Wheel and Tire upgrade
Discussion in 'Wheels & Tires' started by jburcina, Jun 5, 2018.
  1. Jun 5, 2018 at 12:26 PM
    jburcina
    jburcina [OP] New Member
    jason
    Oregon
    2018 Toyota Tundra Crew Max SR5 Stcok
    Rough Country light bar and running boards. 285/65/R18 XD Grenade wheels with Cooper STT Pros. Airlift rear airbags and Bilstein 5100 Coil overs.
    Hey guys, I'm Jason and this is my first Tundra. I picked up a 2018 Crew Max SR5 and I was looking to add some nice wheels and tires to it without lifting it. I really like the XD Grenade 820 in the 18inch size with a 18mm off set and the Cooper STT Pro (285/65/r18). I'm worried about it rubbing, any thoughts or advise would be greatly appreciated
  2. Jun 5, 2018 at 1:08 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  3. Jun 5, 2018 at 1:10 PM
    jburcina
    jason
    Oregon
    Thank you very much
  4. Jun 5, 2018 at 1:18 PM
    Welcome from Ohio!
  5. Jun 5, 2018 at 1:23 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Welcome to the forum.
    18 mm offset wheels (18x9) with 285/65/18 tires should not rub at all. 285/65/18 is only about 1/2 inch taller than stock 275/65/18. Another tire size option to consider is 275/70/18. That's actually 1/2 inch taller than the size you were looking at. Somehow, tires at this size is somewhat cheaper than 285s.
    jburcina[OP] likes this.
  6. Jun 5, 2018 at 1:27 PM
    jburcina
    jason
    Oregon
    Right on. Thank you!
  7. Jun 5, 2018 at 1:46 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Welcome from Washington.
    Currently running similar set up. 285/65/18 w +20 offset. I had to remove the mud flap in front of the front tire. Other than that no rubbing. I have heard the stt pros run taller than most 285/65 d/t aggressive tread. Not sure how accurate that is though.
  8. Jun 5, 2018 at 1:49 PM
    jburcina
    jason
    Oregon
    is that with a stock suspension?
    jewsNbrews likes this.
  9. Jun 5, 2018 at 1:51 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Yes, still stock. Haven't saved enough for suspension. Bought wheels and tires. By the time these tires are ready to be replaced I will upgrade suspension and tires.
    jburcina[QUOTED][OP] likes this.
  10. Jun 5, 2018 at 2:00 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    I ran that exact wheel size, width, offset with same size tire but Nitto trails. 0 rub. Stock suspension.
    Now my dad is running that exact setup on his stock 2008 2wd:
    Welcome.
    parker44 and jburcina[OP] like this.
  11. Jun 5, 2018 at 2:18 PM
    jburcina
    jason
    Oregon
    was that the 285/65 or the 275/70
    Wolvi71 likes this.
  12. Jun 7, 2018 at 5:02 PM
    Wolvi71
    Wolvi71 New Member
    Franco
    2016 red tundra SR5
    Yes @Pale_Horse
    What size are the ones you are using. I like the way your tundra looks.
  13. Jun 7, 2018 at 8:46 PM
    Pale_Horse
    FL
    Cupcake chit.
    @jburcina
    @Wolvi71
    285/65-18x9 +18 thanks that is my old mans truck. I do like how these trucks sit with that setup on stock suspension
    7BCECAF8-EB89-4610-9F14-FCE3D5557D50.jpg 9B0AA169-CB9C-4731-8F64-689C8B080B9C.jpg E338CFFC-05E8-4C9B-A01F-67FD01181F3B.jpg
    I tried to find some old pics of that setup on my truck to give you an idea of how 285/65 on 18x9 +18 looks on truck without flares... best I could come up with:
    FD528B85-6678-4A2F-9032-96F08CC01DA9.jpg 96101C96-A98C-43FC-BD07-F58C4DC10E48.jpg
    jburcina[OP] and parker44 like this.
  14. Jun 9, 2018 at 3:54 PM
    jburcina
    jason
    Oregon
    Went with the 285 65 r18. Slight rubbing when I back up. Il use a heart gun to fix the issue
    KELZ84, parker44, DaBoro54 and 4 others like this.
  15. Jun 9, 2018 at 4:48 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Good lookin' truck Jason! :thumbsup:
    jburcina[OP] and jewsNbrews like this.
  16. Jun 12, 2018 at 7:38 PM
    jburcina
    jason
    Oregon
    Quick update. I had to remove all the front mud guards and the factory front wheel liners to eliminate the rubbing issue. Now I need to find a thin mud guard
  17. Jun 12, 2018 at 7:43 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    What wheels are those? Size, offset?
  18. Jun 12, 2018 at 7:53 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Those wheels look great with the cement color. You may be able to keep the front liner after removing the front mub flap. There are several bolts under the bumper that hold the liner in place. I was able to remove the inner bolt, push the liner forward about an inch, and then drill a new hold in the liner to hold it in place.
  19. Jun 12, 2018 at 8:18 PM
    jburcina
    jason
    Oregon
    The wheels are XD Grenade 820 18x9 with an 18mm positive off set. 285 65 r18
    Mo_Martz likes this.
  20. Jun 12, 2018 at 8:19 PM
    jburcina
    jason
    Oregon
    Good idea. I'll have to play around with it
  21. Jun 22, 2018 at 6:42 PM
    Mo_Martz
    Mo_Martz New Member
    Great Country of Texas
    2017 White Tundra CM
    Do you have a shot of it from the front? I was wondering how much they'll stick out with the 18+ offset. I'm looking at getting these in flat black.
  22. Jun 22, 2018 at 7:10 PM
    jburcina
    jason
    Oregon
    I'll have to upload one when I get home, but yes
  23. Jun 22, 2018 at 7:43 PM
    treihing
    treihing MAGA
    TR
    Washington State
    2018 Black Limited CrewMax
    Welcome J-Bone!
  24. Jun 22, 2018 at 8:37 PM
    jburcina
    jason
    Oregon
  25. Jun 23, 2018 at 6:38 AM
    Mo_Martz
    Mo_Martz New Member
    Awesome! Those look great with that offset. Thanks for the photos. I really do appreciate it.
  26. Jun 23, 2018 at 11:21 AM
    jburcina
    jason
    Oregon
    thank you, i love them!
  27. Jun 26, 2018 at 4:17 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    That is a sharp looking setup you have!!!
  28. Jun 26, 2018 at 6:40 AM
    Mo_Martz
    Mo_Martz New Member
    Well Jason thanks again for the photos. Welcome to the forum. I'm getting my 20" XD Grenades put on my truck now.
  29. Jun 26, 2018 at 9:03 AM
    jburcina
    jason
    Oregon
    Please post pictures when you do. The Grenades are bad ass wheels. I didn't want to do the lift since it interferes with the sensing system for the 2018 model and the dealer will void the warranty. So this worked best
  30. Jun 26, 2018 at 2:28 PM
    Clippers015
    Clippers015 New Member
    DK
    OC, California
    2008 Tundra 5.7L SR5
    None yet =)
    This thread is the thread I was looking for! Just joined after a frustrating week of searching and not finding the right answers.
    I got a 2008 Tundra DC 5.7 RWD 2 years ago and need to get new tires and since I had steelies on them, figured I try and find some upgraded wheels on CL in good condition.
    I located one that is an 18x9 with a +20 offset and was confused on what type of tire could be used with minimal alterations. It seemed like most trucks had lifts and I don't have the extra dollars for a lift and new wheels/tires.
    It seems like 285-65-18 or 275-70-18 could work? I sort of prefer the wider thread tire, but will check out prices for both!
    Is 275-65-18 going too small and thin?
    I look forward to learning more on the forum!
