one on my 2016. The parts do still fit 2015-2016 correct?
    (Unrelated another thing i wish i had was back door pocket storage and more above head roof console storage)
  9. Mar 25, 2016 at 6:18 PM
    DBL TAP
    DBL TAP Light 'em up
    USA
    Yes, they fit perfect. I made this mod to my '16 and it looks like factory. The cost was $160.00 from Cool Springs TOYOTA.
  10. Mar 25, 2016 at 6:55 PM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    Thank you for all the input
  11. Mar 30, 2016 at 8:54 PM
    jmcolejr
    jmcolejr New Member
    James
    BRONZE 2015 TUNDRA 1794
    I installed my Pillar trim and handle about three ago. Got all of my parts online about $148.00. No pictures...yet. Easy MOD.
    Thanks
  12. Mar 31, 2016 at 7:28 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I use my grab handle every day to get into the truck. Very useful to have it on the drivers side. For those that don't have it, i would highly recommend getting it.
  13. Mar 31, 2016 at 7:50 AM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    Thanks for the input. My only concern is the airbag. Does the grab handle version account for this?
  14. Mar 31, 2016 at 7:55 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Yep doing this mod! 5'8" with a lifted truck and no steps is a pain to get into!
  15. Mar 31, 2016 at 7:56 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    The new trim has the SRS logo so Id say yes.
  16. Mar 31, 2016 at 8:08 AM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    Ok cool. Thanks
  17. Mar 31, 2016 at 11:52 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Order mine they should be here tomorrow.
  18. Mar 31, 2016 at 11:53 AM
    csuviper
    Broomfield, CO
    Yep it has the SRS Curtain Air Bag logo just above the grab handle.
    Passenger side air bag deployment shows its not affected by grab handle.
  19. Mar 31, 2016 at 12:27 PM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    Cool, I appreciate the feedback. Will orde soon.
  20. Mar 31, 2016 at 1:48 PM
    DBL TAP
    USA
    Attached is a PDF file that takes you through the complete install. Credit for this goes to a member at another tundra forum. Easy install, but the 1/4x20x1.5" must be an all thread bolt. I used a 1.5" shouldered bolt and it required 3 washers before it would tighten up. You could use a 1.25" shouldered bolt with a single washer if you could find one. Anyway, it's an easy and very worthwhile mod.
  21. Mar 31, 2016 at 5:08 PM
    Cubanchem
    Pedro
    Washington, DC
    TBD
    Thank you!
  22. Mar 31, 2016 at 7:40 PM
    DBL TAP
    USA
    You're welcome!
  23. Mar 31, 2016 at 8:12 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    I hate to tell you but Toyota does not use a 1/4x20 bolt on any vehicle I've seen. All hardware is metric that I know of it may be different with a Tundra but all hardware I have ever seen on a Toyota is metric.
    When I install mine I'll get the metric numbers if they in fact metric as I assume they are.
    FireInTheDesert, tHondo and csuviper like this.
  24. Mar 31, 2016 at 9:00 PM
    DBL TAP
    USA
    IF YOU READ the PDF file in the #24 post on this thread, you will know why a 1/4x20 bolt is being used. Don't assume anything.
  25. Mar 31, 2016 at 9:14 PM
    csuviper
    Broomfield, CO
    Drivers side.
  26. Apr 1, 2016 at 4:40 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Yep didn't read that far I stopped when he said to use a 11 mm on a 1/4x20 bolt.
  27. Apr 2, 2016 at 8:44 PM
    DBL TAP
    USA
    It's all good.
  28. Apr 5, 2016 at 1:12 PM
    Tacogrande
    Jeremy
    I just got in the parts and did this mod..Thanks for sharing this info guys! My first real mod on the truck. Here is something weird i found out about my Kobalt socket set...there are 3- 10 mm sockets and one of them is 6mm but marked 10! So i will need to have Lowes take care of that.
  29. Apr 13, 2016 at 8:58 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Did mine today. I used a 1" ¼ x 20 all thread bolt with a ¼ x 20 extruded speed nut. Worked great.
    Henry1jg, bulldog93, Lilly and 2 others like this.
  30. Apr 24, 2016 at 11:56 AM
    Fishinstud
    Fishinstud New Member
    San Antonio, Texas
    2016 TSS Off Road 4x4
    Oh poop! Driver's handle Lock'er Down Console Safe BAMUFFLER standard 6” stainless steel exhaust
    Thanks for all the info on this mod. I installed "Oh, Sh@t!" handle today and it looks like a factory install.
    Cheers,
    Ray
